589 -
Sve što je postavio član: zogu
Haslamov suzuki sporiji 10,9 km od Guintolievog???? Ili bolje receno Haslam ga ne vozi do kraja po pravcu, ali opet dosta velika razlika.
Potpuno si u pravu. Voditelji sa eurosporta bas otvoreno navijaju za BMW, a cini mi se i da citaju ovaj forum po nekim izrazima pa evo im jedan link:
Voleli ili ne voleli Maxa, ovu trku je odvezao savrseno. Calmier isto odlican, zna se koji je najbolji motor
Do oo, taman sam pomislio nije valjda da kopiraju BMW, kad ono ono
I ja sam pomislio, da probaju Spiesa i odma na 3. mesto???? Ali ipak sumnjam, ako su malo i unapredili motor da je bas isti kao fabricki. Sefe Spdzilla, sta mislis?
Evo nasao sam o tom arm-pumpu, ne znam ni sta je to, ali koliko kapiram kada ti je ruka previse stegnuta stitnicima pa utrne (efekat slican VEP-u :) ), molio bih strucnije da objasne: Stoner unconcerned by arm pump issue By Simon Strang and David Emmett Sunday, June 20th 2010, 16:36 GMT Casey Stoner is confident that he will not suffer a recurrence of the arm pump that afflicted him in Sunday's British MotoGP when the championship reconvenes in Holland next Thursday. The Australian, who battled to fifth place after a poor start at Silverstone, admitted that he suffered from the condition on his right arm from the fifth lap of the race onwards. But the 24-year-old says he already knows what caused it and doesn't expect it to be a problem in the future. "I know what it is," he said. "It's basically the under-suit that I wore. I had three new ones for the weekend and they were tighter around the arms than they've been before. Big deal. We just found out after the race is all. "With this cool weather air blowing on your arm as well as them being under pressure a bit more than usual, it had an effect. It's a silly mistake and something I didn't think about. "I'll be fine to ride tomorrow. Arm pump is not like that. It was on my right side because there are a lot of right hand corners, and you are always picking it up to the left and it started getting sore." Stoner said he started feeling signs of the arm pump on Friday, and admitted it came as a surprise to him because he doesn't normally suffer from it. "All weekend I've been struggled with it, but it is the first time other than at Laguna Seca last year, when I was tired," he said. "I've never had it my life while road racing so I struggled around with it today." Izvor: http://www.autosport.com/news/report.php/id/84643
Odlicna trka, sazancemo u toku dana sta se stvarno desilo. Stoner je dokazao opet da moze, ali sta se sa njim desava....
Ako puca u auspuhu znaci da ima visak goriva, sto znaci karburator. Vodi samo racuna o nivou ulja, Gargi je u pravu da mozda benzin moze da udje u blok. To se desava kod Kawa sa 500ccm twinom (gpz, er, kle, en), ako se prepuni karburator gorivo kroz jedno crevo (iberlauf) ide direktno u blok, ne znam kako je pegazo resen. Dok sam imao KLE-a meni se to desilo, problem je bio u slavinici koja radi na principu vakuma pa je stalno pustala gorivo kao na polozaju otvoreno (KLE ima tri polozaja: normalno, rezerva i otvoreno za paljenje na niskim temperaturama, pusti se na otvoreno 10 sec i vrati na normalno). Sreca pa mi je drugar rekao da otkacim iberlauf iako je motor bio nov, pa osim prosutog rezervoara nisam imao nikakvu stetu. Dok je slavinica bila neispravna motor se ponasao apsolutno isto kao tvoj. Kako sam popravio? Kada je iscureo rezervoar ispred moje firme procistio je karburator, na pola puta do kuce (a bio sam ubedjen da ce morati slep) kada je istrosio sve viskove motor je potpuno normalno proradio. 99% karburator, jedno lepo ciscenje ili kit ako ima kod louis-a.
