djura 28 Napisano Februar 8, 2008 Drug član, 2245 postova Lokacija: Beograd Prijavi odgovor kao problematičan aj da ne otvaram novu temu....Svaba i ja kupili po jednu Hornet DS...pa nek' ide zivot... On ovu crnu: a ja ovu belu (koja je 20ak EUR skuplja, zivo me zanima zasto) Procitao ja kao ceo test, nahvalili je sacuvaj boze, kao silni neki patenti (sad ce Dane da se raskenja kako je to imalo da se kupi u Japanu jos 1342. godine...). Koga ne mrzi da cita: Since the Hornet-DS is a hybrid helmet fusing the capabilities of both on and off-road helmets, Shoei was able to combine the best of both worlds! With a removable shield as well as a removable visor, the Hornet-DS can be configured in three different ways to compliment all forms of motorcycle riding. With both the shield and visor fixed to the helmet, the Hornet is the perfect tool for exploring trails and back roads with your friends. The shield will keep the noise down and protect your face and eyes from bugs and dust. The visor protects your eyes from the glare of the sun, and can also deflect the roost that your buddies throw back at you in the dirt. If the trails get really tight or muddy, the rider can opt to remove the shield and ride with a pair of goggles. If the rider has to do some high-speed highway commuting to get to their favorite trail, the visor can be removed to completely eliminate the buffeting that can be caused by a visor. The visor on the Hornet-DS was one of the most carefully thought out parts of the helmet. Not only is does it protect the rider from roost and glare, but it is actually part of the ventilation system of the helmet. To begin with, the visor is positioned slightly higher on the top of the helmet than a typical off road helmet for optimal visibility. The wedge shape visor was designed in Shoei’s in-house wind tunnel to reduce uncomfortable wind resistance and buffeting. The reduction of drag and lift help eliminate neck fatigue and keep the rider more comfortable during long stints in the saddle. The Hornet-DS comes equipped with a 2mm thick 3-dimensionally curved shield that can be positioned in 4 different locations from fully closed to fully open. The shield can also be removed so the helmet can be used with goggles. Shields for this helmet are available in clear and light smoke tints and block 99% of UVA and UVB rays. Ventilation was a primary concern when designing the Hornet-DS. Long days of riding combined with the relatively low speeds typically encountered while dual sporting create a real challenge for designers who are trying to develop effective ventilation. The Hornet-DS has one of the most advanced ventilation systems ever found on a motorcycle helmet. With four intake and three exhaust vents, the Hornet-DS is up to the task of keeping a rider cool and dry in even the most extreme conditions. The stylish nose cover on the Hornet-DS is equipped an internal deflector mechanism that forces fresh air upward to help prevent fogging of the shield. The nose cover vent is also equipped with a shutter to enable to user to shut the vent if they choose to. The nose cover vent is easy to remove and disassemble, making cleaning a snap. The upper intake on the Hornet-DS is a real engineering feat. The intake is positioned in the center of the visor, taking advantage of the ram-air effect and forcing air through a gasketed seal into the top of the helmet. The ram-air vent is mated with traditional forehead vents to ensure effective ventilation. After entering the helmet, the air travels through channels set between the layers of Shoei’s exclusive Semi-Dual EPS liner. Not only does this two piece expanded polystyrene liner offer better ventilation, but the utilization of dual density EPS foam allows for improved impact absorption performance as well. All of this fresh