aca-pn
Sve što je postavio član: aca-pn
  1. sta ce im dokaz, rec njih dvojice se vise racuna nego njegova, ako mislis da ide na foru da se pravi blesav da nije bio on jer nema fotografije/snimka
  2. Prodaja stopirana privremeno, poslao potencijalnom kupcu, ostaje mogucnost da je vrati ako ne odgovara broj.
  3. Zar zabrana po novom ne vazi za sve kategorije ?
  4. Ne sviraj, nego se prijavljuj Koma kakva je podloga na stazi, nikad nisam vozio po Kopaoniku, a jos manje na takmicenju, pa da znam sta me ocekuje ?
  5. Mene zanima koja je fora sa predajom organizaciji malih motora, čemu to ? Послато са HTC One S уз помоћ Тапатока
  6. Otvori posebnu temu za ovo, vredi !! Uhhh jedva cekam
  7. U stvari 600, toliko si naveo da kosta ako se dobro secam
  8. aca-pn
    BJB enduro fanovi
    za 220 su bile ok dimenzije
  9. Nosio sam za vikend Kushitani jaknu i ipak mi je pretesna, ne mogu vise da je nosim, zato evo je u oglasima: http://forum.bjbikers.com/index.php?/topic/100627-jakna-kushitani-shun/page__p__1617216__fromsearch__1#entry1617216
  10. Onda je kupi, pa smrsaj
  11. Kushitani: Shun Gore-Tex Jacket Material: schoeller-dynatec; Original Cordura by INVISTA lining: nylon taffeta Details: •windproof, waterproof and breathable by GORE-TEX z-liner •DuPont Teflon treatment •POWERTECTOR CE protectors at elbow and shoulder, at elbow height can be adjusted •pocket for CE protector at back •large reinforcement from schoeller-dynatec at elbow area •padded areas at chest and back area •reflective pipings and area from 3M Scotchlite at back and shoulder area •luxurious detachable thermal lining with front cover •thermal insulation made from 100g Thermolite Active by INVISTA •comfort collar •stretch areas above of elbow, at shoulder and back area and at front hem •hem width adjustment by side flaps •waist width adjustment by covered cords •double sleeve width adjustment •2 plain covered outer pockets with labyrinth closure •waterproof document pocket •inside pockets •tight fitting cuff by GORE-TEX STORMCUFF, with long zipper for easy use •fixed labyrinth front closure •S-VENT front ventilation •KUSHITANI crotch belt •long connection zipper Otvori za ventilaciju, kao i ziperi za podesavanje sirine jakne u grudima: Dupli dzepovi, unutrasnji manji vodonpropusni i spoljni veci Lastez koji membranu drzi uz ruku, tako da ne ulazi voda i kad se nose kratke rukavice po kisi Zadnji dzep ima traku koja ide izmedju nogu do prednjeg dela jakne gde se pricvrsti i onemogucava podizanje jakne Postava od Thermolite active materijala, tanka, a izuzetno topla. Nova je, nisam je stavio vise od dva puta. Kad sam kupio jaknu, nije bilo ledjnog protektora, u medjuvremenu sam ga kupio, ide i on. Inace sto se tice protektora u jakni, vrhunski su, recimo na laktovima su toliko dugacki da pokrivaju kompletnu podlakticu Jaknu sam nosio nekoliko sezona, pa ima sitnih tragova koriscenja, sto cete videti u sledecoj slici, ali nije nigde pocepana i oguljena. Ovo sto se vidi na slici se ne vidi kad se jakna obuce niti utice na vodonepropusnost. Jakna je nosena po najvecim pljuskovima i celodnevnoj kisi, nikad kap nije propustila. Zahvaljujuci ventilaciji i goretex membrani, prijatno je u njoj i na +30, dok god se krecete nema potparavanja. Ima puno podesavanja - za struk, rukave, okovratnik itd. Prodajem je jer mi je sad mala (nije se ona smanjila, nego se ja povecao:) ), da mogu da najdem ponovo bi uzeo istu jaknu bez razmisljanja. Ima ukupno 8 dzepova, od toga 6 vodonepropusna + 2 na postavi Velicina je 52, znaci za nekog oko 180cm i 75-80kg. Ja sam 183 visok i dok sam imao 75-80 kg bila mi je taman, sad sam blizu 90 i tesna mi je. S obzirom da je nova kostala 500e, mislim da je 150e korektna cena. tel 064 255 96 26
  12. Resenje tvog problema trazi kod psihologa, ovde ga neces naci.
  13. Ovo je drzalo mnogo duze posto je majstor otisao, vidis da je drzalo i kad nije trebalo
  14. Kad pre Sta si uzeo ?
  15. aca-pn
    BJB enduro fanovi
    Imao sam kdx220, imao je gume 90/90-21 i 120/90/18
  16. Ja sam cuo za slucajeve da su se ljudi mucili i ostavljali nategnute radapcigere po dva dana, ali jos nisam cuo da je neko morao da sece magnet, izgleda si bas maler..
  17. A jesi li probao kombinaciju svega toga, da nategnes radapcigerom, grejes magnet i onda naglo ohladis osovinu co2 gasom ? Mada opet, ne znam koliko je pametno tako kaliti osovinu.
  18. Sto je procvetalo drvece u Vinci, jos ne videh tako velike cvetove
  19. Strit gard mi se ne svidja, najvise pucam na RP2. U stvari najvise bi voleo kad bi nasao kushitani istu kao sto imam, samo broj vecu, ali slabo ih ima. Kad nadjem drugu jaknu, prodacu kushitani i jos jednu dainese.
  20. U neku ruku si u pravu, ali da ja tako razmisljam ne bi se navozao motora Garantujem da je mnogostruko veca mogucnost da se nesto desi u saobracaju, narocito gradskoj guzvi, nego na nekom puteljku u sumi.
  21. Gledao sam, ako ne nadjem ovde to mi je otvorena opcija.
  22. Nije za tebe enduro cim si odustao od voznje posle prve bare, a kako vidim imas dobre gume Ipak i setnja ima svojih cari
  23. Za takve prsluke kazu da su nezamenjivi na visokim temperaturama, voznja po pustinjama i slicno, nisam video da kod nas ima tako nesto da se kupi. Potrazite ne netu coolig vest, videcete.
  24. Stvarno prelep, jedan od najlepsih copera, kruzera ili kako se vec zovu.