Malo smo spojili moto vesti i ovu temu....., nema veze svi citamo sve Cesto sam razmisljao da bi bilo gotivno da Rosi predje u slabiji tim i da pomogne pri razvoju sampionskog motora, svima bi to bilo jako zanimljivo (i njemu). Nazalosk Kawe nema u moto gp, ne znam da li ce se vracati, ali ga u Ducatiju nikako ne vidim zbog same politike tima gde je na vozacu samo da vozi, zato Rosi ni ranije nije hteo u Ducati. Oni su sad nesto poominjali da bi promenili taj odnos kada bi on dosao, ali cisto sumnjam. Najbolje bi bilo da Aprilia sledece godine udje u MotoGP sa Valentinom, onda bi prvi put navijao za njega Ovako pre verujem da ce ostati u Yamahi.
Nije ni Italijan nego svedjanin, a sada Nemac :) Ali nema veze, iz jevrope je.
Oznaka modela, to je onaj zadnji koji se pravio do 2007.
Mare, aj i ja da predlozim gume, uzmi Metzeler tourance i neces pogresiti: http://www.metzelermoto.com/web/catalog/moto/moto_catalogo_schedaDescription.page?uri=/metzeler/en_IT/browser/xml/catalog/moto/EnduroStreet_Tourance.xml&vehicleType=MOTO&menu_item=/products/catalog/enduro_street
Ima i jeftinih kofera, na primer za sprint prince, izgledaju vrhunski, a komad je valjda 1500 din (imaju 2-3 vrste). To ti je najbolje resenje. Jedini problem su nosaci, ako se dobro secam acapn ih radi za 50 eur.
Hvala na odgovoru, a saznace se to vrlo brzo. U svakom slucaju zao mi McCoya, ne moze on jos dugo vrhunski da vozi sa 38 godina koliko ih ima.
To sam i ja posle danasnje trke pomislio, ali ipak mislim da nece biti sporiji, samo je pitanje da li ce drugi biti brzi, ipak je lakse boriti se protiv lorenca nego protiv lorenca i rosija zajedno. A Lorenco jeste faca, spominjan je i Sumaher u ovoj temi, a ja sam prestao da gledam formulu posle Senine pogibije, svi su vozaci bili tuzni i u neverici, jedino se Sumaher smeskao i nije mogao da doceka nastavk trke... U MotoGP-u koliko vidim svi su pravi bajkeri i koliko god da se kidaju na stazi, van staze pokazuju da su pravi sportisti, da postuju jedni druge i samim tim zasluzuju mesto u timovima.
Spdzlla, povodom vesti iz druge teme da je Gary McCoy raskinuo ugovor sa FBcorse ekipom, da li ti to lici na popunjavanje upraznjenog mesta u nekom timu kada se Yamaha odluci ko ce da menja Rosija? Imas li neke pretpostavke posto pratis sve vesti pa mozes bolje da prognoziras od vecine nas? Pozzz.
@spd Bogami HRC krenuo da przi Meni se cini da nece biti nista manje zanimljivo bez Valea. Samo se pitam da li su vec danas proradili neki kojima se cini da je bez rosija lakse do titule.
Bice klanja i bez rosija, sada se mozda okuraze i neki koji su imali "strah od rosija" sto bi rekao jedan nas forumas. Rosi ima 31. godinu, steta sto jedan takav pad za koji kazete da je morao da se desi nije odradio ranije, ali i sada moze da bude na podijumu jos 3-4 sezone, pa jos koju u SBK ako bude imao volje, gledacemo mi njega jos dugo i navijati za ili protiv njega, samo neka se doktor sto pre oporavi.
Sumnjam da se bilo ko raduje.
Ne mogu ventili da prave debalans na fabricki balansiranima gumama, a balansiranje kod lesanovica je oko 500 din ako se ne varam, 1500 su mi uzeli za prednji tocak, skidanje, krpljenje, balansiranje, vracanje.
Na kraju ce da se ispostavi da je bio Srbin iz Obraza
Salim se, detaljan opis i vidi se da si zadovoljan sto znaci da sam te sa pravom ubedjivao da kupis keeway-a. A kocnicu prednju cemo da sredimo.
Djunta, pretera ga, zvucis kao Alvirovici kada testiraju Tojotu :)
Ocigledno su radili na Dukatiju i dobili su na svemu osim na pouzdanosti, sredice oni to.
1. Aprilia Max Biaggi 2. Aprilia Leon Camier Generalni plasman: 1. Max Biaggi 257 boda 2. Leon Haslam 242 boda Japanci ......
