HD720p Kamera
  • Svrati ponekad, 226 postova
  • Lokacija: Backi Petrovac, Vojvodina
  • Motocikl: Tomos Automatic A35-S / Kawasaki ZZR600
Neshto sam trazio review za MD80 kamericu ( kojoj se by the way slika trese kao da se boji nekog ) i koshta oko 1500 rsd, posle puno pogledanih review-a naidjem na ovu kamericu:
U pitanju je HD 808 #11 kamera koja snima u 720p @ 30fps ( 1280x720 ) i to joj je prirodna rezolucija, nije upscale.
Specifikacije:
100% brand new really true H.264 720P HD DV Mini car key chain.
Smallest Pin-hole Camera made especially for recording use.
Latest version 3 in 1 function: video record, camera, pc-webcam.
720P high Definition Video 1280 x 720 H.264 30fps.mov
5.0 Mega pixels Photo JPEG format: 2592 x1944.jpg
Useing as a driving recorder 20 minutes close-and-continue.(1280x720 H.264 30fps).
Support our company dedicated car charger configuration to side recording video features while charging.
Support USB 2.0
Mass storage.
PC-Webcam 640x480.
4G TF card can video about 80 minutes.
External Memory: Support up to 32G TF memory card ( you’d better use the SDH4 FILSH MEMORY High-Speed Card.)
Playback video on your PC.
Easy connection with PC/Laptops, no driver needed.
Built-in rechargeable high volume Lithium-ion Battery 250mA
Built-in Charger manage IC
Real time record any video evidence instantaneousl.
Dimension(mm): 50 (L) x 32 (W) x13 (H)
Kao shto vidite mala je kao privezak za kljucheve tako da moze da stane u kacigu a kvalitet videa i zvuka je daleko iznad MD80 kamere. Koshta oko 40$$
Sa novim Firmware-om moze da se skine datum i vreme i da se namesti da snima file-ove od po 4gb a ne na 20 min kako je po defaultu namestena...
http://cgi.ebay.com/Keyfob-cam-DV-LENS-Camera-DVR-video-camera-808HD-11-/150624928908?pt=LH_DefaultDomain_0&hash=item2311f2048c
Shta mislite ? Jel vredi tih 40$$ i jel ima neko iskustva sa ovom kamerom ?
  • Svrati ponekad, 125 postova
  • Lokacija: Zemun
  • Motocikl: GW
Kosta mnogo manje, prodaju se za oko 1500 dinara po limundu i slicnima.
Sigurno vredi, posebno kada nemas za bolje, Ako imas za bolje ne vredi.
Tesko ju je namestiti, ume da zabrljavi, nikad ne znas da li snima, fotka ili nesto trece.
No, 1500 din je 1500 din.
Btw. rezolucija jeste 720p ali to ne znaci da je kvalitet HD. Boje i ostrina su daleko iza 720p materijala i ukupno je treba tumaciti kao wide PAL.
Za one sa jeftinijim ulaznicama, kvalitet je a'la losiji divx filmovi.
Naravno da je snimak losiji od kamera koje kostaju po 250€. Ova snima @7000Kbps a te od 250€ idu do 20000Kbps. Ali na ovoj se barem slika netrese ko na MD80.
Ali shta ce ti bolje od ovog: ( odgledati u 720p )
Na ovoj kameri ?? Mislim da je daleko bolji od bilo kog divx-a.
  • Ministar za Enduro, ratluk i ženske motore, 5395 postova
  • Motocikl: HTZ 750
Trese se ako je nakačiš na motor, ako je na kacigi uopšte nije toliko strašno... osim što ima oštar ugao snimanja pa se bar meni često desi da slikam cajgere umesto put ispred... čak mogu da dodam da je i splašpruf što je ovaj snimak dokazao
  • Lokacija: Zemun
  • Motocikl: GW
Postoji nesto sto se ne meri kilobitima u sekundi a zove se ostrina optike, kvalitet cipa i procesiranja.
Na ovoj kameri to je dno, a kada je to u pitanju nece ti pomoci rate bluray diska.
Znam care... Neidem da snimam novog Avatara, tako da je kvalitet slike sasvim zadovoljavajuci. Koliko para toliko muzike...
  • Integrisan, 13835 postova
  • Lokacija: Buda/Szigliget
  • Motocikl: CB 360 / . SV 650 / GSXR600(ukraden) / GSX-R 750
Ovaj Techmoan koji je radio review za ovu novu verziju "11" je ozbiljan lik. Idite na njegov site, uglavnom razvaljuje (verbalno) proizvode koje testira. James May mu je "posudio" glas za ove videe. To je jedan od trojice iz Top Gear-a.
Da se vratim na ovi kameru. Ima nekoliko verzija koje se isto zovu i izgledaju samo je neka extenzijica drugačija. Ova testirana u prvom postu je odlična, u jednom momentu pušta uporedo napravljene snimke sa novom i prethodnom kamerom - dupe i oko. Mislim da to nisu te za 1500 sa Limunda.
Napominjem, isto se zovu i isto izgledaju.
Stigla mi je kamera pre dve nedelje ali tek sad sam je testirao.
Nosac kamere sam uradio od starog GPS nosaca i kamera je stavljena na rezervoar. Skuckao sam nosac za pola sata i vidim da cu morati drugacije da ga uradim poshto se puno vibracija prenosi na kameru. Nekako cu morati da stavim neku gumu ili sundjer izmedju kamere i nosaca... Ali shta ja znam za ove pare kamera ima solidnu sliku...
Probao sam da je stavim i u kacigu ali nemogu dobro da je namestim - uvek je ukrivo ili gleda previsoko ili prenisko...
