Benelli Tre 1130 K Amazonas
  • Svrati ponekad, 419 postova
  • Lokacija: San Jose, CA
  • Motocikl: BMW S1000XR '16, BMW R1250GS HP ADV '19
Model: Benelli Tre 1130 K Amazonas
Year: 2007
Category: Enduro / offroad
Rating: 64.3 out of 100.
Engine and transmission
Displacement: 1130.00 ccm (68.95 cubic inches)
Engine type: In-line three
Stroke: 4
Power: 123.37 HP (90.1 kW)) @ 9000 RPM
Torque: 115.00 Nm (11.7 kgf-m or 84.8 ft.lbs) @ 6250 RPM
Bore x stroke: 88.0 x 62.0 mm (3.5 x 2.4 inches)
Fuel system: Injection. Electronic injection with 1 injector per cylinder
Fuel control: DOHC
Ignition: Single coil inductive discharge electronic ignition
Starter: Electric
Lubrication system: Wet sump
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Chain
Clutch: Wet clutch
Physical measures
Dry weight: 205.0 kg (451.9 pounds)
Wheelbase: 1,514 mm (59.6 inches)
Chassis and dimensions
Frame type: Mixed solution. Front: ASD steel tube trellis,
Rear suspension: ASD steel tube trellis swingarm with
Front brakes: Double disc
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc. Bremo
Speed and acceleration
Power/weight ratio: 0.6018 HP/kg
Sto se mene tice stvarno izgleda zanimljivo ali to nije moj ukus.
  • Drug član, 1140 postova
  • Lokacija: Chicago, IL USA
  • Motocikl: 2007 Triumph Daytona 675
uff, ja bih voleo ovo posedovati...  :-\
Verujmi da ne bi voleo da ovo imas.  Moj prijatelj ima Tre i vise je u servisu nego sto se vozi.  Presao je jedva 1000km a non stop ima probleme da bukvalno nesme da krene ni na kafu sa njim jer nezna da li ce da upali ili da se ugasi u voznji.
Da verovatno je greska. To sam kopirao sa jednog sajta. Ja pretpostavljam da je prednja 19 a zadnja 17.
  • Zainteresovan, 561 postova
  • Lokacija: Chicago, IL / Bor, SRB
  • Motocikl: 04 Yamaha R1, 15 Kawasaki ZX-14R 30th Anniversary LE, 01 Ducati Monster S4, 21 Vespa Primavera 150 Sean Wotherspoon, 16 Aprilia Dorsoduro 750, 01 Suzuki Hayabusa, 14 Harley-Davidson Road King FLHR, 94 Suzuki RM250
gledajuci sliku,mislim da je precnik gume isti, samo je razlika u sirini
Glupost...
Inace,lep je ovako,"na oko"...Kao neka kombinacija enduro i naked motora.
  • U prolazu, 70 postova
Uveliko radim na tome da sebe obezbijedim jednoga... Samo bijelog.
Sto se "problema" tice bili su prisutni kod TNT t.j. Tornado serije... i to samo na prvim modelim...
Problem je sto je agregat preuzet sa SBK "Tornado" modela koji nije predvidjen da ima alaser i lako se pregrijavao... TnT modeli imaju 3 ili cak 4 hladnjaka i ventilatora.
Sent from my SM-G920F using Tapatalk
  • Ko zna šta, 68 postova
Evo prodaću ti ja moj, ti samo kupi druge točkove i to ti je to, rolbar, bulbar isl.
Ja sam ga uzeo sa 9900km. promenio sam samo frajlauf, i fercera bez problema, tako da te priče o lošim agregatima ne piju vodu, pali radi, ide, perem ga na pušku pod pritiskom, doduše jednom u je crkao automat migavaca, ali je posle sušenja fenom ni to više nije problem.
http://www.polovniautomobili.com/motori/8096995/benelli-trek-1130-hitno
  • Drug član, 1085 postova
  • Lokacija: Bijeljina
  • Motocikl: YZF R1
Meni su ovi Beneli egzotičniji i od Aguste :) ..A imaju taj neki fazon za hlađenjem, i Tornado gdje god pogledaš ima neki ventilatorčić, mislim da čak i ispod sjedišta..
