acim 770 Napisano Jun 1, 2011 Ne silazi, 5817 postova Lokacija: Minhen Motocikl: Kawasaki H2 SX SE '23 / Triumph R3 Storm R '24 Prijavi odgovor kao problematičan Evo novog hita za mlade bajkere, prvi četvorotaktni motocikl od 125 kubika iz Aprilije. Tu je i manji brat od 50 kubika koji takođe liči na RSV4, ali i dalje ima 2T agregat. Aprilia RS4 50 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
mare gsxr750 46 Napisano Jun 1, 2011 U prolazu, 74 postova Lokacija: Beograd Motocikl: Suzuki GSXR-750 k8 & Cpi popcorn 50 Prijavi odgovor kao problematičan cek cek, prestaju da proizvode rs? Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
acim 770 Napisano Jun 1, 2011 Ne silazi, 5817 postova Lokacija: Minhen Motocikl: Kawasaki H2 SX SE '23 / Triumph R3 Storm R '24 Prijavi odgovor kao problematičan Aprilia RS4 50 - Tehnička specifikacija Engine type Single-cylinder, two stroke, carburettor, liquid cooled. Bore and stroke 39.86 x 40 mm Engine capacity 49.9cc Compression ratio 11.5 :1 Ignition Electronic with CDI capacity discharge Start up Electric Lubrication Automatic mixer Gearbox 6 Ratios, 1st 11/34, 2nd 15/30, 3rd 18/27, 4th 20/24, 5th 22/23, 6th 23/22 Primary drive Gears, 21/78 Final drive Chain, 11/53 Clutch Multiplate wet clutch Frame Twin spar aluminium frame Front suspension 41 mm upside down fork, wheel travel 110 mm Rear suspension Asymmetric swingarm with monoshock, wheel travel 130 mm Brakes Front: 300 mm stainless steel disc with radial 4 piston calliper Rear: 218 mm stainless steel disc and calliper with single 30 mm piston Wheel rims In light alloy with 6 split spokes, with sealing profile for tubeless tyres; front: 2.75 x 17″; rear: 3.50 x 17″ Tyres Front: 100/80 - 17″, rear: 130/70 - 17″ Dimensions Max. Length 1953 mm Max width 740 mm Max height at top fairing 1,138 mm Saddle height 820 mm Wheelbase 1,350 mm Fuel tank capacity 14.5 litres (including 3.5 litre reserve) Emissions compliance Euro 2 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Alekre 16381 Napisano Jun 1, 2011 Integrisan, 8384 postova Lokacija: Smederevo Motocikl: TDM 900 Prijavi odgovor kao problematičan Tehnicki i kozmeticki bez premca u klasi ali je RS 125 bila itekako ozbiljna masina za razliku od ovog 4T. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
acim 770 Napisano Jun 1, 2011 Ne silazi, 5817 postova Lokacija: Minhen Motocikl: Kawasaki H2 SX SE '23 / Triumph R3 Storm R '24 Prijavi odgovor kao problematičan Aprilia RS4 125 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
acim 770 Napisano Jun 1, 2011 Ne silazi, 5817 postova Lokacija: Minhen Motocikl: Kawasaki H2 SX SE '23 / Triumph R3 Storm R '24 Prijavi odgovor kao problematičan Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
RadicM 1077 Napisano Jun 1, 2011 Hard Enduro, 1532 postova Lokacija: Beograd Motocikl: Honda Africa Twin 750 '01, Honda Dominator 650 '01 bili nekad Suzuki TS 125 R i Tomos ATX 01' Prijavi odgovor kao problematičan Sta dozivesmo da su ugasili RS 125 zadnji trkacki 125 2t motor. Ovaj 50 je i dalje 2t ali je auspuh ruzan za sve pare lici na tomosov od BT... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
