Aprilia Tuareg
  • Prekidach, 1093 postova
  • Motocikl: Honda Africa Twin CRF1000L & Suzuki DR 650 SE
Woohooo
750cc agregat iz Dorsodura i Shivera spakovan na velike tochkove ;D ;D
According to a report on Motociclismo, the new Aprilia Tuareg adventure tourer will be unveiled at the EICMA Show in Milan this year. The bike will be fitted with a 750cc parallel-twin engine (the same unit that’s also used on the Shiver and the Dorsoduro), steel tube chassis and a 21-inch front wheel, which means the Tuareg 750 will be fully optimised for off-road use.
Later, Aprilia may also do a more street-oriented version of the Tuareg, which will be fitted with a 1,200cc engine and a 19-inch front wheel. With bikes like the Yamaha XT1200Z Super Ténéré and the new Ducati Multistrada 1200 having recently been launched and with Aprilia also joining the fray with the Tuareg 750/1200, it seems the BMW R1200GS is finally getting all the competition it ever wanted… :-)
admini, mrdzhujte ove dve: http://www.bjbikers.com/index.php?option=com_smf&Itemid=53&topic=51595.0
a bajk je sve shto ja zhelim u motoru... one mazge od (bmw i super tenera) 1200cc su samo za put... ovo je vec sposobno za mnogo vishe...
sad ce verovatno i honda da se javi... a mozhda i ktm opet napravi neki adv ispod 990... uff... :)
  • Enduraš, 6693 postova
  • Lokacija: Paracin
  • Motocikl: 450MT
Konacno nesto u klasi adventure, a da nije velika kubikaza, a nadam se ni tezina. Svidja mi se kako izgleda, jedino ovo sediste.... nikako mi ne ide uz taj tip motora. Samim pogledom na njega se vidi da je "pain in the ass" u pravom smislu te reci :)
  • ¡Siempre adelante!, 2188 postova
  • Lokacija: Kalifornija
  • Motocikl: BMW F650GS... Harley-Davidson Nightster
Konačno nešto što stvarno obećava.....i samo 5 komentara ???
Apdejt: Težina bi trebala da bude 202 kg. 8)  Agregat isti kao Shiver 750, što bi značilo V-2 sa 95 konja. 8)  Cena Shivera 750 ovde u SAD je $9.000, pa ako toliko bude koštao i ovaj Tuareg onda će razbiti konkurenciju. 8)
Možda je Aprilija napravila perfektan enduro... 8)
http://www.motorcycledaily.com/06april10_apriliadisplacement.htm
daj bozhe da bude ispod 10k €... ovo mi dodje kao mala tenera sa normalnim motorom... mada, ko zna... nisam nishta konkretno nashao po netu.. i svi furaju ovu jednu sliku... moracemo da chekamo jesen 2010 :(
  • Hard Enduro, 1532 postova
  • Motocikl: Honda Africa Twin 750 '01, Honda Dominator 650 '01 bili nekad Suzuki TS 125 R i Tomos ATX 01'
Konacno jedan pristojan enduro a da nije mrcina od preko 750ccm dace bog da se i drugi proizvodjaci opamete pa naprave ovako manje motorice.
el ovo Cagiva Elefant 750? nikada ga nisam video uzhivo... drugar je zagovornik teorije da je to odlichan motor...
Koliko vidim, pored migavca piše da se motor zove Magični Autobus. :)
  • U prolazu, 11 postova
  • Lokacija: Studenica
  • Motocikl: aprilia tuareg 350 wind
Woohooo
taman da zamenim ovog mog od tuarega 350 (jos kad bi moglo staro za novo :) )... Svidja i se koncept Paris Dakar motora za enduro voznju .
  • Drug član, 2265 postova
  • Lokacija: Stara Pazova
Nazalost, tezina mu i odgovara imenu.
Citiracu deo teksta sa jednog od linkova:
Aprilia has a potential winner coming if they get few things right - fuel economy, gas and luggage capacity and wind management - white keeping the bike lightweight.
U potpunosti se slazem sa njima. Model definitivno ima potencijal. :)
Dodacu samo jednu ispravku, ako sam dobro razumeo u pitanju je V-twin, a ne parallel twin kao sto pise u pocetnom tekstu.
  • Ne silazi, 6792 postova
  • Lokacija: Vrmdža, Sokobanja
  • Motocikl: konzerviran
Ima vec skoro nedelju dana kako sam uzeo novi Motociclismo,od obaveza i raznih drugih gluposti imadoh vremena samo na brzinu da ga prelistam.
Evo sta kazu u vezi sa novom Aprilijom.
Ova slika koju vidite na pocetku teme je rezultat igre novinara iz redakcije lista.
Istina je da je na pomolu novitet,ali da ce biti identican ovome na slici to ce se tek videti.Svaki proizvodjac svoje novitete ipak malo bolje cuva od radoznalih pogleda.
Prvo su "montirali" zadnju viljusku od modela koji je vozen na Dakaru.Onda su "zakacili" onu od Shivera,pa tek na kraju shvativsi da bi ove solucije bitno digle cenu,onu od Dorsoduro.
Ram ce umesto da bude odlivak,biti verovatno (tako je i na slici) tipa kavez od metalnih sipki.Tako kosta manje.
Kazu isto tako da je u pripremi i novi agregat.Evolucija postojeceg V2,sa 750 na 1200 ccm,koji ce prvobitno da bude montiran na novi Dorsoduro,a kasnije na model o kojem je ovde rec i vrlo verovatno da obogati segment maxi-enduro i da se ukljuci u borbu za deo trzista,protiv Yamahe,Ducatija,BMW-a...
Tekst je eto tako vise analiticki i pun teorija,ali prilicno zanimljiv i pun ilustracija.Tu su slike konkurencije,BMW F800GS,KTM 690Rally i starih slavnih modela,Cagiva Elefant 750,BMW R80GS,Afrika,Tenere...
