1455 -
Sve što je postavio član: GixxerK6
A vezano za incident 46 i 93 o kome se priča nikada nisam video da je neko na takav perfidan način odveo nekoga spolja u krivinu gde je nesrećnik 93 blokirao prednju ako se dobro sećem i pljusno na maloj brzini. Ja se sećam King Kennija, Fast Fredija ali ovo ne pamtim. Za to sledi DNF. Svejedno 99 je te godine na Yamahi kidao i Lossiju ništa nije pomoglo pa čak i nagrada da startuje sa zadnjeg mesta u sledećoj trci jer je završio u sekundama tačno tamo gde mu je mesto. Španske serije nisam gledao tako da ne znam ništa o teorijama zavere. Za ovu trku u Qataru 2018 moram da kažem da je Lossi pokidao. Svaka čast, deda je legenda.
Ako poredite 93 i 27 ovo nisam hteo da pamtim već sam zapisao, priča Shuei Nakamoto: How would you compare Casey Stoner and Marc Marquez? I can’t, because their personalities are completely different. Both riders have something special on the track. Marc is special on the brakes; Casey was very fast on cornering speed. Casey was very good in acceleration. May be he found the correct bank angle or the correct power delivery control or something…in the data you could see that he had perfectly under control the limit of the tire grip, the point where the tire grip ends and the traction control starts to work cutting power. His throttle control on acceleration was amazing—always on the edge. Marc is similar, but definitely he uses more the traction control help. Did you understand why he quit? No! Casey is so difficult to understand! But I respect his decision.
Za sada EON preko Web-a ima dodate SK kanale sa mogućnošću simultanog gledanja sa više kamera, koliko vidim On Board 1-3. Verovatno i EON aplikacije za Android, IOS, PC, Mac. U listi kanala preko risivera će se pojaviti nešto kasnije tokom marta ako ih sada nema posle restarta risivera SK7-SK10. EON Početna EON APP's Treba aktivirati EON, dostupno je ako ste koristili MojSBB portal, kucate iste kredencijale. EON radi mnogo bolje nego pređašnji D3GO. Prebacite ovo u adekvatnu temu jer nije vezano za Doha trku.
Jes bogami mene u subotu gu*a zaboli od vožnje
@Simon69 U tvojim godinama se treba čuvati preteranog uzbuđenja , hahaha Ja ne znam šta će ovi sa maketama ali ja odoh da isteram jednu narandžu i to će biti baš ova sa wobblingom na 200km/h, danas bez velikih uzbuđenja da ne bude zdravstvenih problema Jbg, jače od mene...
Sad se nešto setih, kada se pojavio prvi android telefon koji je bio svemoguć za dotadašnje Nokie moj prijatelj je tako žestoko opljuvao tada najmoderniju android tehnologiju jer zamisli nema budilnik !! Ja to nisam prepoznao kao problem... Jasno je ako je ovo za tebe party breaker nema druge nego Gopro ili šta znam kameru koja kreira i lošiju sliku ali ima ozbiljan daljinac. Ja sam shvatio da na SJ7 da bi utvrdio da li radi ili ne radi snimanje moram da bacim pogled na led diodu na kameri i stvar rešena. Ne treba mi displej koji ima GoPro. Nije mi toliko nekomforno. Šteta što si se razočarao ali za takve zahteve moraš mnogo dublje da ulaziš u tehničke detalje pre kupovine i priča nije završena, znaćeš koliko ti proizvod odgovara tek kada stigne i kada napraviš prve vožnje.
Po ovome što je Severian rekao ako zaboravimo indikaciju statusa baterije na kameri (na SJ7 daljincu traje bar 6 meseci pa je irelevantno) ovde ne znaš da li kamera snima ili ne. Sa obzirom da SJ7 po kvalietu ni po ceni nije Gopro4 Black zavisno od toga da li je kamera ispred tebe ili na kacigi pogledaš led diodu na displeju ili spreda na retorovizoru ako je na kacigi za status i znaš da li snima ili ne. I sve to za 15 EUR. Nije show stopper.
@Lalajko Lale, ovo oko dva pritiska na shutter button kada je screen ugašen da čuva bateriju isto tako radi i kada ne koristiš RC već komanduješ na samoj kameri. Prvi pritisak aktivira sliku na ekranu a drugi okida. Kod RC je lepota što nema prebacivanja moda tj ne moraš da prebacuješ mode nego ako stisneš video ide video, ako je snap onda je snap itd (ekran mora da bude uključen). Na samoj kameri to ne može tako ali tamo je druga priča, gledaš u ekran prebaciš mode iz video u photo i okineš sliku. Znači ovo je dobra opcija kod RC, videćemo šta kaže SJCAM community oko zaobilska 2 pritiska na taster na RC za start video/snap kada je ekran ugašen a kamera na čekanju (Standby). Ja ne promovišem SJCAM ali vezano za probleme na koje si naišao prvo proveri da li koristiš sve kako je predviđeno, videćeš da kamera generiše odličnu sliku sa stabilizacijom u res koja baš tebi treba. Mene nije sram da uživam u sadržaju na poslednjoj generaciji OLED TV. Naprotiv. Verujem da je GoPro bolji brend ali npr ja kada sam kupovao ovo sokoćalo 4K Gopro cena je bila X2, čitaj bar 400EUR a budi uveren da i tamo ima sitnica koje bi te više zabolele za tih 400 nego ove za 130 EUR. Vidim da se ovde često spominje Hero2 koja je zaista dobra kamera ali evo jedno iskustvo na istom putu na jednoj glavi SJ4000 a na drugoj Hero2. Na Hero2 skeleton ispred objektiva zamaglio po nekim brdima tamo i promenama temp i jasno ti je kakva je bila slika a SJCAM odradio sve kako treba. Nismo imali te kesice koje piju vlagu, mislim da sam ti dao jednu sliku šta može da te sačeka. Ako sutra kupiš KTM ADV 2018 za solidnih 17K ojra to ne znači da za 6 meseci neće da ti crkne ABS ili da za svih 17K ojra nećeš imati wobbling na 200Km/h. Zato ti voziš BMW Nadam se da sam ti dao hint barem kako ja to vidim
Oko Mic kada smo pricali bilo mi je jako cudno kako moze da radi pa da ne radi, logika kaze neispravan mic ili los kontakt. Super je da si to resio. Nema los audio ali nije cist kao na Gopro 3, 4 npr, pricam za snimanje glasa. To shvatis tek kada poredis ali i ovaj audio je sasvim ok. Action kamera nema primarnu funkciju snimanja audia vec kao sto znas ide slika a podmece se neki drugi audio stream u najvecem broju slucajeva. Malopre posle 1god probah moj RC. Malo se podsetih pa sam ukapirao da ne radi preko WIFI a WIFI valjda sluzi za konekciju sa Android aplikacijom, download slika,videa mada je to po meni besmisleno zbog brzine i sta ce mi to na telefonu SJ7 snimci sa 60mbits bitrate, treba tu i memorije pa telefon koji to pusta itd. Gledam da ne mesam babe i zabe. FW update direktno sa kartice, posao od 15sec a na Android app sam video da mozes i da podesavas meni na kameri setup itd ali osim boljeg pregleda u trenutku podesavanja nista vise. Hocu reci meni je WIFI na OFF, sparam bateriju a i ne znam sta ce mi android app. Sve ovo ti vec znas ja samo potvrdjujem kako ja vidim taj deo price. Moj RC se upario odmah (stoji tacno 1god) iako sam imao poruku za timeout i posle toga pri svakom paljenju kamere odmah radi bez uparivanja. Na komande reaguje besprekorno, stisnes taster upali se plavo pozadinsko svetlo na RC i nijednom nije omanuo. Menjas modove pritiskom na odgovarajuci taster jednom Video, sledeci put slika pa photo burst sve radi sta stisnes on okine. Bez RC na samoj kameri moras prvo da promenis mod, video ili photo. Sa RC ne mora. WIFI ON/OFF sa RC radi kao i kamera turn OFF. U pravu si za 2 pritiska na RC komandu video ili photo kada je screen u turn off ali ovo isto vazi i kada komandujes na samoj kameri. Kod mene ide u off posle 30 sec (podesava se do 5min) tako da je jednostavno, kada si na motoru ako si imao pauzu bez komandi 1min ides uvek 2 pritiska na taster. Na FW 1.21 u FHD 1920x1080, 60FPS, Superfine, Wide, Gyro sensor ne sme da bude zasencen i mora da mozes da ga ukljucis i iskljucis. Kao sto si video u tabeli Gyro radi samo u FHD na 30 i 60 FPS, za sve druge res je zasencen. Tako je kod mene.