acim 770 Napisano Jun 1, 2011 Ne silazi, 5817 postova Lokacija: Minhen Motocikl: Kawasaki H2 SX SE '23 / Triumph R3 Storm R '24 Prijavi odgovor kao problematičan Aprilia RS4 125 - Tehnička specifikacija Engine type Four stroke liquid cooled single cylinder with electronic injection and 4 valves. Timing system Double overhead camshaft - DOHC Bore and stroke 58 X 47 mm Engine capacity 124.8 cc Compression ratio 12.5 ± 0.5:1 Ignition Electronic with CDI capacity discharge Start up Electric Lubrication Wet sump Gearbox 6 Ratios, 1st 11/33 (0.33) 2nd 15/30 (0.50) 3rd 18/27 (0.67) 4th 20/24 (0.83) 5th 25/27 (0.92) 6th 23/22 (1.05) Primary drive Gears, 69/29 Final drive Chain, 60/13 Clutch Multiple discs, in oil bath Frame Aluminium perimeter frame Front suspension 41 mm upside down fork, wheel excursion 110 mm Rear suspension Asymmetric swingarm with monoshock, wheel travel 130 mm Brakes Front: 300 mm stainless steel disc with radial 4 piston calliper Rear: 218 mm stainless steel disc and calliper with single 30 mm piston Wheel rims In light alloy with 6 split spokes, with sealing profile for tubeless tyres; front: 2.75 x 17″; rear: 3.50 x 17″ Tyres Front: 100/80 - 17″, rear: 130/70 - 17″ Dimensions Max. Length 1953 mm Max width 740 mm Max height at top fairing 1,138 mm Saddle height 820 mm Wheelbase 1,350 mm Fuel tank capacity 14.5 litres (including 3.5 litre reserve) Emissions compliance Euro 3 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
acim 770 Napisano Jun 1, 2011 Ne silazi, 5817 postova Lokacija: Minhen Motocikl: Kawasaki H2 SX SE '23 / Triumph R3 Storm R '24 Prijavi odgovor kao problematičan Ukratko o oba motora: RS4 50 - 50cc 2 stroke single-cylinder engine, liquid cooled with six speed transmission RS4 125 - 125cc 4 stroke, single-cylinder electronic injection engine, liquid cooled, 4 valves, dual overhead cam (DOHC) with six speed transmission RS4 125 - Aprilia Quick Shift system available, the sophisticated technical solution derived directly from its big sister, the RSV4 APRC stiff aluminium perimeter frame derived from racing experience 41 mm upside down fork front brake with 300 mm disc and radial four piston calliper Superbike inspired analogue/digital instrument panel fairings derived directly from the RSV4 for total aesthetic coherence with the SBK world champion LED taillight Evo i jednog videa: Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
acim 770 Napisano Jun 1, 2011 Ne silazi, 5817 postova Lokacija: Minhen Motocikl: Kawasaki H2 SX SE '23 / Triumph R3 Storm R '24 Prijavi odgovor kao problematičan cek cek, prestaju da proizvode rs? Sta dozivesmo da su ugasili RS 125 Nigde nisam pročitao da je Aprilija to najavila, ali me ne bi čudilo, odnosno gotovo je sigurno da će se to dogoditi narednih godina jer interesovanje za 2T mašina opada (zagađenje okoline, ukidanje klase 125 u MotoGP-u, itd). Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Skyrunner 5643 Napisano Jun 2, 2011 Drug član, 1960 postova Lokacija: Beograd Prijavi odgovor kao problematičan Sve u svemu jedan korak unazad Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
freepartyman 420 Napisano Jun 2, 2011 Svrati ponekad, 212 postova Lokacija: Beograd-Cerak,Banovo brdo Motocikl: Yamaha R6 Prijavi odgovor kao problematičan Meni je motor prelep. Sigurno ce izgubiti na brzini, a dobiti na dizajnu. Mislim da ce i dalje proizvoditi rs 125 zbog trka. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
mare gsxr750 46 Napisano Jun 9, 2011 U prolazu, 74 postova Lokacija: Beograd Motocikl: Suzuki GSXR-750 k8 & Cpi popcorn 50 Prijavi odgovor kao problematičan bio sam danas u salonu aprilie, vozio ortaka da pogleda 125ice, video sam i rs i rsv prelepi su, pito sam lika koji radi tamo, oce ukidate rs, on mi odgovorio za sada nece mada nista se ne zna Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
