SUZUKI B-KING
  • Svrati ponekad, 208 postova
  • Lokacija: Bicske Hungary
  • Motocikl: BMW K1200 LT
Dal je neko vozio ili ima,nesto ga merkam za sledeci motor procitao sam dosta ali mi bi trebao i neko ko je vozio.Naravno ako nije na mestu pitanje ,brisi.
General information
Model: Suzuki B-King
Year: 2008
Category: Allround
Rating: 82.2 out of 100. Show full rating and compare with other bikes
Price as new (MSRP): US$ 12899. Prices depend on country, taxes, accessories, etc.
Engine and transmission
Displacement: 1340.00 ccm (81.77 cubic inches)
Engine type: In-line four, four-stroke
Compression: 12.5:1
Bore x stroke: 81.0 x 65.0 mm (3.2 x 2.6 inches)
Fuel system: Injection
Fuel control: DOHC
Ignition: Digital/Transistorized
Lubrication system: Wet sump
Cooling system: Liquid
Gearbox: 6-speed
Transmission type,
final drive: Chain
Chassis, suspension, brakes and wheels
Front suspension: Inverted telescopic, coil spring, fully adjustable spring preload, adjustable rebound damping and adjustable compression damping
Rear suspension: Link-type, gas/oil damped, fully adjustable spring preload, adjustable compression and rebound damping
Front tyre dimensions: 120/70-ZR17
Rear tyre dimensions: 200/50-ZR17
Front brakes: Double disc
Rear brakes: Single disc
Physical measures and capacities
Dry weight: 235.0 kg (518.1 pounds)
Seat height: 805 mm (31.7 inches) If adjustable, lowest setting.
Overall height: 1,085 mm (42.7 inches)
Overall length: 2,220 mm (87.4 inches)
Overall width: 800 mm (31.5 inches)
Ground clearance: 120 mm (4.7 inches)
Wheelbase: 1,525 mm (60.0 inches)
Fuel capacity: 16.50 litres (4.36 gallons)
Other specifications
Starter: Electric
Color options: Gray/Silver, Black/Matte Black
Further information
Parts and accessories Our partner CMSNL ships low cost OEM motorcycle parts to Australia, Austria, Bahamas, Belgium, Canada, China, Croatia, Cyprus, Czech Republic, Denmark, Estonia, Finland, France, Germany, Greece, Hong Kong, Hungary, Iceland, India, Ireland, Italy, Japan, Kuwait, Latvia, Lithuania, Luxembourg, Macedonia, Malta, Montenegro, The Netherlands, New Zealand, Norway, Poland, Portugal, Serbia, Slovakia, Slovenia, South Africa, Spain, Sweden, Switzerland, Taiwan, Ukraine, United Kingdom, The United States and more. Or check out parts and accessories from our other partners.
Ask questions Join the 08 Suzuki B-King discussion group.
Insurance, loans, tests Check out insurance here. Search the web for dealers, loan costs, tests, customizing, etc.
Related bikes List related bikes for comparison of specs
  • Svrati ponekad, 240 postova
  • Lokacija: Banja Luka, BiH
  • Motocikl: BMW 1600 GTL, Vespa PX 200
Beric je kupio B-kinga prošle godine i prodao meni svog GSR-a, kontaktiraj ga, on može reći iz prve ruke čovjek ga ima u vlasništvu.
  • BMW GS is waiting for You...what are You waiting for????, 822 postova
  • Lokacija: YU jos uvjek u 36-oj...
  • Motocikl: Wee 650
Brutalan i pitom...vozi se lako i na 100 i na 200konja... Nema mana..
http://bikepics.com/pictures/2131178/
Malo slika...poredjenje gabarita sa zzr1400
  • U prolazu, 11 postova
  • Lokacija: Vozdovac
  • Motocikl: Suzuki Bandit 600 s ,Yamaha r6
Nije valjda da ovde nema nikog ko bi iz prve ruke napisao nesto o ovom motoru...razmisljam da se ponovim tim motorom mozda cak i sledece godine,pa me zanimaju par sitnica. na pr. kakav je na duzim putovanjima sto se tice udobnosti,kakav je za gradsku voznju s obzirom da ima preko 250kg sa svim tekucinama. jel mnooogo opasno da sa 600 predjem na 1300ccm :) ...
