Arakis 6570 Napisano Decembar 30, 2008 Svakom po zasluzi, 12498 postova Lokacija: NBGD - KN04ET Motocikl: Honde Transalp, plavi i narandžasti, oba za dečake Prijavi odgovor kao problematičan Važni podaci o našim Transalpovima Service manual: http://www.filestube...Manual-ENG.html http://www.filestube...+service+manual http://www.manualede...Microfiche.html http://www.manualede...-1987-2002.html Uputstvo za razne prepravke https://docs.google....Vpld1V3VjA/edit Dimenzije ležajeva u točkovima: prednji su 6202, zadnji su 6203 i ležaj zupčanika je 6204. Dimenzije ležajeva upravljača: 26x47x15 mm, oba (prema www.wemoto.com) Svećice: NGK DPR8EA-9 Delovi za TA: http://www.hamart.at...Hand-Parts.html Termoprekidač ventilatora: odgovara od automobila Suzuki Maruti, cena oko 900 din Year of manufacture/VIN Year of manufacture: 1987-1993 VIN: PD06-3000002 to PD06-5200008 Capacities Fork oil per rod: 550 ML SAE 7,5W Engine oil w/o filter: 2,2 L SAE 10W-40 Engine oil incl. filter: 2,4 L API SE-SF Final drive lubricant: Brake fluid: DOT 4 Coolant: 2,0 LITER Fuel: 18,0 LITER Technical data Engine size: 583 ccm Cylinders: 2 hp/kW: 50/37 - 34/25 Valve clearance (intake): KALT 0,15 MM Valve clearance (exhaust): KALT 0,20 MM Engine idle speed: 1300 ± 100 U/MIN Carburettor air screw: 2,25 AUSDREHUNGEN Tyre pressure (front): 2,0 BAR Tyre pressure (rear): 2,0 BAR Spark plug 1: NGK DPR8EA-9 Spark plug 2: NGK DPR8EIX-9 Electrode gap: 0,9 MM Fork tube Ø: 41 MM TELEGABEL Front and rear sprockets: 15/47 ZÄHNE Chain/final drive: 118 GLIEDER Year of manufacture/VIN Year of manufacture: 1994-1996 VIN: Capacities Fork oil per rod: 550 ML SAE 7,5W Engine oil w/o filter: 2,2 L SAE 10W-40 Engine oil incl. filter: 2,4 L API SE-SG Final drive lubricant: Brake fluid: DOT 4 Coolant: 2,0 LITER Fuel: 18,0 LITER Technical data Engine size: 583 ccm Cylinders: 2 hp/kW: 50/37 - 34/25 Valve clearance (intake): KALT 0,13-0,17 MM Valve clearance (exhaust): KALT 0,18-0,22 MM Engine idle speed: 1300 ± 100 U/MIN Carburettor air screw: 1,75 AUSDREHUNGEN Tyre pressure (front): 2,0 BAR Tyre pressure (rear): 2,0 (2,3) BAR Spark plug 1: NGK DPR8EA-9 Spark plug 2: NGK DPR8EIX-9 Electrode gap: 0,9 MM Fork tube Ø: 41 MM TELEGABEL Front and rear sprockets: 15/47 ZÄHNE Chain/final drive: 118 GLIEDER Year of manufacture/VIN Year of manufacture: 1997-2000 VIN: ZDCPD10A*VF000001-G to ZDCPD10B*VF000001-2G Capacities Fork oil per rod: 550 ML SAE 10W Engine oil w/o filter: 2,2 L SAE 10W-40 Engine oil incl. filter: 2,4 L API SE-SG Final drive lubricant: Brake fluid: DOT 4 Coolant: 2,0 LITER Fuel: 18,0 LITER Technical data Engine size: 583 ccm Cylinders: 2 hp/kW: 50/37 - 34/25 Valve clearance (intake): KALT 0,13-0,17 MM Valve clearance (exhaust): KALT 0,18-0,22 MM Engine idle speed: 1300 ± 100 U/MIN Carburettor air screw: 2,25 AUSDREHUNGEN Tyre pressure (front): 2,0 BAR Tyre pressure (rear): 2,0 (2,25) BAR Spark plug 1: NGK DPR8EA-9 Spark plug 2: NGK DPR8EIX-9 Electrode gap: 0,9 MM Fork tube Ø: 41 MM TELEGABEL Front and rear sprockets: 15/47 ZÄHNE Chain/final drive: 118 GLIEDER Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Arakis 6570 Napisano Decembar 30, 2008 Svakom po zasluzi, 12498 postova Lokacija: NBGD - KN04ET Motocikl: Honde Transalp, plavi i narandžasti, oba za dečake Prijavi odgovor kao problematičan A vidi kako se čovek setio pa stavio normalne (kućne) halogene sijalice od 50W - spot na motor ;D 1 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
B@ne 307 Napisano Decembar 30, 2008 Drug član, 1520 postova Motocikl: KTM 990 Adventure, KTM Lc4 Adventure-R 640 Prijavi odgovor kao problematičan Arakis, da li je TO vodootporno, cena i gde TO ima ? Mislim gedžet . Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
