-Viper- 547 Napisano Mart 11, 2013 Zainteresovan, 621 postova Lokacija: Kać Motocikl: Kawasaki ER-6n 2006g. Prijavi odgovor kao problematičan ELM 327 bluetooth na prodaju, novo. cena 3000 din. The OBDII Bluetooth car diagnostic is used to read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning. The can test a lot of trouble of the car and display the current sensor data, including: engine RPM, calculated load value, coolant temperature, fuel system status, vehicle speed, short / long term fuel trim, intake manifold pressure, timing advance, intake air temperature, air flow rate, absolute throttle position, oxygen sensor voltages / associated short term fuel trims, fuel pressure, Many others... The Bluetooth diagnostic is very convenient to use. - Works with all OBD-2 compliant vehicles - Bluetooth connection - Bluetooth range: 30m - LED indication - Voltage: 12V (short circuit and overvoltage protection) - Comes with CD disk kontakt na PP ili na 0606212269 Edit Ako moze naziv teme da se popravi, nije 324 nego 327 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
-Viper- 547 Napisano Jun 8, 2013 Zainteresovan, 621 postova Lokacija: Kać Motocikl: Kawasaki ER-6n 2006g. Prijavi odgovor kao problematičan Prodato. Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
