mixa 1396 Napisano Septembar 11, 2007 Ne silazi, 5766 postova Lokacija: Trebinje Motocikl: Honda Varadero 1000 ABS Prijavi odgovor kao problematičan Evo nesto i za one koji vole prasinu: XT660Z Tenere Features - * Follow imagination * Rally raid bodywork * 22-litre fuel tank for long-range riding * Tough steel frame & aluminium swingarm * Range of great accessories available Engine - Engine type Liquid-cooled, 4-stroke, 4-valve, single cylinder, SOHC Displacement 660 cc Bore x stroke 100.0 x 84.0 mm Compression ratio 10.0:1 Maximum power - Maximum torque - Lubrication system Wet sump Fuel System Fuel injection Clutch type Wet, multiple-disc coil spring Ignition system TCI Starter system Electric Transmission system Constant mesh, 5 speed Final transmission Chain Fuel tank capacity 22 L Oil tank capacity 2.9 L Chassis - Chassis: Steel tube diamond shaped Front suspension system Telescopic forks Front travel 210 mm Rear suspension system Swingarm (monocross) Rear travel 200 mm Front brake Double disc, Ø 298 mm Rear brake Single disc, Ø 245 mm Front tyre 90/90-21 M/C Rear tyre 130/80-17 M/C Dimensions - Length 2,246 mm Width 865 mm Height 1,477 mm Seat height 895 mm Wheel base 1,505 mm Minimum ground clearance 245 mm Dry weight 183 kg A evo nove i stare zajedno: Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
AnteK 717 Napisano Septembar 11, 2007 Drug član, 1427 postova Lokacija: okolica Osijeka, RH Motocikl: Tuareg 660 Prijavi odgovor kao problematičan Slin, slin .... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Motoholic 2338 Napisano Septembar 11, 2007 ¡Siempre adelante!, 2188 postova Lokacija: Kalifornija Motocikl: BMW F650GS... Harley-Davidson Nightster Prijavi odgovor kao problematičan Impresioniran sam. Tezak manje od 200 kg, rezervoar od 22 litra, dupli diskovi napred, fuel injection.... it to sve na jednocilindricnom motoru. Sto bre to nema ovde kod mene... :'( Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Cope 216 Napisano Septembar 11, 2007 Drug član, 2247 postova Lokacija: Beograd/Šumadija Motocikl: Triumph Tiger 800xc Prijavi odgovor kao problematičan Meni se ovo čini kao direktan udarac BMW-u F650 Dakar. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Motoholic 2338 Napisano Septembar 11, 2007 ¡Siempre adelante!, 2188 postova Lokacija: Kalifornija Motocikl: BMW F650GS... Harley-Davidson Nightster Prijavi odgovor kao problematičan Meni se ovo čini kao direktan udarac BMW-u F650 Dakar. Naravno, nisu Japanci blesavi. Posto se F650GS Dakar vise ne proizvodi nesto mora da ga zameni. Ova BMW-ova nova G-serija sa svojim smesnim patuljastim rezervoarima mu sigurno nije zamena, a ovaj Tenere izgleda mnogo, mnogo dobro. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
AnteK 717 Napisano Septembar 11, 2007 Drug član, 1427 postova Lokacija: okolica Osijeka, RH Motocikl: Tuareg 660 Prijavi odgovor kao problematičan Meni se ovo čini kao direktan udarac BMW-u F650 Dakar. Dakar se više ne proizvodi. Inače, Dakar je super motor ali je dosta manji i od moje Tenerke, a kamoli od ove nove. E sad imam o čemu razmišljati ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
AnteK 717 Napisano Septembar 11, 2007 Drug član, 1427 postova Lokacija: okolica Osijeka, RH Motocikl: Tuareg 660 Prijavi odgovor kao problematičan Naravno, nisu Japanci blesavi. Posto se F650GS Dakar vise ne proizvodi nesto mora da ga zameni. Ova BMW-ova nova G-serija sa svojim smesnim patuljastim rezervoarima mu sigurno nije zamena, a ovaj Tenere izgleda mnogo, mnogo dobro. Mislim da će SAD opet ostati uskraćen i za ovaj motor, isto kao i za mnoge Yamahe i Honde prije... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Motoholic 2338 Napisano Septembar 11, 2007 ¡Siempre adelante!, 2188 postova Lokacija: Kalifornija Motocikl: BMW F650GS... Harley-Davidson Nightster Prijavi odgovor kao problematičan Mislim da će SAD opet ostati uskraćen i za ovaj motor, isto kao i za mnoge Yamahe i Honde prije... Naravno Vec sam navikao. A cak i oni koji stignu u SAD ne prodaju se uvek kod mene u Kaliforniji posto Kalifornija ima ostrije zakone o zagadjivanju vazduha... Na primer, novi Kawasaki Versys - vec ga ima svuda u SAD, a u Kaliforniji je zabranjen Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
RSVMillenian 229 Napisano Septembar 11, 2007 Drug član, 1140 postova Lokacija: Chicago, IL USA Motocikl: 2007 Triumph Daytona 675 Prijavi odgovor kao problematičan Mislim da će SAD opet ostati uskraćen i za ovaj motor, isto kao i za mnoge Yamahe i Honde prije... Naravno Vec sam navikao. A cak i oni koji stignu u SAD ne prodaju se uvek kod mene u Kaliforniji posto Kalifornija ima ostrije zakone o zagadjivanju vazduha... Na primer, novi Kawasaki Versys - vec ga ima svuda u SAD, a u Kaliforniji je zabranjen Hoces da ti ga registrujem u Ilinoisu? Samo se javi i nema problema. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Čeh 1009 Napisano Septembar 11, 2007 Drug član, 1542 postova Lokacija: Beograd Motocikl: XLV 1000 Prijavi odgovor kao problematičan Žeeeeeliiiim ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Motoholic 2338 Napisano Septembar 11, 2007 ¡Siempre adelante!, 2188 postova Lokacija: Kalifornija Motocikl: BMW F650GS... Harley-Davidson Nightster Prijavi odgovor kao problematičan Hoces da ti ga registrujem u Ilinoisu? Samo se javi i nema problema. Uh, bih vrlo rado... Samo ako imas CA vozacku a tablice iz druge drzave kazna je $300. A ja se neretko susrecem s' policijom Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
