Motorcyclist
Sve što je postavio član: Motorcyclist
  1. Dobro je kako je to nekome ok, meni bi bilo nedopustivo. Valjda sto do sada nisam vozio motor koji se gasi sam od sebe.
  2. To fix the problem, KTM is rolling out an immediate ECU EMS software update across all affected models. Dealers will install the new software version, which not only reduces the chance of stalling but also improves low‑end torque and overall engine stability. Owners will start receiving official notices on January 23, 2026, and KTM has already locked affected bikes in dealer inventory until the update is applied. Riders who previously paid for ECU updates will be reimbursed, and KTM is advising owners not to ride their bikes until the fix is complete. Owners may contact KTM customer service at 1-888-985-6090. The manufacturer’s numbers for this recall are KTB2513 & HTB2508.
  3. ECU Software Issue Triggers Recall Across KTM’s 390/401 Line - ADV Pulse WWW.ADVPULSE.COM KTM North America has announced a recall of 6,546 motorcycles across its KTM and Husqvarna lineups due to an ECU engine management system software defect. The recall...
  4. I ja nisam skontao kada je napustio forum.
  5. Mogao bi neki zvucni zapis sa tim Mivvom?
  6. Procitao sam to na jednom forumu i nista nije u vezi njihovih motornih ulja. Kako god nek koristi ko sta hoce.
  7. Evo malopre neki na fejsu... Pita covek moze li nisov g12 u motor. Reko moze. Neki matori- SAMO MOTUL ANTIFRIZ .. Jaaooo majko sekte motul antifriz.
  8. Pa bas i ne gazim, saltam ono ispod 8000 a crveno je na 14.000, bas penzionerski vozim a prelazim malo godisnje.
  9. Ne fali niti jednom nista ako ispunjava specifikacije i menja se redovno.
  10. Nije, pise polusintetika. Ali ja u zivotu nisam sipao full sintetiku niti u jedan motor. Opet meni ta razlika u ceni znaci. 4x1200=4800din a 4l Mannola ispod 2000din. Menjam uje na manje od 5000km.
  11. Pa ne znam, ocigledno velik broj ljudi sipa zato sto je Motul... Ja bih pre uvek sipao Silkolene umesto njega. Davno smo pokojni painkiller i ja sipali Elf, nikakvih problema. Daleko da je Mannol neko najbolje ulje ali mi se pokazalo kao bolje ulje od duplo skupljih. @Blackened Gde ima taj Castrol po toj ceni?
  12. Probao sam davno neki Bardahl xtc, ipone neki ispod 1000 za litru, sranje. Trosilo,menjac uzas. Za onaj Motul 5100 koliko kosta svi kazu da je krs ulje. U USA ljudi sipaju ulja iz Wallmarta... Dokle god ispunjava specifikaciju ne brinem se. Pitanje je samo kako ce se pokazati u vasem konkretnom motoru sa potrosnjom, menjacem...
  13. Mislim da se ljudima najvise ne svidja cena i sto nije izvikano
  14. Samo zbog topa se mora mapa raditi?
  15. Super izgleda. Jos tako podignut gore. I sprint 1050 mi se svidja, pretpostavljam da su iste masine.
  16. Ovo bi mogao biti moj neki sledeci motor kada bih isao sa kubikazom na gore. Za taj novac deluje da nudi puno. Kada bih isao nize sa kubikazom 450mt i sacekati KLE 500.
  17. Da li ti je menjac ok, posto se nekoliko vozaca istog malo zalilo na menjac u odnosu na japance.
  18. Litar evrodizela danas od 15 sati do petka, 12. decembra u isto vreme koštaće maksimalno 198 dinar za litar, a cena benzina evropremijum BMB biće 181 dinar za litar. Prošle nedelje cena evrodizela iznosila je 201 dinara po litru, a benzina 181 dinara po litru. Ovo znači da je cena dizela jeftinija za tri dinara po litru, dok je cena benzina ostala ista, prenosi Danas. Podsećamo, Vlada Srbije donela je u julu uredbu kojom je produžena mera ograničenja cena goriva na još šest meseci. Najviša cena evrodizela sa PDV-om ograničena je na prosečnu veleprodajnu cenu uvećanu za 17 dinara. Isto toliko iznosi i maksimalna cena benzina evropremijum BMB 95.
  19. Cestitam. Pisi utiske i napisi na kraju zakljucak - koja ti konfiguracija najvise odgovara
  20. Za te pare neces naci Fazera i Horneta u takvom stanju.
  21. @aninana76 • Instagram reel WWW.INSTAGRAM.COM Epske zvezdice su se vraćale na RTS, kako bi se sjećale nekih stare epizoda koje su navikle publike...
  22. Ako se pokaze da dostize 50.000+ bez problema, definitivno bolja kupovina od dva japanca sto sam naveo. A i lepo izgleda.
  23. Koji model i koliko star?
  24. Tacno, to sam nekako zaboravio. Drze cenu. Imam osecaj da se kinezi novi kupuju al polovni bas i ne.
