srbenda 521 Napisano Januar 19, 2023 (promenjeno) Zainteresovan, 532 postova Motocikl: TOMOS Prijavi odgovor kao problematičan Narucio i stigle mi kapice i monitor za moj Piaggio MP3 . Medjutim posto moj skuter ima 3 tocka morao sam kupiti set od 4 ventila.Problem je nastao kada su GENIJALCI OD KONSTRUKTORA u Piaggio resili da na zadnjem tocku izmeste ventil,n mnogo ali sasvim dovoljno da , kada se zavrne i osigura sama kapica ovog ventila ono zakacinje po nekom nosacu . Takodje sam verovali ili ne a nemam razloga da izmisljam .IZGUBIO ZA OVIH 7 DANA od kako mi je i stigao set...1 ventil !!! Prekopao sam i auto i radionicu i ne mogu ga nigde naci.Sto ne znaci da ako se nekada i pojavi da ga necu naknadno poslati naravno o mom trosku U svakom slucaju za montazu imate 2 ventila i 1kao rezerva, za nedaj Boze ako se izgubi ili osteti Snimak kako radi i kako se montira sam skinuo sa Youtube..... neke od specifikacija poed alarma za nizak pritisak i.t.d. Tire pressure monitoring systems are used to increase the length of driving, reduce extra oil reduction from insufficient tire pressure and extend the working life of tires. Multiple tire pressure units are available, long receiving distance, stable signal, support tire position interchange. Air pressure setting range: 0.1~6.0BATemperature setting range: 60℃~110℃Working temperature: -20℃~80℃Storage temperature: -30℃~85℃Power-on voltage: DC 5VFrequency: 433.92MHz±20.00MHZ. Portable installation, long-lasting battery life, beautiful appearance. Real-time monitoring keeps you and your car away from risks. Excessive or low tire pressure during driving, for any reason (such as foreign body piercing the tire, tire scratch...) If the tire leaks, the system will automatically alarm immediately, so as to ensure safe driving. CENA:1,400 dinara KONTAKT TELEFON/ 063-8129618 Zvonko Promenio Januar 19, 2023 član srbenda 1 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
dragan_alumiroi 877 Napisano Januar 20, 2023 Zainteresovan, 627 postova Lokacija: Novi Beograd Motocikl: CRF 1100 D Prijavi odgovor kao problematičan Kupujem, ako se neko nije već javio. Zovem malo kasnije. Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
tibor 608 Napisano Januar 20, 2023 Zainteresovan, 699 postova Lokacija: Temerin Motocikl: TDM 850, DKW RT175 Prijavi odgovor kao problematičan Nisam ni znao da ovo postoji Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
shoyyka 11930 Napisano Januar 20, 2023 Ne silazi, 3689 postova Lokacija: Arandjelovac-Darosava Motocikl: Džies Prijavi odgovor kao problematičan Korisno,ima ih... 1 1 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
shoyyka 11930 Napisano Januar 20, 2023 Ne silazi, 3689 postova Lokacija: Arandjelovac-Darosava Motocikl: Džies Prijavi odgovor kao problematičan Ima i manjih šipinga,ilustracije radi samo... Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Žaksi 9811 Napisano Januar 20, 2023 Ne silazi, 2429 postova Lokacija: Jagodina Motocikl: Suzuki Bandit 650SAL0 Prijavi odgovor kao problematičan Dobra stvarčica.Nego se nešto mislim,ako kupim,namontiram i odem kod N.F.S.-a na kafu,one nestadoše.Ali dolaze 4 kom znači dvaput kafa. 1 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
miketa 367 Napisano Januar 20, 2023 Zainteresovan, 468 postova Lokacija: beograd Motocikl: afrika Prijavi odgovor kao problematičan Jel ima ovo kod nas negde da se kupi Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
mick 5037 Napisano Januar 20, 2023 Drug član, 3094 postova Lokacija: Beograd Motocikl: TRK502X, SVT650X...VOGE DS900X Prijavi odgovor kao problematičan Drugar je montirao na motor, nije loša stvarčica čak i obaveštava ako se motor pokrene...bez dozvole I ja razmišljam da je pazarim... Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
miketa 367 Napisano Januar 20, 2023 Zainteresovan, 468 postova Lokacija: beograd Motocikl: afrika Prijavi odgovor kao problematičan Kakva je situacija ako pokisne Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
mick 5037 Napisano Januar 20, 2023 Drug član, 3094 postova Lokacija: Beograd Motocikl: TRK502X, SVT650X...VOGE DS900X Prijavi odgovor kao problematičan Heheh pa vrlo jednostavna...vodootporan je 1 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
srbenda 521 Napisano Januar 20, 2023 (promenjeno) Zainteresovan, 532 postova Motocikl: TOMOS Prijavi odgovor kao problematičan Da dam jos neku infomaciju....svaka ventil kapica se rasrafljuje i u njoj se nalazi po 1 dugmasta baterija pored 2 Alkalne koje se nalaze u samom displeju - jedinici Promenio Januar 20, 2023 član srbenda Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
vujo032 3047 Napisano Januar 20, 2023 Zainteresovan, 440 postova Lokacija: Čačak City Motocikl: Suzuki Gz 250 Marauder Prijavi odgovor kao problematičan Ja sam čuo da su ljidima, pri većim brzinama kidali ventile, one ukrasne svetleće kapice, što se zavrću na ventil pa sjaje u mraku. Unutra valjda ima samo dugmasta baterija i LEDioda, ali kako je na vrhu ventila, usled centrifugalne sile, nastaje belaj. Ne želim da me neko pogrešno protumači, da vam kvarim poslove i planove, ali eto možda nije zgoreg imati to u vidu. Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
mick 5037 Napisano Januar 20, 2023 Drug član, 3094 postova Lokacija: Beograd Motocikl: TRK502X, SVT650X...VOGE DS900X Prijavi odgovor kao problematičan Babske priče... Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
bdada 16996 Napisano Januar 20, 2023 moto merkat °°, 5033 postova Lokacija: Šid Motocikl: Yamaha TDM 3VD Prijavi odgovor kao problematičan pre 41 minuta, vujo032 je napisao: ali kako je na vrhu ventila, usled centrifugalne sile, nastaje belaj. Centrifugalna ga "nabija" u ventil a zbog male mase ne moze mu nista. Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
dragan_alumiroi 877 Napisano Januar 21, 2023 Zainteresovan, 627 postova Lokacija: Novi Beograd Motocikl: CRF 1100 D Prijavi odgovor kao problematičan Baš sam juče razmišljao o tome. Kod mene su ventili pod 90° Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
srbenda 521 Napisano Januar 21, 2023 Zainteresovan, 532 postova Motocikl: TOMOS Prijavi odgovor kao problematičan Prodan polukomplet Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