LUC1FER 4 Napisano Septembar 11, 2007 Svrati ponekad, 160 postova Lokacija: Beograd Motocikl: Ducati 848evo Prijavi odgovor kao problematičan Ja generalno ne volim enduro motore ali ovaj bih tako posedovao..bas mi se svidza Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ćili 675 Napisano Septembar 12, 2007 Drug član, 935 postova Lokacija: Beograd - Mirijevo Motocikl: Kawasaki ZZR600 Prijavi odgovor kao problematičan Meni lici na ogromnog trickera Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Columbia 1 Napisano Septembar 12, 2007 U prolazu, 84 postova Lokacija: Serbia Prijavi odgovor kao problematičan He, he ... kao da je pravljena za US ARMY ... a makina ista ko na mom konjicu MY660 ! Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
acim 770 Napisano Octobar 29, 2008 Ne silazi, 5817 postova Lokacija: Minhen Motocikl: Kawasaki H2 SX SE '23 / Triumph R3 Storm R '24 Prijavi odgovor kao problematičan Evo testa iz emisije MotoTV na italijanskom Skyju: A evo i još nekoliko slika: Stara i nova Tenera: Izvor Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
TA96 301 Napisano Octobar 29, 2008 Drug član, 1423 postova Lokacija: Bliski Istok-Pančevo Motocikl: Honda CRF300L Prijavi odgovor kao problematičan . Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
lalajko 2064 Napisano Octobar 29, 2008 Teoreticar ..., 12120 postova Lokacija: Lazarevac Motocikl: BMW R1200GS Adv Prijavi odgovor kao problematičan Malo je prejako reci da je Transalp "totalno zakazao". Ja bih recimo izmedju ova dva motocikla uvek pre uzeo Transa jer jednostavno vise odgovara mojim potrebama. Mislim da ta dva motora ne gadjaju istu ciljnu grupu. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
lalajko 2064 Napisano Octobar 29, 2008 Teoreticar ..., 12120 postova Lokacija: Lazarevac Motocikl: BMW R1200GS Adv Prijavi odgovor kao problematičan Slazem se. Pa i iz naziva motora se lepo vidi za koji deo sveta su predvidjeni. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
pit 237 Napisano Octobar 29, 2008 Drug član, 1779 postova Lokacija: Nis- Bliski istok Prijavi odgovor kao problematičan Ova nova Tenera je stvarno leo motor i ne sumnjam da je dobra za off ali ima nesto sto je velika glupost kod nje a to sam vidu na uporednom snimku sa starom Tenerom,naime prednjim blatobran je uz tocak sto je odmah isklucuje iz voznje kroz blato jer je mali razmak i napunice blatom vrlo brzo a koje ulazio u blato sa takvim motorom zna da je tu voznji kraj dok ne ocistis blatobran.Eto. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Cope 216 Napisano Octobar 29, 2008 Drug član, 2247 postova Lokacija: Beograd/Šumadija Motocikl: Triumph Tiger 800xc Prijavi odgovor kao problematičan Ova nova Tenera je stvarno leo motor i ne sumnjam da je dobra za off ali ima nesto sto je velika glupost kod nje a to sam vidu na uporednom snimku sa starom Tenerom,naime prednjim blatobran je uz tocak sto je odmah isklucuje iz voznje kroz blato jer je mali razmak i napunice blatom vrlo brzo a koje ulazio u blato sa takvim motorom zna da je tu voznji kraj dok ne ocistis blatobran.Eto. Visoki blatobran je opciona oprema od par desetina evra i dobro je rešenje samo ako se vozi po izuzetno velikom blatu. Inače preko 100 km/h visoki blatobran ume da baca upravljač usled dejstva jakog vetra što ponekad predstavlja problem. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
pit 237 Napisano Octobar 29, 2008 Drug član, 1779 postova Lokacija: Nis- Bliski istok Prijavi odgovor kao problematičan Ova nova Tenera je stvarno leo motor i ne sumnjam da je dobra za off ali ima nesto sto je velika glupost kod nje a to sam vidu na uporednom snimku sa starom Tenerom,naime prednjim blatobran je uz tocak sto je odmah isklucuje iz voznje kroz blato jer je mali razmak i napunice blatom vrlo brzo a koje ulazio u blato sa takvim motorom zna da je tu voznji kraj dok ne ocistis blatobran.Eto. Visoki blatobran je opciona oprema od par desetina evra i dobro je rešenje samo ako se vozi po izuzetno velikom blatu. Inače preko 100 km/h visoki blatobran ume da baca upravljač usled dejstva jakog vetra što ponekad predstavlja problem. Eto nesto novo sam naucio. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
test 1 Napisano Octobar 29, 2008 Svrati ponekad, 197 postova Lokacija: Petrovac na moru Prijavi odgovor kao problematičan ova yamaha nije izasla bas nedavno ima je vec duze vrijeme na nasem trzistu Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
JankoR 475 Napisano Octobar 30, 2008 Zainteresovan, 707 postova Lokacija: podgorica,mne Motocikl: uvijek prljava Honda xr650r Prijavi odgovor kao problematičan Vidio sam je ovoga ljeta u Sutomoru na motorijadi i na sajmu u Budvi, izgleda baš baš Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