Lale, ovako ja to vidim iako nisam žestok korisnik te kamere. Tvoj primerak je imao taj problem sa lošim kontaktom za mic ali si to tako lepo i elegenatno rešio da nije moglo bolje. Osmeh na lice, prepreka 1 savladana. Dok ne kupiš kameru broj 2 ne znaš koliko ti je ova više ili manje odgovarala jer svaki proizvod ima dobre i loše strane. 1. Nisam mnogo koristio daljinac ali on naprosto radi iako na displeju nema adekvatne potvrde o tome, moguće da wifi ikona promeni boju, proveri to nisam koristio. Što se funkcije paljenja kamere preko daljinca tiče ja bih to uporedio kao sa TV, ako TV ugasiš na dugme (nije na Standby) tvoj RC ga neće upaliti jer je ovaj bez napona pa tako i za kameru, pritiskom na dugme "ON" kamera se pali i ulazi u Standby posle vremena koje ti definises, gasi se ekran npr, i RC komande rade. Ono što bih ja zamerio koliko se sećam ja kada stisnem dugme za start ili prekid snimanja ja ne znam da li je komanda izvršena. Daljinac ima neko svetlo kada stisneš taster valjda kao znak da si ga pritisnuo ali ko garantuje da snimanje sada radi. Nisam koristio RC možda to jednostavno radi bez obzira što nemaš povratnu informaciju. Moguće da se zaglupi ako mu daš seriju komandi u kratkom vremenu a dok prethodnu nije izvršio. 2. Poslao sam ti ovde u kojim rezolucijama radi Gyro sensor SJ7 Res, znači ako hoćeš Gyro on radi tačno tamo gde tebi treba u FHD na 30-60 FPS. Ovo je izgleda neko ograničenje Ambarella chipa. Kod mene na 1.21 to nije zasenčeno. Obrati pažnju da ako često vadiš bateriju ili reset da ti je default rezolucija 4K i tu ti je Gyro zasenčen. Nisam primetio da zablokira kod fotografija. Testiraj to komanda po komanda, jedna po jedna. 3. Nisam primetio. Ako komanduješ preko daljinca, probaj da eliminišeš njega pa direktno komanduj na kameri. Ugasi WIFI. Moje iskustvo sa SJ7 tada sa starijom verzijom FW je na motoru, na letovanju napolju i pod vodom sve na FHD 60 FPS i nisam primetio ništa neobično. Daljinac iako ga imam nisam koristio a probao jesam, video da radi i to je to. Nisam ga koristio jer se nisam bavio time gde da ga "obesim" na motor a nisam hteo da ga nosim na ruci, za motor nepraktično. Ako te zeza i dalje start/stop kada je WIFI ugašen a znamo da imaš pravilno formatiranu relativno brzu SDXC onda zaista nisi imao sreće sa tvojim SJ7 primerkom.
Mislim da si dobro rekao Lestvica nivoa trkanja se pomerila i neki ispadoše i bez obzira na zlatne ruke, najbolje timove i inženjere se ne snađoše Posebna priča je dolazak Mišelina koja je svakome dala šansu da se na nekoj od trka nešto bolje snađe na svom motoru Meni je Rossi kao Rossi super lik bez obzira ne njegove trikove kako su se uzimale pobede u prošlosti ali taj novinarski/marketinški, nerealan/neobjektivan i van realnih očekivanja hype je nešto šta mi se gadi, španske serije (čitaj teorije zavere) itd. Mislim da to više smeta samom Rossiju jer ne može da se sa time nosi (nerealna očekivanja) Ima ona izreka koju volim u svakom poslu pa i u mom: "If your strength is weak, don't carry heavy burdens" Mislim da je to to, prevelika očekivanja.