air coming in would do you no good if the hot air had nowhere to go. The Hornet-DS is equipped with two Cross Vortex exhaust vents and a neck outlet that are positioned to take advantage of low air pressure zones at the rear of the helmet that actually work to draw hot air from the helmet. Ventilation is only part of what makes the Hornet DS the most comfortable dual sport helmet in the world. The Hornet-DS is fitted with Shoei’s 3D interior system. Shoei’s 3D interiors use several different densities of foam in shapes corresponding to the shape of the rider’s head to ensure not only a comfortable feel, but superior stability in high speed riding. Shoei utilizes our 3D Max Dry liner material for the interior of the Hornet-DS. This proprietary blend of fibers is capable of absorbing 35 times its weight in moisture. The Hornet-DS’ 3D interior is completely removable, making cleaning easy. Shoei offers range of cheek pad sizes to allow for a custom-fitting option. Our cheek pads even feature slits so you can comfortably wear eyeglasses inside your helmet. A chin curtain is added to the Hornet DS for additional comfort. The chin curtain prevents wind from entering the bottom of the helmet, reducing noise and increasing comfort on cold days. Safety is always the number one priority here at Shoei, and the Hornet DS has many features which help it live up to Shoei’s reputation for safety and quality. The AIM+ shell construction of the Hornet DS is a multilayered composite utilizing several different materials with different properties to create a shell that is very rigid and light weight. This rigid shell is mated with a three piece EPS (expanded polystyrene) liner system that utilizes varying densities of EPS. This allows the EPS to “give” more easily in light impacts (helping to reduce concussions), while still providing protection from severe forces. Shoei even utilizes EPS in the chin bar area of our helmets to protect your face. This is something that isn’t even required by Snell or the DOT! Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
dane@ 99 Napisano Februar 9, 2008 Drug član, 1777 postova Lokacija: Sibir Prijavi odgovor kao problematičan te patente jos samuraji koristili da ih ladi dok seku... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Mikka 431 Napisano Februar 9, 2008 In Mud We Trust, 1918 postova Lokacija: BGD Motocikl: 950ADV Prijavi odgovor kao problematičan Glisto, opet kenj... ! ;D e super su vam slemici ! bravo ! kad ce revija da ih vidimo uzivo ? Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
mrgood 0 Napisano Februar 9, 2008 U prolazu, 8 postova Lokacija: Bijeljina Motocikl: bmwf800gs Prijavi odgovor kao problematičan aj da ne otvaram novu temu....Svaba i ja kupili po jednu Hornet DS...pa nek' ide zivot... On ovu crnu: a ja ovu belu (koja je 20ak EUR skuplja, zivo me zanima zasto) Procitao ja kao ceo test, nahvalili je sacuvaj boze, kao silni neki patenti (sad ce Dane da se raskenja kako je to imalo da se kupi u Japanu jos 1342. godine...). Koga ne mrzi da cita: A gdje ste pazarili ako nije tajna? Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
djura 28 Napisano Februar 9, 2008 Drug član, 2245 postova Lokacija: Beograd Prijavi odgovor kao problematičan Glisto, opet kenj... ! ;D e super su vam slemici ! bravo ! kad ce revija da ih vidimo uzivo ? Fala Mikko. Pusti glistu, njemu poklanjaju kacige, pa nema potrebe da se mlati ovako kao mi, obicni smrtnici. Revija ide za 20ak dana cim stigne Svaba iz USA. Mrgoode, kupljene su ovde: http://www.shoei-helmets.com/road/ Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
dane@ 99 Napisano Februar 9, 2008 Drug član, 1777 postova Lokacija: Sibir Prijavi odgovor kao problematičan Mogli ste i Komi jednu da narucite. Sramota da decko nema u cemu da vozi motor... Ali dobro, ti imas svoj tabor, svoje prijatelje... Mozda nisam moro da se mucim za svoju kacigu, ali zato me ta tvoja zakla... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
