rusic 261 Napisano Februar 18, 2010 Prekidach, 1093 postova Lokacija: Beograd Motocikl: Honda Africa Twin CRF1000L & Suzuki DR 650 SE Prijavi odgovor kao problematičan chas ga ima na sajtu chas ga nema... uglavnom, ima par slika po netu: Model EC 450 Desert Engine: Cylinder size 449 cc Type 4-stroke single cylinder with 4-valve cylinder head. Cooling system Liquid Bore x stroke 97x60.8mm Ignition Integrated in the injection system Fuel System Electronic injection (Battery less EFI) Clutch Multidisc hydraulic operated AJP Gearbox 6 gears. Frame: Frame Deltabox build with Cromoly "B" tubes Front suspension 48 mm upside-down Marzocchi fork, 290 mm travel Rear suspension One-piece aluminium swing arm progressive system with Sachs shock absorber, 320 mm travel Front brake 260mm. disc, double-piston caliper Nissin. Rear brake 220mm. disc, single-piston caliper Nissin. Front tire 90x90 - 21" Michelin Rear tire 140x80 - 18" Michelin Kick starter Forged aluminium. Size: Wheelbase 1465 mm Seat Height 940 mm Minimal ground clearance 370 mm Fuel tank capacity 17 liters Mass 133 Kg http://www.gasgasmotos.es/ Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Februar 18, 2010 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Dobar... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
to crank 5893 Napisano Februar 18, 2010 Integrisan, 13840 postova Lokacija: Buda/Szigliget Motocikl: CB 360 / . SV 650 / GSXR600(ukraden) / GSX-R 750 Prijavi odgovor kao problematičan Uh! Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
RadicM 1077 Napisano Februar 20, 2010 Hard Enduro, 1532 postova Lokacija: Beograd Motocikl: Honda Africa Twin 750 '01, Honda Dominator 650 '01 bili nekad Suzuki TS 125 R i Tomos ATX 01' Prijavi odgovor kao problematičan Lici an super teneru po obliku ali onu matoru samo sto je ovaj uzi. Sve u svemu ne bi se zalio da imam jedan ovakav Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Boban 501 Napisano Februar 21, 2010 Drug član, 1480 postova Lokacija: Bratunac, Earth Motocikl: R1200C, GS, DRZSM Prijavi odgovor kao problematičan Uh! Isto :o Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
SHOKLA 1768 Napisano Februar 27, 2015 Drug član, 1507 postova Lokacija: KLADOVO, KLADOVO, KLADOVO Motocikl: Mali Plavi Zeka S '06., VFR 800 V-Tec '02., TL 1000s '97., FJR 1300 '02., Gillera Runner FXR '02., Peugeot Vivacity. Suzuki AY 50 Katana - za sada... I SVI LEPI!!! Prijavi odgovor kao problematičan 133kg??? Pretezak za to na sta "puca". Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
markodjurovic 818 Napisano Mart 9, 2015 Drug član, 1413 postova Lokacija: Beograd/Kraljevo Motocikl: Husaberg FX 550, Honda Varadero 1000, Honda CRF300L Prijavi odgovor kao problematičan Sada stoje druge informacije o tezini u pdf 121 na strani 127 kila. U svakom slucaju nije mnogo za reli motor. A izgleda ko milion dolara . Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