Da, CTEK je jedna opcija izgleda da je dobar proizvod, ima više modela i izlaznih struja. Louis je takođe dobar izvor za te punjače, Optimate, ProCharger itd, vidim sada neki punjač na popustu za 19-20 EUR, ima za svakoga ponešto da izabere. Louis punjači Samo još jedan savet kada smo kod nabavke ovog punjača pošto je to sada postalo već skoro standard, Li-ion baterije... Kada kupujete punjač piše za koje je baterije, olovne/gel/AGM ali nije za Li-ion, a ima poseban za Li-ion baterije. Ja sam imao jedan koji pokriva sve tipove baterija ukljucujuči Li-ion ali kada sam video da je struja 4A za Li-ion nisam nastavio punjenje jer su moto baterije male i to je velika struja. Za sada ako se nešto drugo nije pojavilo za Li-Ion poseban punjač. Ja koristim više komada ProCharger već dugo, rade ok, evo nekih karakteristika: Note: Conventional trickle chargers and car battery chargers will damage motorcycle batteries. Motorcycle batteries are designed to be small, which means the metal components are reduced in size and are easily damaged by high charging currents and chargers that continue to trickle charge after the battery's full capacity has been reached. The SAITO ProCharger is different: It helps you keep your bike on the road with a micro-processor controlled regime to keep your battery in optimum condition! The (very) techy stuff: Multi-stage charge mode (I /U1 /U2) as well as pause cycles Battery can remain permanently attached Protection from short-circuiting and reverse polarity through an electronic protection circuit Automatic battery care mode Maintenance mode to maintain your battery's maximum charge capacity Charge and discharge function (ideal for winter storage) Test functions, including fault diagnostics and testing of the battery’s ability to hold charge Manually switch between 6V and 12V Charging current maximum 1A (full automatic adjustment) 16 LEDs in 3 colors deliver a comprehensive and easily understood status display - 5 LED lights for the five-stage charging cycle (displayed in % bands) - 2 LED lights for the indication of the voltage setting (6V and 12V) - 4 LED lights to indicate the battery condition: Deep discharge, defective, reverse polarity and ready for use - 4 LED lights for the identification of the basic functions - 1 LED light for mains connection Long connection cables: Mains lead 1.70 metres; Battery connection cable 2.20 metres Cable set with crocodile clips for direct connection Cable set with eyelet connectors to create a permanent charging point on your bike Prepared for wall fitting Measurements (W x H to (max.) x D): 10 x 6.5 x 15 cms
Pre ili kasnije treba nabaviti punjač koji može stalno biti priključen na bateriju npr tokom zime. On sam ima više modova, punjenje, pražnjenje, održavanje, desulfatizacija itd Dok su baterije nove mali je i unutrašnji otpor tako da je sporo samopražnjenje a kasnije se stvar poprilično degradira i postaje problem. Ovaj motor ima ozbiljnu bateriju ako porediš kapacitet/veličinu i struju koju isporučuje pri paljenju pa je zato treba i održavati, ima ozbiljan zadatak ispred sebe. Ja sam to davno provalio na KTM sa jednim cilindrom o od tada adekvatan punjač se podrazumeva na polici u garaži kao sprej za lanac
Sa ovakvim Mišelinkama se nikada ne zna, zato smo i imali "šarenu" 2017 i partije ovakve i onakve Koliko će se to stabilizovati u 2018, videćemo
Jel vi to opet o Lossiju?
Verujem da nije nimalo lako...
Ja potvrđujem wobling na 990 SMT, bez kofera, mislim da je više nego jasno odakle to potiče. Putevi kojima se krećem toliko retko nude mogućnost za brzinu 170+ tako da ja na to zaboravim. Autoput volim samo u kolima a na motoru vidim kao smrtnog neprijatelja za ovalnu moto gumu i mali gazeći sloj gde se guma pregreje i upropasti. Zato "Super Vojvoda" ako ćemo po KTM-u nema problema sa woblingom Stoji i skuplja prašinu
Sve smo razumeli i sve je jasno ali to je bila Nik epizoda. Wobling ima veze sa koferima ali motor ima wobling i bez kofera, to sam hteo reći.