  • Motocikl: Wee 650
Motor nema mana. Jedino sto bi eventualno mogao biti problem je ako si visok(recimo preko 190cm),malo teze staju noge pod one plastike na rezervoaru. Malo je rastojanje od nogara do bocnih plastika. Ja sam 185 i noge mi staju knap. I to sa da rijesiti posebnim adapterom pomocu kojeg se mejnja polozaj nogara.
Nema opasnosti da predjes na 1300ccm jer gas je u glavi a ne u ruci :) Dodajes ga srazmjerno vremenu provedenom na tom motoru...Ako si dobro "izbazdaren",neces imati problema sa tom snagom! Znaces je iskoristiti kad zatreba a ostalo vrijeme ga vozis kao 600tku... Dugme za polovljene snage je po meni totalno bespotrebno. Mislim da ce ti vise odmagati nego pomagati. Ima logike samo ako se slucajno zateknes sa losim gumama na losoj,mokroj podlozi...
Hvala puno na odgovoru.Sada,kada cujem pohvale iz prve ruke,motor mi se jos vise svidja :) Visok sam 176,tako da ne verujem da cu imati problema sa sedenjem na njemu.Isto tako,upravu si za brzinu i snagu.Ja sam sa 50 seo na 600 i prve sezone isao na more,par tura po srbiji,a i u Beogradu nisam silazio sa motora.Nisam imao ni 1 problem vezano za brzinu,snagu ili to sto nisam nikad vozio motor sa menjacem pre tih 600ccm. Nisam vise klinac,tako da ne sumnjam da cu uzivati u voznji b kinga. Sta da kazem,skipljam parice pa se nadam prinovi pocetkom sl sezone. Pozdrav i jos jednom hvala :)
  • Motocikl: Wee 650
Brzo ces skontati,da rijetko kad silazis ispod trocifrene brojke,vjeruj mi... Najbitnija je "interna revizija" vlastitog ponasanja i nacina voznje. To jedan od razloga zbog kojih sam sada na "hladjenju"... :)
  • U prolazu, 22 postova
  • Lokacija: Munze
  • Motocikl: Suzuki GSX1300BK (B-King), Yamaha Fazer FZ6
Upravo ga uzeo... prezadovoljan sam nakon par stotina km. Naravno, kao što je primetio igor-gs, one plastike na rezervoaru smetaju malo, visok sam 195... nije da se nisam navikao, ako neko zna kako izgledaju ti adapteri neka stavi ovde.
  • Svrati ponekad, 302 postova
  • Lokacija: reci dje si i eto me tu sam
  • Motocikl: Pan američki onaj
ja mog prodao pre par meseci i mogu reci da je jedini motor za kojim zalim (ali situacije je bila takva da sam ga morao prodati)
nadam se da ce suzuki opet vratiti kinga u serisku prizvodnju posto bi ga verovatno bez razmiljanja opet uzeo
  • U prolazu, 20 postova
  • Motocikl: Kawasaki Z1000R (2017)
Caos ljudi, da li neko zna čiji je crni B King sa Arrow izduvima? Bio je danas pored mene na semaforu u Savskoj i pravi je lepotan :)
  • Drug član, 4288 postova
  • Lokacija: CH-HR-BiH
  • Motocikl: 2002 K1200RS-1989 XTZ 750 Chesterfield- 1989 XTZ 750 FarawayBlue, 1985 Honda XLV750-RD01
B-King je bio i vazda će biti KING.
Vozim motor a nisam bajker.....