djura 28 Napisano Februar 9, 2008 Drug član, 2245 postova Lokacija: Beograd Prijavi odgovor kao problematičan Mogli ste i Komi jednu da narucite. Sramota da decko nema u cemu da vozi motor... nema tamo tako velikih kalupa ;D Ne znaju japanci kakvi medjedi ovde zive pa se zaustavili na 2XL Nisam ja narucivao nista, samo sam dobio email sa sajta da je kupljeno to i to. Nemam vise kontrolu nad svojim zivotom... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
dane@ 99 Napisano Februar 9, 2008 Drug član, 1777 postova Lokacija: Sibir Prijavi odgovor kao problematičan Za veliku pamet mora velika glava. I cetri noge ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
sasa umag 11 Napisano Februar 9, 2008 , 1322 postova Lokacija: Umag HR Prijavi odgovor kao problematičan I cetri noge ;D necete valjda Komi ugradjivati pomocne kotacice ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
dr.chala 3 Napisano Februar 10, 2008 Zainteresovan, 541 postova Lokacija: Zagreb Prijavi odgovor kao problematičan djura dal sam ti radit naljke Milicija za kacigu! ;D Jel još u trendu petokraka ili da metenem nekaj drugo???? ??? Dugine boje npr. :o Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
djura 28 Napisano Februar 10, 2008 Drug član, 2245 postova Lokacija: Beograd Prijavi odgovor kao problematičan djura dal sam ti radit naljke Milicija za kacigu! ;D Jel još u trendu petokraka ili da metenem nekaj drugo???? ??? Dugine boje npr. :o petokraka je Mikkin domen, ja planiram ovako nesto da stavim: ;D ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
zozon 6 Napisano Februar 10, 2008 Zainteresovan, 554 postova Lokacija: Banatsko Novo Selo Prijavi odgovor kao problematičan Glisto, opet kenj... ! ;D e super su vam slemici ! bravo ! kad ce revija da ih vidimo uzivo ? Fala Mikko. Pusti glistu, njemu poklanjaju kacige, pa nema potrebe da se mlati ovako kao mi, obicni smrtnici. Revija ide za 20ak dana cim stigne Svaba iz USA. Mrgoode, kupljene su ovde: http://www.shoei-helmets.com/road/ E da, Mikko gde si ti kupio tvoju Arai kacigu, kol'ko te kostala ? ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
dane@ 99 Napisano Februar 11, 2008 Drug član, 1777 postova Lokacija: Sibir Prijavi odgovor kao problematičan joj djuro kak ce to krasno bit... ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
franc 0 Napisano Februar 11, 2008 U prolazu, 42 postova Lokacija: Zagreb Prijavi odgovor kao problematičan povoljno prodajem Arai tour-x, veličina medium, srebrne boje nošena dvije sezone, s puno ljubavi i malo kilometara glava mi je Shoei... i jebem ja svakog metrrosexualca sa sivim bmw-om koji nema shoei! Arai je za dokazane pedere poput ona dva engleza (dobro, englez i škot), koji kao fol putuju po svijetu uz kamionsko-kamermansku pratnju Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
sasa umag 11 Napisano Februar 11, 2008 , 1322 postova Lokacija: Umag HR Prijavi odgovor kao problematičan povoljno prodajem Arai tour-x, veličina medium, srebrne boje nošena dvije sezone, s puno ljubavi i malo kilometara taman moja velicina,javi se ako je odlucis dati u dobrotvorne svrhe ;D ;D,e siroti mi Talijani sto kaze Chala :D a za uzvrat obecajem da nikada necu kupiti Stroma ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
djura 28 Napisano Februar 11, 2008 Drug član, 2245 postova Lokacija: Beograd Prijavi odgovor kao problematičan povoljno prodajem Arai tour-x, veličina medium, srebrne boje nošena dvije sezone, s puno ljubavi i malo kilometara a ja sto sam je nosio od Novigrada do Rovinja i nazad...po kisi, vetru......buri....govnima...??! Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