Meni je sve jasno, i tvoj i Nik-ov kao i bilo čiji drugi stav kako za KTM tako i za bilo koju drugu marku. Mi koji koristimo KTM-ove znamo za sve te kako si napisao "bubice", neko živi sa tim a neko ne želi da pomisli da to može da se desi na motoru od 10+K EUR. SM690 koji sam spomenuo sam "trejdovao" za jedan nov motor koji se deklariše da može da se vozi kao SuperMotard, snažniji dosta od ovog malog 690 ali na kraju sam ukapirao da taj novi nikada ne može da bude SM690 sa svim manama i vrlinama i da zapravo tamo gde sam ja mislio da ću da se krećem brže samo zato što je taj motor brži i snažniji ja zapravo to ne mogu zbog samih voznih karakteristika ovog drugog. Tu je lepota tih KTM-ova.
Pa tu i jeste trik, ljudi imaju različit pristup i to je sasvim OK. Tvoj Enduro 690 sigurno te nije ostavio na Terazijama već negde pretpostavljam u šumi a ti ga nisi bacio u potok i napisao da sada kada vidiš kamion gradske čistoće naježiš se oranž boje iako je i to individualno kompletno prihvatljivo. Iako i ja imam wobling problem kada sam vratio moju arhivu oko toga video sam da sam temu kompletno razradio i da je trebalo samo "delati" ali da sam ja to stavio kompletno u zapećak mojih ideja na mom KTM jer je to kompletno irelevantno. Wobling nema veze sa koferima, motor se ljulja i bez kofera. Da je naš drugar Nik zamenio levi semering i prednje diskove on bi i dalje kako je rekao vozio najlepši motor, motor kojem kada daš gas i kada kočiš mami ti osmeh na lice, na autoputu bi bio poslednji ali ako mene neko pita nikada ne bi menjao kvalitet vožnje na autoputu naspram uspona na Etnu kako je Nik napisao. Brzina preko 150km/h sa koferima pa kome to treba? Gledam na jednom UK forumu lik kaže ja kada hoću da vozim preko 150 isteram drugi motor iz garaže jer je ovaj totalno nebitan u toj priči. To isto radim i ja. Svejedno imamo iskreno Nik iskustvo i način kako je on ušao i otresao se oranž motora. Tako je to uradio Nik i ništa više ni manje.
Pa kako kada se motor ljulja a trke se odrzavaju samo na autobahn preko 170? Sala mala ali zaista sve sto je nas drugar Nik napisao nema dileme da se to odigralo ali nipodastavati jednu robnu marku zbog jednog izolovanog slucaja sa dodatkom licnog dozivljaja istog i spletom dogadjaja oko servisa je neozbiljno. Ali zato je lepota u razlicitosti, ne moze svako ni KTM da vozi sto je potpuno ispravno.
Iz svega što je sada već bivši KTM-džija iz DE napisao imamo 3 problema koji su se javili, wobling na autoputu na 170km/h, curenje levog semeringa i vibracije prednjeg kraja (krivi diskovi). Tu sada može da se otvori kompletna priča, šta, kako i zašto se to desilo, da li je to izolovan slučaj ili masovna pojava i kako se pristupa rešavanju problema. Za sve postoji rešenje pa i za wobbling ako je to primarno, naravno nešto ćeš dobiti a drugo izgubiti. Mislim da je trik u pristupu. Sve ostalo bez ljutnje je neka lična dramatrurgija, veš mašina sa blokadama, cena servisa u DE, nesporazum sa servisom i godišnjim odmorom od 4 nedelje itd. Možda i prevelika očekivanja iako si tresno 10-15K ojra. Evo ja ću ispričati samo jedno iskustvo sa jednim od KTM-ova i drugačiji pristup, Kepo gore spomenuo SM690. Ne radi se o meni, o mom drugaru ali i ja sam upleten pa znam sve detalje. Kupio sam nov SM690. Ima tu nekih gluposti koje se dešavaju ali to je skroz nebitno za kompletnu priču jer se to sve olako rešava (master i radni cilindar kvačila strada gumica pa vlaži ulje dok ne izgubiš kvačilo, rebraste gume na retrovizorima posle 1god pucaju (nov retrovizor 16eur), otpadaju neki šrafovi dok ne ukapiraš da treba malo da staviš Loctite 