Višak: ručke, 12 V...
  • Drug član, 1181 postova
  • Motocikl: Suzuki SV 650 N
1. 12 V utičnica.
Novo. Može za volan 22 mm i za veći, ima adaptere. Sa osiguračem. Vodootporan.
Cena 1000 din.
2. LSL ručke nove
Nove, guma-aluminijum,125 mm, otvorene, za 22 mm volan.
LSL Design Handlebar Grips
For 22mm-Handlebars, Pair
Elegant styling, intelligent functions: LSL grips made from a combination of aluminium and rubber reduce vibration, are grippy and give your cockpit an extra visual highlight. The aluminium sleeves are CNC-milled and anodised.
Suitable for 22 mm handlebars, length 12.5 cm, with open handlebar ends. Plastic end caps are included.
Cena 35 eura.
3. Univerzalna cev za gas kako gugl prevodi
Novo.
Universal Throttle Tube
For 22mm Handlebar, Black, (Set)
Universal throttle tube for 22 mm handlebar
Whether you're fitting new grips or simply replacing a defective throttle tube, this sturdy throttle tube, made of impact-resistant plastic and with three interchangeable throttle cable cams, will fit the control housing of very many motorcycle models.
As this is a universal item, you should check the dimensions of your original throttle tube with those given in our installation instructions. There you will also find all other important information.
  • Sold individually with 3 adapters
  • Material: Plastic
  • Overall length: approx. 125 mm
  • Length up to the adapter: approx. 110 mm
  • Outside diameter: approx. 25 mm
Cena 1000 din.
4. Kišne pantalone danke Doichland
Nove. Treća slika je bez blica. Mogu se oblačiti sa strane, imaju rajfešlus.
Cena 1200 din.
  • Svrati ponekad, 246 postova
  • Motocikl: Yamaha XJ600 Diversion
Kupio bih uticnicu ali ne bih mogao da je preuzmem pre subote-nedelje.Malo sam posvadjan sa slobodnim vremenom...
PUIG ANGLED VALVE STEMS
11.3 MM VALVE HOLE, SILVER
If your motorcycle has rather large brake discs, you'll know what a fiddly job it can be to check your tyre pressures at the service station. Not any more! Puig angled valve stems for motorcycle tyres give far better accessibility.
The special shape makes checking your tyre pressures a piece of cake. What's more, angled valve stems prevent air escaping from the tyre due to the enormous centrifugal forces. They integrate perfectly with the wheel rim, brake disc and tyre.
High-quality materials plus special treatment and machining make Puig angled valve stems an extra safety feature for your motorcycle.
Available for rims with 11.3 mm valve hole (compatible with all standard rims + Honda, Kawasaki, Suzuki, Yamaha). EPDM rubber seal - temperature-resistant from -30°C to 120°C. Including sealed metal cap.
Available in black, silver and red. Sold in pairs.
Very important:
Puig angled valve stems must be inserted in the wheel rim, which necessitates removing the tyre from the rim.
Torque for mounting: 8 Nm!
Pošto vidim zbunjenog smajlija,ovako:
Platio sam skuplje, prodajem jeftinije ( ispod realne cene, znači na gubitku sam ) i te označene moje cene nisu fiksne :)
  • Zbunjen 3
  • Tužan 3
Pošto se neko sprda očigledno sa smajlijima, dosadno vam, šta li, tema se zaključava. Poruke, telefon, KP...
  • Haha 1
  • Zbunjen 2
Ostalo:
2. LSL rucke
3. Univerzalna za gas
5. Puig ventili
6. FLM pantalone, 52 produženi iliti 102, bez tragova korišćenja, ko nove skroz, sa protektorima na kolenima a bez zimskog uloška, lufteri, nogavice mogu patentom da se suze da bidne rejsing :) 4500 din
Tel 0637005870
Cena u Polo je 230 eura :)
Pantalone nisu nošene, samo probane. Pošto nedostaje zimski uložak, cena je 8000 din.
Malo sam zgrešio sa cenom gore u postu.
  • Stretch inserts and pre-curved knees
  • long zips at the leg end for easy entry
  • Knee protectors (EN 1621-1)
  • Protector for hip can be retrofitted
FLM Sports Textile Trousers 2.0
The pants for sporty touring - power to wear.
Comfort & Equipment:
  • Original 500D Invista Cordura®
  • waterproof, windproof, breathable SympaTex® membrane
  • MVS-1 membrane ventilation system
  • reflective strips
  • short and long connection zipper to jackets
  • Non-slip material in the seating area
  • removable thermostatic chuck
  • Quality seam according to DIN ISO 4916
Protectors:
Material:
  • Outer shell: 100% polyamide
  • Lining: 100% polyester
2. LSL ručke- 35 eura
3. Univerzalna cev - 1000 din
5. Puig ventili - 2700 din
6. FLM pantalone - 7000 din
8. Nike air pantalone vel XL ( Nove ) - 3600 din
Piše i za koju je visinu, meni velike na 183cm-85 kg
On 16.12.2018. at 15:53, gox je napisao:
5. Puig ventili - 2500 din ( rezervisano)
6. FLM pantalone - 6500 din
7. Crane pantalone nove vel L- 2000 din
8. Nike air pantalone nove vel XL- 3500 din
6. FLM pantalone - 6300 din
7. Crane pantalone nove vel L- 1800 din
