Sta bih ja vozio kinesko (Novi modeli) ili kada ce ovo stici do nas
  • NW, 2593 postova
  • Lokacija: НОВИ САД
  • Motocikl: R 1200 GS
Ispirisan nekim slikama koje su se vec pokazivale negde na temi za vlasnike kineza, a pokrenut malopre procitanim tekstom o prepisci sa Kinroad fabrikom resih da ponovo pokrenemo sad vec zaboravljenu pricu ali pomalo spominjanu (od sajma do sajma) ja bih voleo nesto od ovoga:
EEC/EPA Approval, new designed 400cc Dirt bike
Product size(mm): 2110*825*1340
Wheel base(mm): 1455
Ground clearance(mm): 140
Max. speed(Km/h): 140
Fuel capacity(L): 22
Seat height(mm): 820
Started system: kick/electric
Tire size: 110/90-16 / 140/70-16
Wheel type: light alloy / light alloy
Brake mode: Disc brake / disc brake
Brake operation mode: hand/foot
Engine style: Single cylinder, water cooling, 4stroke
Rated displacement: 386.8cc
Max. output power(Kw/rpm): 20kw/7500rpm
Bore*Stroke: 91*59.5
Ignition: C. D. I
Transimission type: chain transmission
EEC NO.:e4*2002/24*1941*01
Detailed Product Description
Product size(mm:)2210*790*1130
Wheelbase (mm):840
Mix ground clearance (mm): 180
Dry weight(kg):140
Gross weight (kg):190
Fuel tank capacity(L):22
Seat height(mm):820
Battery type:12V7A
Brake mode(front/rear):disc brake/disc brake
Brake operation mode(front/rear ):hand/foot
Engine type:single cylinder 4-stroke
Engine number:XY191MQ-2
Bore*stroke(mm):91*59.5
Displacement(ml):387
Compression ration:10.0:1
Max power/ running radius:22/7500kW/(r/min)
Rated power /running radius : 20/7500kW/(r/min)
Max torque /running radius:32/5500 N.m/(r/min)
Mim fuel consumption (g/kw/km):367
Ignition :C.D.I.
Product size(mm)2210x860x1200
Wheelbase (mm):720
Mix ground clearance (mm): 300
Dry weight(kg):132
Gross weight (kg):182
Fuel tank capacity(L):9.0
Seat height(mm):880
Battery type:12v/7AH
Mim fuel consumption (g/kw/km ):367
Ignition :C.D.I.
Jedino sto nigde nisam mogao pouzdano da nadjem to je cena! Ako neko dobro gugla neka dopise pa cemo azurirati.
Izvolite komentarisite i dajte mi vas model?!
  • Drug član, 3087 postova
На сајту неке северноамеричка компаније која их увози, ова прва два мотоцикла су сликана са неким изменама (имају трокраке фелне у нормалним димензијама, а ендуро постоји са пластиком а-ла Кавасакијеви тренуто актуелни ендуро модели.
  • NW, 2593 postova
Nemoj da nam pricas nego turi slike....
  • Drug član, 1435 postova
  • Lokacija: BG - Zemun - Zvornik
  • Motocikl: Bmw R1200RT LC, Ktm exc300
Jel se meni cini ili ovaj zadnji sivi ima facu ko BMW a zadnji kraj od stroma :-) Spojiti lepo i korisno, pametni ovi Kinezi
А да је у питању "Фотошоп", то као да никоме није пало на памет?
Ове слике се врте одавно по Нету.
  • Svrati ponekad, 404 postova
  • Lokacija: Novi Becej
  • Motocikl: Honda CBR 900rr
Negde sam procitao da su to koncept modeli...Ne bi me zacudilo da kinezi stvarno izbace tako nesto! ;D
  • Zainteresovan, 730 postova
  • Lokacija: Kotor Varos (Republika Srpska) - Novi Sad
Meni bi i ovo bilo dovoljno... Samo da se prodaje kod nas
LF200-B
Colors: Red/Blue/Black
Engine Type: Air Cooled, Single Cylinder, 4-Stroke
Displacement: 197CC
Starting System: Electric
Brake System (FRONT): Double Disc/Hand Control
Brake System (REAR): Disc/Pedal Control
Transmission System: 5 Speed, Manual Clutch
Ignition System: CDI
Max. Power: 16HP/8000RPM
Max. Torque: 14.5N.m/6000RPM
Max Speed: 60MPH
Max Loading Capacity: 330LBS
L x W x H: 88.6" x 32" x 42.3"
Wheel Base: 55.9"
Dry Weight: 350 LBS
Gas Yield: 0.97 GAL/100Mile
Suspension (FRONT): Hydraulic
Suspension (REAR): Hydraulic Spring
Tire Size: FRONT 110 / 70 - 17
REAR 140 / 70 - 17
  • U prolazu, 39 postova
  • Lokacija: jarkovac
  • Motocikl: cbf600abs
imaju li ti kinezi nesto od 600 ccm
sad ih prvi put ogledah, bas me interesuje vredi li vrteti da se tako nesto niskobudzetno odpazari
  • Drug član, 1399 postova
  • Lokacija: Chicago IL - Babusnica - Nish
  • Motocikl: Husqvarna tr650 strada abs 2014
Ovi sa slike su prototipi, tacnije photo shop. Imaju kinezi jedan model od 600ccm i to nije kopija vec su ga sami konstruisali sa jos jednom firmom, ne znam kako se zvase. Malo kasnije cu da postavim sliku i link, samo da nadjem.
Evo par slika.
Evo jednog linka gde je sve bas dobro i slikovito objasnjeno.
http://www.jialing.com.cn/newjl/en_web/600_sx01.html
Evo i jednog linka sa foruma za koga ste naj verovatnije skoro svi culi
http://www.mychinamoto.com/forums/showthread.php?t=191
Ovo mi se bas posvidjalo.
Therefore, many outside help has been commissioned, joint developed, technical transfered etc.... Just to mention a few :
Engine: Jointly designed by Jialing and AVL in Austria
Clutch: FCC
Drive chain: DID
Suspension: Showa
ECU/fuel injection: Bosch
Instrument: Simens
Izvor: www.mychinamoto.com
  • Svrati ponekad, 458 postova
  • Motocikl: gpz 500 s
Ja ovo vozim dogodine,ima malo losiju zavrsnu obradu ali ima i snage,o eleganciji da ne pricam.Stvar ukusa,ali ovaj me potrefio:
Kawu sam vec bio vozio(doduse bratovu,ali vozio) devedesetih,odavno su mi poznati ti motori.
Videcete na prolece Daytonu,ako Bog da!