243, baterija uvek kora da je u top stanju) ali da nema toga svega kako bi našao razlog da uopšte uđem u garažu Posle cca 20.000km ustupam motor drugaru koji mi je kao brat, evo ti vozi, pare kada budeš mogao. Motor ozbiljna zabava i tako to krene, osmeh uvek na licu. Jedan dan motor staje u nekom selu u okolini Uba i ni pomisli o paljenju. Stao je u pokretu bez ikakvog znaka da nešto nije u redu. Vergla normalno ali nema paljenja. Ostavljamo motor kod nepoznatog čoveka u dvorište, vraćamo se kolima u Bgd i sutra kombijem po motor. Sve smo proverili šta se moglo prveriti sa znanjem i alatom koji više naginje elektronici i struji nego mehanici i sve kao lutka, status isti. Zamenimo svećicu, sve isto. Zovemo KTM servis u Bgd, dogovor da se dotera motor u 16h. Servis dobija sve inpute šta je bilo, mi odlazimo. U 18h Viber poruke sa slikama da je motor izgubio kompresiju usled pucanja klackalice (usisnog ili izduvnog ventila) i da sve to raspalo u motoru ali da ništa nije oštećeno i otuda nema nikakvog čudnog zvuka. Klackalica ima jedan roller koji ide preko bregova i roller kada zariba pukne stub klackalice i sve se raspadne. Ok cena popravke sa delovima 400 EUR, tu sada ide klackalica, ulje, filter i još ponešto ali cena rada u tih 400 je 150 EUR. 22h motor očišćen, sve zamenjeno može da se preuzme. Sutradan idemo po motor. 400 ojra nije bilo malo i ja zbog neke griže savesti kažem drugaru da podelimo trošak nije tu bilo nikakvog znaka da se to može desiti niti je bilo ko mogao da predvidi ali je izgleda poznat problem jer klackalica ima reviziju i novi part number, pri tome servis taj specifičan deo ima na lageru, znači troši se... Ne znam koliko je 400 ojra u DE ali u SRB znam koliko je, bilo je malo kiselo kada smo vadili pare iz džepa. Ode ovaj da proba motor i kada se vratio i otvorio vizir bio je kez od uva do uva i više niko nikada nije spomenuo tih 400 EUR. Imam mnogo drugara koji voze taj motor u obliku SM, SMC, Duke 690 i ja nikada nisam rekao da je taj motor sranje samo zato što sam ja imao feleričnu klackalicu. Znamo za potencijalni problem ali niko ne priča o tome a svima se vrti točak. I dalje taj motor mami osmeh na lice. Da li mislite da na mojoj Yamahi Bucking Bronco iz 2015 nema fabričkih opoziva? Smešno...
Iako može da bude do guma u ovom slučaju to nije problem jer je slučaj masovno poznat na modelima koji imaju visok prednji kraj a zadnji dosta niži. Pri tome vešanje mekša strana, neki ADV fazon, opstrujavanje vazduha oko raznih karakondžula motora i to je to. Sve to se dešava na većim brzinama tako da ako malo okratiš autoput i kreneš da se voziš po "backroads" nemaš predstavu šta se dešava na 170km/h i stvar rešena. Mislim da je Nik_Sa015 sve napisao kako je bilo i tu nema razloga za sumnju ali je takođe napisao kako je on to lično doživeo. Ja bih rekao da KTM ima poneku glupu boljku ili nešto što može da ti pokvari užitak ali daleko od toga da je to za odbacivanje motora. Taj Suzuki, neka Honda i šta ti ja znam nikada mu neće izmamiti osmeh na lice kao na KTM kada mu daš gas ili kreneš da kočiš. Da li negde curka/vlaži antifriz, ljulja na 170, loša serija Brembo mastera koji uvlači vazduh sve se to prevaziđe i idemo dalje. Tačno je da je na nekim modelima lošija kontrola gasa na malim rpm ali kome to toliko smeta neka kupi Hondu. Ja imam jednu Yamahu iz mog potpisa koja je još gori slučaj u tom smislu (otuda Bucking Bronco) a glavni razlog su stroga pravila za emisiju gasova do određenog rpm Promeniš režim vožnje i pičiš dalje...
I ja sam procitao da BMW a pogotovo Adv kao i KTM treba obilaziti u sirokom luku.
