Koje ulje sipate u vas motor?
  • Drug član, 4503 postova
Ma ja sam se ponovio, prodao sam TDM, sad vozim Vstrom 1000 2014. god, sipao Shell 10W-40 i ne prija mu ni malo.
Sent from my SM-A705FN using Tapatalk
Suzuki ecstar
  • Zainteresovan, 429 postova
  • Lokacija: Ša/NS
  • Motocikl: F800ST
On 12.7.2022. at 18:09, N.F.S. je napisao:
Modricu bih rado vozio (i vozio sam!) ali je nemaju ni na "Nestro" pumpama, za Srbiju da ne pisem...
Da li Modrica ima MA2 standard?
Na njihovom sajtu ne pise taj podatak.
Ps: zastupnici Modrica ulja u Srbiji ima vise, dva su iz KG
https://modricaoil.com/Content/Read/srbija?lang=sr-Latn-RS
  • Integrisan, 10661 postova
  • Lokacija: Kragujevac
  • Motocikl: ---Honda---
Ne secam se koji standard ispunjava, ima kroz teme u nazad, postavljao sam slike...
A ti "zastupnici"... Smejurija!
Kao da sam u apoteci trazio tubeles ventil, bukvalno.
  • Svrati ponekad, 342 postova
  • Lokacija: Novi Beograd
  • Motocikl: Suzuki Bandit GSF 650; BMW F800 GT
Uzeh 3L po 1330din.
Gde si ga našao po toj ceni?
Poslato sa MAR-LX1A pomoću Tapatoka
  • Ne silazi, 3690 postova
  • Motocikl: Džies
pre 23 minuta, KoleD je napisao:
Sredom na pumpi u KGu 30% popust.
A danas je........
Promenio član shoyyka
O ovom mannolu sam pricao, 630din/l, uslikao sam upravo bocu/oznaku..
Ovo kaze proizvodjac.
"Mannol modern high-performance motor oil with high-quality ester components for the highest demands in racing and on the road in all common 4-stroke motorbikes, such as sports bikes, pit bikes, Enduro and trial motorcycles. During its development, special attention was paid to the specific requirements of motorcycles in daily use with frequent cold starts and high operating temperatures. Offers optimal cold start properties, highest resistance at high temperatures and highest shear stability. Ideal for models with injection engine and catalytic converter. Complies with the following approvals / specifications / products: SAE 10W-40 API SL JASO MA/MA2 Kawasaki Yamaha Suzuki Honda HUSABERG."
  • Ne silazi, 5270 postova
Одлично уље али код нас ништа више за моторцикле од двотактола.
Sent from my SM-N960F using Tapatalk
  • U prolazu, 49 postova
  • Motocikl: NC750D
Drugari,
nisam uspeo da pronađem noviju temu koje ulje za podmazivanje lanca (sistem) umesto Scottoiela koga nema, barem u BGD. Ako neko ima ili zna gde može da se uzme,javi na PP ili ovde.
Šta predlažete da je dobro a da ne usere ceo motor, točak i štitnik za lanac. Ulje za testeru mi se čini BAS retko.
Sent from my SM-G981B using Tapatalk
  • Drug član, 1460 postova
  • Lokacija: Kikinda
Pa scott isprska sve zivo, meni je motor ceo podmazan od njegac:neznam: Nema nigde u Srbiji da se kupi, ja sam porucio preko e bay iz Nemacke. Ako imas nekog da ti donese to ti je onda premija. Mada ja sam moj iskljucio i podmazujem klasicno, ocistim lanac i sprej, sat vrm jednom nedeljno mogu da odvojim.
Promenio član Zarkela
  • Ne silazi, 3729 postova
  • Lokacija: NS
  • Motocikl: Versys 1000 Kiklop aka Belka, Sym ST200 aka Robb
Scott kad je dobro podešen i namešten da baca gde treba na lančaniku baci par kapi na felnu... Nešto ti tu nisi namestio kako treba. Veruj mi, 5 godina imao Scott na VFR, nema bolje i čistije.
Sprej je zlo zla.
  • Drug član, 1717 postova
  • Motocikl: Suzuki DL 1000 2014
Stiglo Scottoiler ulje u prodavnice
  • Lokacija: Ša/NS
  • Motocikl: F800ST
On 27.7.2022. at 9:17, N.F.S. je napisao:
Sljivakovic doo iz Valjeva mi je jedini odg na mail da ima Mototaktol po 450din/L
  • Hvala 1
  • Drug član, 919 postova
  • Lokacija: NBGD 63 / STALSK-12
  • Motocikl: BMW S1000XR - 2016
On 13.7.2022. at 20:10, Savan je napisao:
Suzuki ecstar
Ovo bih probao pri sledećoj zameni ulja, valja li? Ako ne, biće Motul 7100, svakako me Shell po ceni od 1.900 RSD ne zanima...
On 29.7.2022. at 19:55, N.F.S. je napisao:
Први пут чујем за уље и за оно мало што претражих имали су неки проблем прошле године у Британији са уљем за аутомобиле које су тврдили да испуњава неке норме, али изгледа нису могли да докажу.  Мало као колеге из Волфсбурга.... или пак не. :)
WWW.LUBESNGREASES.COM
A watchdog of the United Kingdom’s lubricant market has lodged a complaint against a German marketer, contending that it promoted one of its engine oils as meeting mutually...
  • Motocikl: NC750D
stiglo u ML, danas uzeo crveno. skuplje ali jbng c.a. 2.4 rsd 0.5l ... dok je preko oko 1.2k rsd za 0.5l
  • Integrisan, 8462 postova
  • Lokacija: Smederevo
  • Motocikl: TDM 900
Pređite ljudi na Cobrru. Scottoiler više nije isplativ zbog cene ulja.
U Cobrru ide SAE 80W90, kupio neko u traktorskoj radnji za 600 dinara litar i traje koliko hoćeš.
Ima sad i zeleno all season da se kupi
  • Zainteresovan, 523 postova
  • Lokacija: Aleksandrovac
  • Motocikl: Honda CBF600SA
Prosli put sam u skuterce sipao Eneos 10W40, sad ga nije bilo pa uzeo Ipone 10W40.
Manual kaze da je interval zamene 4k km. Ne ide ni litar u motor (Honda Pantheon 125). Ja msm da je 1500-2000 km ok. Preko toga ne bih isao...
  • Lokacija: NS
Po meni je 2000km za litar ulja i bez filtera ulja taman....
  • Sviđa mi se 3
  • Drug član, 411 postova
  • Motocikl: Ex GSX-750R
U subotu u prodavnici auto delova, cujem za Pantherol ulje.
Navodno nemacko. Covek kupio ispred mene 5L oko 4 hiljade i nesto.
Jel neko cuo za tu marku?
Нема програм за моторцикле.
