Motor iz snova STRIKES BACK ! (... ili PEGAZ JE STIGAO ! )
  • U prolazu, 84 postova
  • Lokacija: Serbia
Hvala , Hvala , Hvala ...
Masina je udobna , lako se vozi (kao skuter), ma sve BEST ...
Probacu ga u OFF-ROAD pa vas obavestavam (mada mi je malo zao da ga prljam , al valja se)
A snage ihaaaa, momenta jos i vise ... kao Golf DCI :) sad mi je jasno zasto jedan cilindar? Zbog momenta ... JEDAN ALI VREDAN !( a i srce pocne da kuca po taktu ... BROM, BROM)
Predlozio bih da se iz imena foruma izbaci prvo slovo B ,
sobzirom na trendove :)
APRILIA PEGASO TRAIL 650
Engine
Single-cylinder four-stroke with light alloy cylinder. Liquid cooling with three way pressurised circuit. Single overhead cam with chain timing drive; four valves. Anti-vibration counter-shaft.
Fuel
Unleaded fuel.
Bore and stroke
100 x 84 mm.
Displacement
659 cc.
Compression ratio
10:1.
Max. power at crankshaft
50 HP (37 kW) at 6,250 rpm.
Max. torque at crankshaft
6.25 kgm ( 61.31 Nm) at 5,200 rpm.
Fuel system
Integrated electronic engine management system. Electronic fuel injection. 44 mm throttle body.
Ignition
Electronic.
Starting
Electric starter.
Alternator
290 W
Lubrication
Dry sump with oil pump.
Gearbox
5 speed. Transmission ratios:
1st 12/30
2nd 16/26
3rd 20/23
4th 22/20
5th 26/20
Clutch
Multiple disc in oil bath. Cable operated.
Primary drive
Spur gears.
Transmission ratio: 36/75.
Final drive
Chain.
Transmission ratio: 15/44.
Frame
Steel, open cradle, single spar frame.
Front suspension
45 mm fork.
Wheel travel 170 mm.
Rear suspension
High strength steel swingarm.
Aprilia Progressive System (APS) rising rate linkages.
Sachs hydraulic monoshock with adjustable rebound and preload.
Brakes
Front: Brembo stainless steel disc, 300 mm. Two-piston floating caliper.
Rear: Brembo stainless steel disc, 240 mm. Floating caliper.
Wheels
Aluminium spoked.
Front: 2.15 x 19"
Rear: 3.00 x 17"
Tyres
Front: 100/90-19
Rear: 130/80-17
Dimensions
Max. length: 2,232 mm
Max. width: 810 mm
Ground clearance: 270 mm
Seat height: 820 mm
Wheelbase: 1,515 mm
Tank
Capacity 16 litres, 3.5 litre reserve.
Accessories
Adjustable front brake lever; luggage rack; 28 and 45 litre top boxes; semi-rigid panniers in high-tech textile with secure, lockable fittings; tank protector and tank bag in high-tech textile; high seat (+40 mm), Slip On Street Legal Aprilia by Akrapovic titanium exhaust kit, carbon hand guards hinged on handlebars, carbon parts (exhaust pipes protection, heel guards, sump guard), electronic anti-theft system.
http://www.aprilia.com/modelli/adventure/modello.asp?id=83
  • BMW GS is waiting for You...what are You waiting for????, 822 postova
  • Lokacija: YU jos uvjek u 36-oj...
  • Motocikl: Wee 650
Izgleda ko san!
Ja sam vidio Caponorda i otkinuo kako izgleda!
Nek se dugo kotrlja!
Guest diRRty
Ono sto je najvaznije , Aprilia vise ne trpa ono djubra od Rotaxa u taj model, vec stavlja provereni Yamahin agregat koji ide i u njene srodne modele
  • Super heavyweight, 641 postova
  • Lokacija: Nis
  • Motocikl: BMW F700 GS
Meni se cini da u Pegaso 650 ide minarelijev agregat koji se ugradjuje u Yamahu XT660, MT 3 Yamahu, Derbi Mulhashen 659.
  • In Mud We Trust, 1918 postova
  • Lokacija: BGD
  • Motocikl: 950ADV
Bravo ! bike je super ! ja se u jednom momentu primio na njega, moj drugar ga ima i prezadovoljan je !!!
Bravo na izboru i da se navozas ! (uhhh ! nece nas vise smarati sa izborom !!! :mrgreen: )
A jes' lep !
Ali, moras da ga peglas ovako !!! :D
  • jedan od DDMZ, 818 postova
  • Lokacija: NBG
  • Motocikl: R, gsx R
Propustio sam da èestitam za motor, pa evo sad za obe stvari:
Puno kilometara sa uživanjem da preðeš, pa da se zajedno radujemo putopisima! :pivo: A za dozvolu: (malim slovima) dobrodošao með` legalne vozaèe. :wink:
