Triumph Speed Triple 2011
  • Ne silazi, 5817 postova
  • Lokacija: Minhen
  • Motocikl: Kawasaki H2 SX SE '23 / Triumph R3 Storm R '24
I ove slike su procurele, ali ponovo nema slike kompletnog motorcikla. Nadam se da će Triumph izložiti svoje modele na Intermotu, pa ćemo ubrzo imati još slika.
  • Lokacija: Minhen
verovatno uzivo izgleda mnogo atraktivnije...
Što ga ne ubaci ovde?
The 2011 Speed Triple now makes 135bhp of smooth, effortless power at 9,400rpm and 82lb/ft of torque at 7,750rpm. Weight is now 214kg/472 (wet). Compare those figures to 128bhp at 9,250rpm, 76lb/ft at 7,550rpm and 217kg/477lbs for the outgoing model. That’s a fairly unimpressive improvement given the all-new frame, so let’s reserve judgement until we can compare apples to apples, the new weight might be with a full tank of fuel while the old one is listed without.
1kg/2.2lbs has allegedly been shed by each wheel, reducing unsprung weight and the new 43mm USD forks are fully adjustable.
Regardless of precise mechanical spec, the biggest changes here are the new looks and the addition of optional ABS, likely to prove popular with people who see the Triple as a practical sportsbike and use their bikes for commuting as well as recreation.
  • Lokacija: Minhen
Evo konačno slika sa Intermota ;)
1050 kubika, 5 konja više nego ranije (ukupno 135), novi cevasti aluminijumski ram, aluminijumski točkovi po kilogram lakši, motor ukupno 8 kg lakši od prethodnog, obrtni momenat 11.5 kgm pri 7750 obrtaja.