Evo ga i prvi test snimak:
:zdravo:
  • Strucnjak, 1693 postova
  • Lokacija: Novi Sad - Šabac
  • Motocikl: CRF300L, Versys650
cini mi se da vizir dosta kvari sliku. mozda da probas da montiras pored vizira? mada to ce unistiti zvuk potpuno.. ako te ne mrzi molim te probaj. Da li se mogu videti tablice nekog automobila na 30-ak metara udaljenosti na snimku?
Vizir mi je veoma izgreban shto se vidi i na snimku pa dosta kvari sliku. A negde pored da montiram pa neznam... Onda bi bilo najbolje da montiram na vrh kacige poshto tu ima najmanje vibracija i kamera bi gledala direkno a ne preko vizira...
Tablice sa 30 metara nema sanse da se procitaju... Jedino ako bi vozio iza automobila na nekih 5 metara onda mozda i moze da se procita...
  • U prolazu, 21 postova
  • Motocikl: Honda CX 500 E ,"83g.
Danas naletim u radnji ,sasvim slucajno , na jednu HD 720p kamericu , Praktica 5000 WP za 6490,oo RSD .U nju idu 2 x AAA bat. iz trafike i SD HC mem.kart,
do 16 GB (pozeljno je klase 6).Dosta lose je na forumima ocenjena za foto ali za video u 720p u 30flaps je dobila dobre ocene .
Ostaje da napravim odgovarajuci drzac na motoru ,pa da vidim kakav video pravi ,ova low budget vodootporna kamerica .
post-14648-0-10955500-1313868854_thumb.jpg post-14648-0-63534500-1313869056_thumb.jpg
Metodom pipanja ,dosao sam do najboljeg mesta za postavljanje HD 720p kamerice .To je nosac retrovizora ,na mestu gde se srafi za rucku ,tako da kamerica zauzima mesto izmedju levog retrov. i satova .
Prva zamisao je bila bocni krash bar ,ali vibracije su takve da bi ,verovatno ,ispao objektiv posle 15min. voznje.
Po sistemu 'uradi sam' upotrebio sam nosac sedista od bicikla ,8mm torban vijak ,3mm flah ,malo gume i crni sprej . Ovde je veoma vazno da nema dodira medju metalnim delovima ,ni u jednoj tacki , kao i izmedju kamerice i nosaca gde se pricvrscuje orig.vijkom sa starog tripod-stalka .
post-14648-0-70383000-1315040604_thumb.jpgpost-14648-0-05873100-1315040659_thumb.jpgpost-14648-0-68802700-1315040703_thumb.jpgpost-14648-0-12827300-1315040736_thumb.jpg
U toku ovog vikenda ,postavicu kamericu i uraditi probni video u rez.1280x720 sa 30flp.
Praktica je pokazala da pravi dosta lose slike pri slaboj dnevnoj svetlosti i sa blicem ,koji dobaci do 1,5m .Medjutim , na dnevnoj svetlosti ,slike su odlicne ,ostre sa jasnim bojama .Nema opticki zum ,samo softverski , i 'hvata' siroki kadar . Imam problem sa racunarom ,radi ko da vuce plug za sobom ,tako da za sada ne mogu da obradim video .To bi trebalo da se promeni naredne nedelje ,kada stize upgrade za racunar .
  • Zainteresovan, 904 postova
  • Lokacija: Šumadija-Pašaluk
  • Motocikl: SUZUKI V- STROM
Imam neki kineski, univerzalni držač mobilnog tel. Pokušaču da ga namontiram na retrovizor jer je to jedini ugao gde se vidi put ispred. Nokia od 5mpx i gotovo. Meni treba iz bezbednosnih razloga.... >MOntirao sam ali je spadao držač jer je predviđen za korman ne retrovitor..... <_<
  • Elbow dragger, 2405 postova
  • Motocikl: CBR 1KRR Luna Nera / BMW S1KRR Lexa
gde ima da se uzme i koliko evropljana?
u sluchaju nezgode da li se takav snimak mozhe iskoristiti?
da li se sechenje i te slichne stvari koje rade 4tochkashi mogu nekako snimkom krivichno voditi? tipa da me kreten iseche i iscima ko budalu a ja ga prijavim muriji za nasilnichku vozhnju..
  • Călător motocicleta, 2361 postova
  • Lokacija: Novi Sad / Mlecni Put
  • Motocikl: Bez... jednog dana ponovo :)
Evo jedna mala novost. Nije skupo a radi pristojno. Testirano na preko 200km planinskih puteva, fin snimak,... nije savrseno ali je skroz OK
http://blueberry-eu.com/main.php?action=filter&group=prod&producer=camera&subgroup=hdcam
Ja sam sad kroz Rumuniju snimao dosta... montirano vakuum nosacem na vizir Varadera. Cepka film na 5 minuta ali ne pravi pauze izmedju fajlova tako da se nekim softverom mogu snimci spojiti u jedan film. Baterija traje oko 2.5 sata, 1sat snimka je oko 4GB
Neznam kako je mogu reklamirati kao HD kameru kad to nije... postoji samo HD 720 ( 1280x720 ) i HD 1080 ( 1920x1080 )...
  • Drug član, 1050 postova
  • Lokacija: BGD, Serbia
  • Motocikl: CBR600RR , CBR600F , Burgman400
sve je to bulja al za male pare 5 puta montirash dok ne namestish da snima gde ocesh ... najbolje a najjeftinije reshenje je digitalac jeste velik ali ima i shraf za montazu i lako se moze napraviti nosach .... ja imam md80 i za 10$ sam zadovoljan ali smara montaza , prvih 10 snimaka su mi neupotrebljivi jer neznam gde snima dok ne skinem snimak ...
