Sherco SM 50
  • U prolazu, 0 postova
Motor je Sherco SM 50,2006 godiste,presao je 13000 KM,cena 1150 eura.
-Sherco:Italijanska marka
-Motor:Minarelli AM6 (2T, vodeno hladjenje, 6 brzina)-Italijanski, isti motor koriste Aprilia RS 50, Yamaha TZR 50 i drugi...
-Karburator: Dellorto-Italijanski
-Viljuske: Paioli 41mm-Italijanske
-Amortizer: Olle(Gasni)-Spanski
-Kocnice:AJP (disk napred i pozadi)-Spanske
-Plastike: Acerbis i UFO-Italijanske
-Ceo motor je mnogo kvalitetan...
-Uvezen 2008 iz Svajcarske (licno)
-U odlicnom je stanju, gume su odlicne, trajno je registrovan za dve osobe, ima dosta dodatne opreme...
-Ide mnogo dobro....
-Cena novog u Hrvatskoj 3199 evra...
-Moze neka zamena, u zameni cena 1500 evra...
Kontakt na telefon 064/366-1553
Da dodam jos nesto o motoru,motor je stvarno u perfektnom stanju,sipano je samo kvalitetno ulje,prosle sezone je zamenjeno ulje u menjacu(Ipone ulje je sipano,koje je propisala fabrika Minarelli motora),promenjene su zadnje kocione plocice,i stavljena je nova NGK svecica.
Evo karakteristike na engleskom koje sam skinuo sa Shercovog oficijalnog sajta(www.sherco.com).
Engine-2 stroke - Minarelli AM6
Capacity-49,7 cc
Bore x Stroke-40,3 x 39 mm
Cylinder lubricat.-Nikasil coated cylinder with automatic oil injection (unleaded gasoline)
Cooling system-Closed water system with constant water circulation
Start-Geared system with foldable lever
Carburettor-Dellorto
Exhaust-Steel exhaust system with aluminum silencer
Transmission-6 speed sequential gearbox with security selector system to prevent false shifts. Primary gear drive, chain secondary drive.
Clutch-Multidisc in oil bath
Ignition-Electronic 12v 85 w
Chasis-Chrome-molybdenum tubing main frame with a removable sub-frame
Petrol tank-Made from plastic. Capacity 7 L
Brakes-Hydraulically activated AJP, floating 240 mm front and 180 mm rear
Front suspension-Paioli telescopic fork, Ø 41mm tubes
Rear suspension-Olle single shock absorber, adjustable spring preload
Front wheel-2.50 x 17"
Rear wheel-3.50 x 17"
Weight-83 kg (183 lbs)
Wheel base-1,360 mm (53.54 in.)
Ground clearance-260 mm (10.25 in.)
Seat height-850 mm (33.47 in.)
Kao sto mozete i sami da vidite motor je veoma kvalitetan.
Dodatne slike saljem na e-mail,ove su od letos.
I dalje aktuelno.
Cena pala na 1000€ zato sto sam nasao drugi motor koji mi se svidja,zaboravio sam da napisem da je to i jedini razlog prodaje,prelazak na 125 cm3.
