TDRr
  • Zainteresovan, 981 postova
  • Lokacija: Bgd
Model: Yamaha TDR 125
Year: 2002
Category: Allround
Rating: 78.9 out of 100.
Engine and transmission
Displacement: 125.00 ccm (7.63 cubic inches)
Engine type: Single cylinder
Stroke: 2
Power: 15.00 HP (10.9 kW)) @ 7000 RPM
Torque: 14.70 Nm (1.5 kgf-m or 10.8 ft.lbs) @ 7000 RPM
Compression: 6.6:1
Bore x stroke: 56.0 x 50.7 mm (2.2 x 2.0 inches)
Cooling system: Liquid
Physical measures
Dry weight: 128.0 kg (282.2 pounds)
Seat height: 850 mm (33.5 inches) If adjustable, lowest setting.
Wheelbase: 1,405 mm (55.3 inches)
Overall length: 2,120 mm (83.5 inches)
Overall width: 840 mm (33.1 inches)
Overall height: 1,295 mm (51.0 inches)
Ground clearance: 270 mm (10.6 inches)
Chassis and dimensions
Front suspension travel: 180 mm (7.1 inches)
Rear suspension travel: 180 mm (7.1 inches)
Front tyre dimensions: 100/90-18 56P
Rear tyre dimensions: 130/80-17 65P
Front brakes: Single disc
Front brakes diameter: 282 mm (11.1 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Power/weight ratio: 0.1172 HP/kg
  • Drug član, 2247 postova
  • Lokacija: Beograd/Šumadija
Ima ortak samo je sa Minareli agregatom i ima oznaku Belgarda. Motor je nabudzen i ima oko 25 KS :)
Motor na prvi pogled izgleda kao smanjeni KTM 950 Adventure a ima i takav polozaj za voznju samo je dosta nizi. Ide kao nenormalan a isto tako i koci jer ima brembo kocnice. Na semaforu sa Dominatorom je, kada se trkam sa njim, moram priznati znojenje do 80-100 km/h.
  • MK. Sirius - Srbija, 806 postova
  • Lokacija: Pancevo
  • Motocikl: KTM Supermoto T 990 '11, Piaggio Beverly Tourer 250ie '08
Ovaj motor ima 15 KS u zatvorenom stanju(na 7000rpm se otvara exup ventil i tek onda razvija vecu snagu,a dok je u zatvorenom(fabrickom) stanju ventil se ni ne otvara,koliki god da je broj obrtaja).
Tako da ima 30tak KS,kao i druge 125ice cvaje..
Da bi isao dobro,mora de se drzi u visokom broju obrtaja,zahteva koriscenje dobrog ulja za mesavinu.Prilicno udoban motor,tezina mu nije velika.
Sve u svemu,ako nije mnogo presao,i u ocuvanom je stanju,prava odluka!
Guest gasa
kupio sam ga, 93 godiste je ali je presao pravix 18000km, videce oni koji dodju na trku u Vrsac!!!!!
samo mi treba slika instrument table negde oko tog godista, i slika oko onog za pustanje goriva!!!
ako neko ima neka mi posalje, molim vas!!!!
  • Svrati ponekad, 161 postova
  • Lokacija: Crna Gora
kupio sam ga' date=' 93 godiste je ali je presao pravix 18000km, videce oni koji dodju na trku u Vrsac!!!!!
ako neko ima neka mi posalje, molim vas!!!![/quote']
kOLIKO SI GA PLATIO???????????/mENE TAKODJE INTERESUJE TAJ MOTOR. NASO SAM GA U SLOVENIJU ZA 1500E AL 2003GOD AKO IMA NEDJE PO SRBIJI ILI CRNOJ GORI JAVITE MI NA cole.kl@cg.yu
