Kawasaki W800 Retro
  • Drug član, 3618 postova
  • Lokacija: Kovin
Visordown nam otkriva podatke o motoru, a na linku možete videti još slika.
2011 Kawasaki W800 specs
Engine type Air-cooled, 4-stroke Vertical Twin
Displacement 773 cm³
Bore x stroke 77.0 x 83.0 mm
Compression ratio 8.4:1
Valve/Induction system SOHC, 8 valves
Fuel system Fuel injection:φ34 mm x 2 with sub-throttles
Ignition Digital
Starting Electric
Lubrication Forced lubrication, wet sump
DRIVETRAIN
Transmission 5-speed, return
Final Drive Chain
Primary reduction ratio 2.095 (88/42)
Gear ratios: 1st 2.353 (40/17)
Gear ratios: 2nd 1.590 (35/22)
Gear ratios: 3rd 1.240 (31/25)
Gear ratios: 4th 1.000 (28/28)
Gear ratios: 5th 0.851 (23/27)
Final reduction ratio 2.467 (37/15)
Clutch Wet multi-disc, manual
FRAME
Frame type Double-cradle, high-tensile steel
Wheel travel, front 130 mm
Wheel travel, rear 105 mm
Tyre, front 100/90-19M/C 57H
Tyre, rear 130/80-18M/C 66H
Rake/Trail 27° / 108 mm
Steering angle, left / right 37° / 37°
SUSPENSION
Suspension, front 39 mm telescopic fork
Suspension, rear Twin shocks
Type: Twin shocks
Spring preload: 5-way
BRAKES
Brakes, front Type: Single 300 mm disc
Caliper: Twin-piston
Brakes, rear Type: Drum, 160 mm
DIMENSIONS
Dimensions (L x W x H) 2,180 x 790 x 1,075 mm
Wheelbase 1,465 mm
Ground Clearance 125 mm
Seat height 790 mm
Curb Mass 216 kg
Fuel capacity 14 litres
  • Drug član, 1963 postova
Aha, MZ malo sutra, ovo ce izgleda biti Trijumf Bonevil u jeftijem pakovanju( do duse Bonevil je ipak malo lepsi, jedina za oko bolja stvar na Kavasakiju su zicane felne)
  • Svrati ponekad, 217 postova
  • Lokacija: Necu da ti kazem celavi!!!
  • Motocikl: GPZ 500S
Dobro,nemoj da se ljutis,lici na ZELENI MZ ;D
  • prisutan, 1330 postova
  • Lokacija: Banja Luka
  • Motocikl: keeway cruiser 250,KLE 500,BMW K75, ZEPHYR 750,CBF 1000 BENELLI TRK 702
Vidio u motoreviji,odlicno izgleda,prava klasika,samo da ga neko i testira,ali ne moze da ne valja,Kawa je to!!
  • Rashodovani bajker, 1731 postova
  • Lokacija:
  • Motocikl: SunRa Shino
Prelep nema sta, bas me zanima koja ce cifra biti u pitanju.
Za naše tržište DKS još nije objavio cenu, ali u Sloveniji košta 7522 eura, pa pretpostavljam da će slična cena biti i kod nas, možda i par stotina niža ...
  • Zainteresovan, 699 postova
  • Lokacija: Srce Srbije pod jakim infarktom-Kosovska Mitrovica
  • Motocikl: Tomos APN6-82,BMW R 1150 RT-03,Kawasaki EN 500-94
Za samo 23 cm³ prelazi 750 cm³ <_<:stabre:
Ovi japanci nista ne vode racuna o "Seseljevom" porezu kod nas :)
Inace, mnogo je lep :takoje:
Samo bih voleo da je 4 cilindra, bio bi mnogo lepsi (a i bolji)
i skuplji za odrzavanje :zvizduk:
  • Drug član, 2285 postova
  • Lokacija: Kragujevac
  • Motocikl: Honda Sevenfifty
Oh pa to naravno :moto3:
Ali sta cu kad sam odrastao uz Mad Max-a :care:
  • BMW GS is waiting for You...what are You waiting for????, 822 postova
  • Lokacija: YU jos uvjek u 36-oj...
  • Motocikl: Wee 650
I meni se svideo kad se pojavio ali sam se debelo razocarao kad sam ga vidio uzivo...i to u onoj braon boji...
Nekako mi se bas nije svidio... Ovaj zeleni jos i lici na nesto...bar na slici
  • Lokacija:
ovo nema kod nas da se kupi?
Ima, ima ... i nije ni preterano skup, cena je 7252 evrića ... :)
Ali verzija Cafe Style je za sada samo za japansko tržište ... :(
