Jakna Kushitani Shun
  • Enduraš, 6692 postova
  • Lokacija: Paracin
  • Motocikl: 450MT
Kushitani: Shun Gore-Tex Jacket
Material: schoeller-dynatec; Original Cordura by INVISTA
lining: nylon taffeta
Details:
•windproof, waterproof and breathable by GORE-TEX z-liner
•DuPont Teflon treatment
•POWERTECTOR CE protectors at elbow and shoulder, at elbow height can be adjusted
•pocket for CE protector at back
•large reinforcement from schoeller-dynatec at elbow area
•padded areas at chest and back area
•reflective pipings and area from 3M Scotchlite at back and shoulder area
•luxurious detachable thermal lining with front cover
•thermal insulation made from 100g Thermolite Active by INVISTA
•comfort collar
•stretch areas above of elbow, at shoulder and back area and at front hem
•hem width adjustment by side flaps
•waist width adjustment by covered cords
•double sleeve width adjustment
•2 plain covered outer pockets with labyrinth closure
•waterproof document pocket
•inside pockets
•tight fitting cuff by GORE-TEX STORMCUFF, with long zipper for easy use
•fixed labyrinth front closure
•S-VENT front ventilation
•KUSHITANI crotch belt
•long connection zipper
Otvori za ventilaciju, kao i ziperi za podesavanje sirine jakne u grudima:
Dupli dzepovi, unutrasnji manji vodonpropusni i spoljni veci
Lastez koji membranu drzi uz ruku, tako da ne ulazi voda i kad se nose kratke rukavice po kisi
Zadnji dzep ima traku koja ide izmedju nogu do prednjeg dela jakne gde se pricvrsti i onemogucava podizanje jakne
Postava od Thermolite active materijala, tanka, a izuzetno topla. Nova je, nisam je stavio vise od dva puta.
Kad sam kupio jaknu, nije bilo ledjnog protektora, u medjuvremenu sam ga kupio, ide i on. Inace sto se tice protektora u jakni, vrhunski su, recimo na laktovima su toliko dugacki da pokrivaju kompletnu podlakticu
Jaknu sam nosio nekoliko sezona, pa ima sitnih tragova koriscenja, sto cete videti u sledecoj slici, ali nije nigde pocepana i oguljena. Ovo sto se vidi na slici se ne vidi kad se jakna obuce niti utice na vodonepropusnost.
Jakna je nosena po najvecim pljuskovima i celodnevnoj kisi, nikad kap nije propustila. Zahvaljujuci ventilaciji i goretex membrani, prijatno je u njoj i na +30, dok god se krecete nema potparavanja. Ima puno podesavanja - za struk, rukave, okovratnik itd. Prodajem je jer mi je sad mala (nije se ona smanjila, nego se ja povecao:) ), da mogu da najdem ponovo bi uzeo istu jaknu bez razmisljanja. Ima ukupno 8 dzepova, od toga 6 vodonepropusna + 2 na postavi
Velicina je 52, znaci za nekog oko 180cm i 75-80kg. Ja sam 183 visok i dok sam imao 75-80 kg bila mi je taman, sad sam blizu 90 i tesna mi je.
S obzirom da je nova kostala 500e, mislim da je 150e korektna cena.
tel 064 255 96 26
  • Drug član, 1520 postova
  • Motocikl: KTM 990 Adventure, KTM Lc4 Adventure-R 640
... Prodajem je jer mi je sad mala (nije se ona smanjila, nego se ja povecao:) )...
Zbog takve jakne vredi smršati, al` stvarno :aha:
  • Lokacija: Paracin
  • Motocikl: 450MT
Prodaja stopirana privremeno, poslao potencijalnom kupcu, ostaje mogucnost da je vrati ako ne odgovara broj.
