КГБ 11 Napisano Mart 28, 2011 Svrati ponekad, 208 postova Lokacija: Дорћол Motocikl: Honda Dylan 150cc Prijavi odgovor kao problematičan Ćao, nigde nenađoh nešto o ovom modelu Honda Air Blade skuter 110cc 2008, a imam ga u nekoj kombinaciji ... pa me zanima jel neko imao neka iskustva sa istim ... The Honda Air Blade is the latest addition to the fleet of Honda motor bikes available in Thailand at the moment. The Honda Air Blade designed by Kaoru Hayashi and his team is one of the sleekest of the scooter style motor bikes available on the market. The Honda Air Blade with its sharp wide beam twin headlights has numerous features that make it one of the best value and most reliable motor bike, the Honda Air Blade is a strong competitor on a highly competitive motorcycle market. The Honda Air Blade's 110cc four-stroke engine with built-in liquid cooling is compact but packs more horsepower than a standard 125cc air-cooled automatic motorcycle engine. Ride comfortably, confidently and smoothly at all speeds with the efficient new V-Matic belt-drive transmission that uses a long-lasting reinforced steel belt. One of the newest safety futures is the installed Combi-Brake technology distributes braking power between the front and rear wheels when only the left brake lever is activated. The motorcycle comes to a stop within a shorter distance with both wheels handling the braking. Additional, the Honda Air Blade is equipped with a Parking Brake system which works in the same way as a car's hand brake. The engine is actual a 4-stroke SOHC 108cc cylinder with a compression ratio of 11:1 with a 50mm bore and a 55mm stroke and a CDI ignition. The 103 kilogram Honda Air Blade comes in two versions, the NC110AC and the NC110AS. The main difference between the two is that one comes with aluminum-magnesium alloy wheels an the other with spoked wheels. The rear suspension uses a single swingarm with two shock absorbers which contributing nicely to the motorcycle handling and braking, the Honda Air Blade is all about driving pleasure. The front suspension is what we find with most motorcycles, a telescopic fork with not much to tell about, other that we cannot complain about the road handling of this latest Honda motorcycle. The tail light is made up from high power LED lights, which are clearly seen from far away. The new positions of the fuel tank, which makes it easier to fill the motorcycle, but it needs some getting used to. I'm sure you will see many first time Honda Air Blade drivers opening the seat. The new position of the gasoline tank also gives more space for personal belongings under the seat. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
perlx 562 Napisano Mart 28, 2011 festina lente, 754 postova Lokacija: Beograd Motocikl: XRV Prijavi odgovor kao problematičan Xtra je stvarcica, moj prijatelj je ima, i to bas belu kao sa slike. Prostran je i udoban, ima prelepu kontrolnu tablu. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
КГБ 11 Napisano Mart 28, 2011 Svrati ponekad, 208 postova Lokacija: Дорћол Motocikl: Honda Dylan 150cc Prijavi odgovor kao problematičan баш ми је драго да неко има ту машину ајде га питај где је одржава колико троши итд ... или он нек напише ако је на форуму... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
