GG Quad
  • Svrati ponekad, 426 postova
  • Lokacija: Beograd/Surcin
  • Motocikl: Suzuki SV650S
Jedan od najlepsih quad-ova koje sam video, sa BMW 1130 cc boxer motorom!!!  a evo i nekih tehnickih detalja o samom modelu
Technical data
engine type 2-cylinder 4-stroke boxer engine
valves 4 valves per cylinder
capacity 1130cm3
power output 70 kW (90 hp at 7250 rpm EU and CH 15 kW
torque 98Nm at 5500 rpm
catalytic converter controlled 3-way catalytic converter
transmission 6 gears / 1 reverse gear
Mass and weights
tank volume 18 liters
dry weight 375 kgs
overall lenght 2220 mm
overall width 1400 mm
Driving performance
top speed 170 km/h / EU and CH 100 kph
Chassis
frame GG-design
wheel individual wheel suspension with trapezoidal cross-members made of aluminum
suspension struts hydraulic suspension struts with infinitely variable tension adjustment
spring travel 100 millimeters front and rear
drive Differentiel
brakes hydraulic brake system, 270 mm floating brake disks, 4x4 piston GG brake calipers
wheels aluminum cast wheels
tires front: 195/40-16 rear: 225/40-16
Price on request
Authorised for use in
Germany: Unlimited TüV authorization
Switzerland:  TüV and CH authorization (15 kW / 100 kph)
Colors The basic price includes single-colour paint finish (any colour). Customised paint finishes, lettering, logos, special designs etc. are charged on the basis of the actual expense incurred.
  • Drug član, 1592 postova
  • Lokacija: Budva - MNE
  • Motocikl: Aprilia Pegaso 650 Strada
Trebao si onda doci na moto skup u Sutomore  ;) , bio je jedan lik iz Slovenije sa tom spravom
Evo i ja se slikao kraj tog BMW-a
ima jos slika u temi o moto skupu http://www.bjbikers.com/index.php?option=com_smf&Itemid=53&topic=9900.0