sasa umag 11 Napisano Februar 11, 2008 , 1322 postova Lokacija: Umag HR Prijavi odgovor kao problematičan povoljno prodajem Arai tour-x, veličina medium, srebrne boje nošena dvije sezone, s puno ljubavi i malo kilometara a ja sto sam je nosio od Novigrada do Rovinja i nazad...po kisi, vetru......buri....govnima...??! jadan...stvarno si se napatio tih 50 kilometara :D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
djura 28 Napisano Februar 11, 2008 Drug član, 2245 postova Lokacija: Beograd Prijavi odgovor kao problematičan povoljno prodajem Arai tour-x, veličina medium, srebrne boje nošena dvije sezone, s puno ljubavi i malo kilometara a ja sto sam je nosio od Novigrada do Rovinja i nazad...po kisi, vetru......buri....govnima...??! jadan...stvarno si se napatio tih 50 kilometara :D a 50 nazad? ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
dr.chala 3 Napisano Februar 11, 2008 Zainteresovan, 541 postova Lokacija: Zagreb Prijavi odgovor kao problematičan djuro kaj fakat istina da ti ne dolazi SHOEI,nego ARAI??? Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
djura 28 Napisano Februar 11, 2008 Drug član, 2245 postova Lokacija: Beograd Prijavi odgovor kao problematičan djuro kaj fakat istina da ti ne dolazi SHOEI,nego ARAI??? jbte...kako vesti u Hrvatskoj brzo putuju. Vidim sigurnosno obavještajni sustav radi perfektno. Evo ti ga c/p sa vstrom info (onog Bujanovicevog ;D ): mali update....nista od Horneta :( : Ovo je stiglo danas: this item you purchased is currently out of stock and eta is around Late Feb according to our distributor. Please let me know if you would like to back order it or if you would like to cancel the order and we can refund your paypal payment in full. Our Toll Free number is 1-877-484-4860 thanks charlie A kraj februara je prekasno.... Na kraju kupih ovo: A makar se slaze uz motor... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
zozon 6 Napisano Februar 12, 2008 Zainteresovan, 554 postova Lokacija: Banatsko Novo Selo Prijavi odgovor kao problematičan Arai je za dokazane pedere poput ona dva engleza ;D ;D ;D Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
zekazmaj 16 Napisano Februar 12, 2008 Svrati ponekad, 270 postova Lokacija: Zemun Motocikl: BMW R1100GS Prijavi odgovor kao problematičan Ja sam hteo da kupim CABERG justissimo. Medjutim omasim nekoliko dana i u februaru prodje popust za koji nisam ni znao da traje. A sada ste me skroz pokolebali. Hajde na kraju sta covek da kupi a da bude oko 200-300 eur? Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
GS 252 Napisano Februar 12, 2008 Zainteresovan, 572 postova Lokacija: Han Pijesak ,BiH Motocikl: KTM EXC 450, Suzuki RM 125 ,Kawasaki KLX 300R ,Kawasaki KMX 125, Yamaha DT 125R Prijavi odgovor kao problematičan Ja sam hteo da kupim CABERG justissimo. Medjutim omasim nekoliko dana i u februaru prodje popust za koji nisam ni znao da traje. A sada ste me skroz pokolebali. Hajde na kraju sta covek da kupi a da bude oko 200-300 eur? Ako ti odgovara velicina 60 imam pravu kacigu za tebe: BMW sistem 4 EVO ,dokupis sild (dodatna oprema ,nije skup) i imas kacigu za off road .Bijela boja , preklopna i uz dodatnu opremu(moze se poruciti kod Radulovica) se moze koristiti kao jet sa vizirom, jet sa sildom, enduro sa sildom bez vizira i integralna samo sa vizirom. Nosena jednu sezonu u pola cijene nove! Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
dane@ 99 Napisano Februar 12, 2008 Drug član, 1777 postova Lokacija: Sibir Prijavi odgovor kao problematičan Ja sam hteo da kupim CABERG justissimo. Medjutim omasim nekoliko dana i u februaru prodje popust za koji nisam ni znao da traje. A sada ste me skroz pokolebali. Hajde na kraju sta covek da kupi a da bude oko 200-300 eur? Pazi ovaj Arai ti je oko 400-500 eur, ovde u Evropi... Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
