Slike preradjenih TRANSALPa, AFRIKA, i ostalih velikih enduro motora.
  • Svrati ponekad, 154 postova
  • Lokacija: Kac
Dakle, ako neko ima neka postavi slike ovih motora. Izuzetno brutalno izgledaju. Ako neko ima neka postavi. Hvala i pozdrav.
Za pocetak, ovako nesto.
  • Drug član, 1116 postova
  • Lokacija: Tvrdos
  • Motocikl: ZUNDAPP KS 750
obe slike sam ja vec stavio na forum prije a ako te ovo bas zanima imas evo ti link http://www.advrider.com/forums/showthread.php?t=50630&page=4&highlight=africa+twin tu imas preko 100 prerada afrike i transalpa
  • Drug član, 1372 postova
  • Lokacija: Mladenovac
Onaj Versys izgleda bas interesantno! Jel moz' neko da mi pojasni sta je ono obmotano oko izduvnih grana ???
Pa ja bi rekao da su to azbestne trake, a mozda se i varam ???
  • Drug član, 2247 postova
  • Lokacija: Beograd/Šumadija
Moja omiljena  ;D ;D ;D
Mods:
- Wiseco 46 mm pistons and sleeves (848 cc)
- Reworked crankcase and ducts
- Lightened crankshaft
- Lightened flywheel
- Iridium plugs
- Reinforced clutch
- Higher capacity oil pump
- Enlarged crankshaft bearings
- Rejetted carbs
- Rev limiter set at 8800 rpm
- 12.5 :1 compression
- Titanium Arrow end can (shortened)
- Hand made exhaust pipes
- Vacuum fuel pump (no filter)
- Magura hydraulic clutch kit
- Boano fork clamps and BMW HP2 bars
- Garmin GPS and Touratech navigational equipment
- Multi layer neoprene seat
- Hand made underseat fuel tank (10 litres)
- Excel rims 21"/18"
- Braking 260 mm front rotor
- Braided brake and clutch lines
- Marzocchi Shiver 50 mm fork
- Ohlins rear shock
- Front and rear lights by Aprilia
- Hand made front light and dash mounts
- Modified AT 650 engine protection
- African Queens protection parts
- Magura quick throttle assembly
- CRF 450 front and rear fender and side panels
- Hand made rear subframe and radiator side panels
- XR 650 foot rests
- Hand made battery mount
- Quick charge battery connector
- Michelin Desert with mousse
- Small 1 litre emergency fuel can on bars
- Fuel level inspection tube
Total cost about 10,000 euro
kako li onaj supermoto ide sa prve slike, ima jak agregat a skinuto toliko kilograma sa motora
Pogledaj mu samo zadnju gumu, isteruje čitavih 1000 km.  ;D ;D ;D
Ko kaže da je nemoguće
XRV1000  ;D ;D ;D
E upropasti ga sa ovim tockovim :o :o :o :o :o :o
Ne može drugi, pucaju žice...
Imas li jos slika ovog motora? Ili neki link...
Mislim da sam je našao na XRV forumu, davno...
