HONDA VARADERO XL125V 2008
  • Zainteresovan, 984 postova
  • Motocikl: F900GS
Jutros citam casopis"dva tocka" kad ono varadero125, nisam ni znao da postoji od 125 kubika...
Evo specifikacija pa vi malo prokomentarisite...Ja smatram da je super motoric ! ;D
                          General information
Model: Honda XL125V Varadero
Year: 2007
Category: Sport touring
Rating: 76.6 out of 100. Show full rating and compare with other bikes
                           Engine and transmission
Displacement: 125.00 ccm (7.63 cubic inches)
Engine type: V2
Stroke: 4
Power: 15.00 HP (10.9 kW)) @ 11080 RPM
Torque: 10.70 Nm (1.1 kgf-m or 7.9 ft.lbs) @ 9500 RPM
Compression: 11.8:1
Bore x stroke: 42.0 x 45.0 mm (1.7 x 1.8 inches)
Fuel control: SOHC
Ignition: Dual digital transistorised with electronic advance
Starter: Electric
Cooling system: Liquid
Gearbox: 5-speed
Transmission type
final drive: Chain
More details Consult a Honda repair manual.
                                       Physical measures
Dry weight: 149.0 kg (328.5 pounds)
Seat height: 802 mm (31.6 inches) If adjustable, lowest setting.
Overall length: 2,150 mm (84.6 inches)
Ground clearance: 190 mm (7.5 inches)
Wheelbase: 1,450 mm (57.1 inches)
                              Chassis and dimensions
Front suspension: 35mm telescopic fork, 132mm axle travel
Rear suspension: Monoshock swingarm with adjustable spring preload, 150mm axle travel
Front brakes: Double disc
Front brakes diameter: 276 mm (10.9 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Power/weight ratio: 0.1007 HP/kg
                                Other specifications
Fuel capacity: 17.50 litres (4.62 gallons)
Evo i slike :
  • Svrati ponekad, 471 postova
Letos je sestrin decko iznajmio varadero 125 na skiatosu i prenela mi je utiske, kaze da je odlican, dovoljno jak da povuce njega (100kg) i nju (55kg) i to bez ikakvih problema po bilo kom putu, a obisli su skoro celo ostrvo u potrazi za dobrim plazama.
izgleda masivno i ozbiljno tako da nije losa kupovina za prvi motor pre kupovine recimo varadera 1000 ;D
  • Zainteresovan, 564 postova
To je biio moj favorit za kupovinu, ali sticajem okolnosti , nisam mogao da ga nadjem polovnog u Srbiji( verovatno je tolko dobar da ga niko ne prodaje ;D)  a u centru S je 6 hiljada evra...sto je malo mnogo :)
Ukratko odlican motor za pocetnike, malo tezi, ali naviknes se brzo!
  • Zainteresovan, 589 postova
  • Lokacija: Novi Beograd
  • Motocikl: Voge SR4 Max
Snaga i moment se nesto kasno dostizu, skoro pa kao na litarskim  R-ovima...mozda su mogli malo da spuste te obrtaje za max snagu i moment  :-\
  • Ducatista, 2926 postova
  • Lokacija: Pancevo
  • Motocikl: beše Ducati 998
Nije mi jasno odakle im ideja da naprave ovakav motor  ??? ??? ??? ???
Ideja je da to bude najidealniji motor za početnike. Misija uspela.
Vozi sam ga 3 god i nemam loše reči za njega. Uskoro ću da uradim kompletan opis i text o Varaderu pa će te moći da ga iskomentarišete.
  • Drug član, 1126 postova
  • Lokacija: Ljubljana, Slovenija
  • Motocikl: ex MV Agusta 800 Brutale
Video sam letos jedan u Francuskoj (ne znam koje godište izgledao je relativno nov) i mogu reći da izgleda super, samo što ima 125 ccm, ali što Đusi reče idealan motor za početnika
  • Motocikl: F900GS
eto..heh.... meni se mnogo svidja..mnogo je veci od moga xt-a i izgleda mocnije dosta ovako, i udobniji je ja mislim...Ma nema veze, zadovoljan sam onim sto imam  ;D ;)
  • Drug član, 2247 postova
  • Lokacija: Beograd/Šumadija
E da, ja i dalje tvrdim da je to najbolji motor za vožnju po gradu, a prve km sam pravio baš na njemu...
I onda kad ti sviraju skuteraši na friju i libertiju da ubrzaš na semaforu, a tebi strava  jer kad te obilaze sa obe strane imaš utisak vožnje u rikverc  ;D ;D
  • Lokacija: Pancevo
Pa ja sam lakse vozio Varadera nego skuter... Kakvi Friovi i Liberti, pa nije ni ovaj za bacanje. Jedino je zeznuto ako oces da se trkas sa nekim 2T skuterom od 125 ili jace, ali ovi prdavci od 49 mogu samo da gledaju u auspuh. To je cinjenica, a i licno sam se uverio  ;D ;D ;D
  • Motocikl: F900GS
He
Jao sad bas gledam ovu sliku ovde tvog varadera, stvarno je prelep...Ostao sam bez reci stvarno....Strava motor ?Kako ide ?Koja mu je max brzina bas me interesuje ?
  • NW, 2593 postova
  • Lokacija: НОВИ САД
  • Motocikl: R 1200 GS
dobro oce li taj opis?
  • U prolazu, 6 postova
exe... pa ja imam ovaj motor 2003god sa direktnim ubrizgavanjem. Nije los za po gradu al je mnogo slab a max brzina mu je 110-115. Najvise me nervira to sto mu je prva brzina MNOGO kratka pa na 10km/h moram da prebacim u drugu. Ako imate neka pitanja pitajte.....
  • Lokacija: Pancevo
Poceo sam da radim ali nisam stigao da ga zavrsim. Dajte mi samo malo vremena i bice uskoro na naslovnoj... Sad mi je naletelo i jos nekoliko obaveza pa sam malo rastrzan
  • Drug član, 1392 postova
Nije mi jasno odkud im ideja da naprave putni motor sa kojim ne mozes da putujes jer nema dovoljno snage?
1000darka je idealna ali ima dosta ljudi kojima je to previse zbog odrzavanja,registracije,gabarita..
i sta rade?
kupe mali strom
zato sto honda nece da ugrozi svoj dragoceni jebeni transalp-zato i gube kupce u putnoj klasi 600kuba jbg
  • Lokacija: Pancevo
Matori, pa Varadero 125 je izasao 2001. Kakva je konkurenicija on motoru od 600 ili 650 kubika ? To je motor za pocetnike, pogotovo za one pocetnike koji su visi od 180. Znaci ovaj mali Varadero je motor za pocetnika i za gradsku voznju, udobniji je od skutera, zanimljiviji za voznju definitivno, a skoro se podjednako lako manevrise (ili to samo ja imam problem sa voznjom skutera).
  • Zainteresovan, 730 postova
  • Lokacija: Kotor Varos (Republika Srpska) - Novi Sad
Nisi jedini. Ja ne znam kako neko moze voziti skuter. nerealno, monotono, ne volim skutere pa makar imo 1000 ccm i 200ks, ne volim ih. A ovaj varadeo je bas fin. Za pocetnike pravi sto kazes, ne bih se ljutio da mi ga neko daje  ;D ;D