thelord 100 Napisano Decembar 30, 2008 Stomatolog na motoru, 1522 postova Lokacija: NBGD Motocikl: Svartpilen 401 Prijavi odgovor kao problematičan Sad ce gospon Arakis da smisli kojekakve lepote pa ce da mu se napravi red ispred garaze Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Arakis 6570 Napisano Decembar 30, 2008 Svakom po zasluzi, 12498 postova Lokacija: NBGD - KN04ET Motocikl: Honde Transalp, plavi i narandžasti, oba za dečake Prijavi odgovor kao problematičan Arakis, da li je TO vodootporno, cena i gde TO ima ? Mislim gedžet . Ne znam druže, mislim da sam ga viđao na Bubanj potoku...za sad samo smišljam "pakosti" za naše motorine ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
thelord 100 Napisano Decembar 30, 2008 Stomatolog na motoru, 1522 postova Lokacija: NBGD Motocikl: Svartpilen 401 Prijavi odgovor kao problematičan Arakis, da li je TO vodootporno, cena i gde TO ima ? Mislim gedžet . Ne znam druže, mislim da sam ga viđao na Bubanj potoku...za sad samo smišljam "pakosti" za naše motorine ;D Drz se ti tih elektro lepota a za sva ostala razbucavanja naseg cenjenog motora se slobodno javi. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
joska 63 Napisano Decembar 30, 2008 I=U/R, 2061 postova Lokacija: Temerin Motocikl: Transalp `97 Prijavi odgovor kao problematičan Juce sam poceo da pisem program za jedan gadget.Imace LCD sa 2x16 karaktera,a prikazivace vreme,temperaturu vazduha,broj obrtaja motora,i temperaturu motora.Ovo ce biti montirano na hondu shadow,posto nema ni obrtomer,ni pokazivac temperature. Planiram i druge verzije,sve je stvar softvera Recimo meni za moj motor hocu da mi prikazuje napon akumulatora,vreme,i temperaturu vazduha. 1 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Arakis 6570 Napisano Decembar 30, 2008 Svakom po zasluzi, 12498 postova Lokacija: NBGD - KN04ET Motocikl: Honde Transalp, plavi i narandžasti, oba za dečake Prijavi odgovor kao problematičan Nije baš prvi post u temi ali ovde ću da stavljam, kao u kutijicu važne podatke o našim Transalpovima. Service manual: http://www.filestube...Manual-ENG.html http://www.filestube...+service+manual http://www.manualede...Microfiche.html http://www.manualede...-1987-2002.html Uputstvo za razne prepravke https://docs.google.com/file/d/0BwYQrJT16ogVN3NaNVpld1V3VjA/edit Dimenzije ležajeva u točkovima: Dimenzije ležajeva upravljača Svećice: NGK DPR8EA-9 Delovi za TA: http://www.hamart.at...Hand-Parts.html Termoprekidač ventilatora: odgovara od automobila Suzuki Maruti, cena oko 900 din Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
thelord 100 Napisano Decembar 30, 2008 Stomatolog na motoru, 1522 postova Lokacija: NBGD Motocikl: Svartpilen 401 Prijavi odgovor kao problematičan Recimo meni za moj motor hocu da mi prikazuje napon akumulatora,vreme,i temperaturu vazduha. Sve sto ti hoces za tvoj motor ni mom nece skoditi 1 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
joska 63 Napisano Decembar 30, 2008 I=U/R, 2061 postova Lokacija: Temerin Motocikl: Transalp `97 Prijavi odgovor kao problematičan Kada zavrsim projekat,postavicu ga ovde.A dotle dajte neke ideje,sta bi jos moglo da se nadje na display-u. (da skroluje berzanske izvestaje,i dnevni horoskop,kao i rezultate utakmica,nece moci ;D ) Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Arakis 6570 Napisano Decembar 30, 2008 Svakom po zasluzi, 12498 postova Lokacija: NBGD - KN04ET Motocikl: Honde Transalp, plavi i narandžasti, oba za dečake Prijavi odgovor kao problematičan Sat sa štopericom, voltmetar, spoljašnja temperatura vazduha sa ev. indikacijom moguće poledice...to bi mi odgovaralo A znam šta bi Bokiliću pasovalo: Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
bokilic 6107 Napisano Decembar 30, 2008 :), 5945 postova Lokacija: Nova Pazova! Motocikl: Bicikl Prijavi odgovor kao problematičan toooooooooooooooo,,, sam sto bi ja tu turio plin,,,hebes te cudne gasove sto motor poludi za badavaa.... 1 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
TA96 301 Napisano Decembar 30, 2008 Drug član, 1423 postova Lokacija: Bliski Istok-Pančevo Motocikl: Honda CRF300L Prijavi odgovor kao problematičan . Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
TA96 301 Napisano Decembar 30, 2008 Drug član, 1423 postova Lokacija: Bliski Istok-Pančevo Motocikl: Honda CRF300L Prijavi odgovor kao problematičan . 1 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Arakis 6570 Napisano Decembar 30, 2008 Svakom po zasluzi, 12498 postova Lokacija: NBGD - KN04ET Motocikl: Honde Transalp, plavi i narandžasti, oba za dečake Prijavi odgovor kao problematičan Senzori za to su malo zeznuti... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Dr.Bane 212 Napisano Decembar 30, 2008 Drug član, 1126 postova Lokacija: Ljubljana, Slovenija Motocikl: ex MV Agusta 800 Brutale Prijavi odgovor kao problematičan Trebalo bi ubaciti i neki merač pritiska za ove +40 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Arakis 6570 Napisano Decembar 30, 2008 Svakom po zasluzi, 12498 postova Lokacija: NBGD - KN04ET Motocikl: Honde Transalp, plavi i narandžasti, oba za dečake Prijavi odgovor kao problematičan ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
joska 63 Napisano Decembar 30, 2008 I=U/R, 2061 postova Lokacija: Temerin Motocikl: Transalp `97 Prijavi odgovor kao problematičan Trebalo bi ubaciti i neki merač pritiska za ove +40 Ne zaj...vaj! Ima nas vise! Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
revolution 52 Napisano Decembar 30, 2008 Drug član, 1261 postova Lokacija: Beograd Prijavi odgovor kao problematičan Trebalo bi ubaciti i neki merač pritiska za ove +40 Ne zaj...vaj! Ima nas vise! Vidiš to sa pritiskom nije loše, al' da metiš i nivo šećera i triglicerida ;D ;D ;D ;D ;D 1 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
lord_oblivion 1415 Napisano Decembar 31, 2008 Ne silazi, 6323 postova Lokacija: Meljak Motocikl: KLX250S efi klot, GV 2.0 ADV edition Prijavi odgovor kao problematičan Pozadinsko osvetljenje displeja sa senzorom noc/dan, brzinomer... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
KTM+A 559 Napisano Decembar 31, 2008 Drug član, 1359 postova Prijavi odgovor kao problematičan mozda da se ubaci i sati rada motora mislim kao kod croseva ako nekom treba i to . mada ako mozes da napravis da ima stopericu bilo bi dobro ba moze da pamti deset vremana zadnjih a pritom ono najvaznije da se aktivira svaki put kad prodje pored nekog senzora. ovo zadnje mislim bi bilo vise zanimljivo ako je izvodljivo. mada bimeni bilo zanimljivo da nam kazes kako ti to pravis da probamo i mi a ne da bacamo pare kupujuci nesto sto moze da se napravi . ;D ;D ;D ;D ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
bokilic 6107 Napisano Decembar 31, 2008 :), 5945 postova Lokacija: Nova Pazova! Motocikl: Bicikl Prijavi odgovor kao problematičan ma svima cu vama ja da cusnem plin,,pa da se vozite dzaba ;D ;D ;D :D :D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
KTM+A 559 Napisano Decembar 31, 2008 Drug član, 1359 postova Prijavi odgovor kao problematičan ma svima cu vama ja da cusnem plin,,pa da se vozite dzaba ;D ;D ;D :D :D jel moze i na 2t Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Brmbrm 118 Napisano Decembar 31, 2008 Brmbrm, 448 postova Lokacija: Beograd Motocikl: KTM Life Race Prijavi odgovor kao problematičan Joska, koliko bi bilo komplikovano da se ubaci merac kolicine goriva? Na TA ga nema, a zgodna je stvar kada si negde u zabiti gde nema pumpe na svakom cosku... :-\ P.S. onaj regler sto si ga napravio za Virago 535 za mog drugara odlicno radi... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
bokilic 6107 Napisano Decembar 31, 2008 :), 5945 postova Lokacija: Nova Pazova! Motocikl: Bicikl Prijavi odgovor kao problematičan ma svima cu vama ja da cusnem plin,,pa da se vozite dzaba ;D ;D ;D :D :D jel moze i na 2t naravno da da ;D ;D ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
