gosa 553 Napisano April 11, 2013 Drug član, 2150 postova Lokacija: Beograd Motocikl: africa twin, ktm, cb750 boldor, dylan Prijavi odgovor kao problematičan prodajem punjac IMAX B6AC za akumulatore i sve vrste baterija, cena 55e, tel 063 229803 Feature: 1. High-power and high-performance circuit 2. Microprocessor controlled 3. Maximen safety: Delta-peak sensitivity, Capacity limit, processing time limit, tempreture limit, input power monitor 4. Monitoring the voltage of individual cell 5. Can charge Li-ion / LiPo / LiFe 1-6 cells, and Ni-Cd / NiMH 1 -15 cells 6. Dual Power, built-in AC adapter 7. UndefinedLarge range of charge currents 8. Store function, allows safe storage current, and data storage (Store up to 5 packs in memory) 9. Battery break in and cycling 10. Built-in temperature sensor 11. Separate voltage detector for balance charge mode. Oeration voltage range : DC 11.0 ~ 18.0 Volt or AC 100V ~ 240V 50/60Hz Circuit power : AC to DC adaptor (DC 11.0 ~ 18.0V / 5A) Max. charge power 50W Max. discharge power 5W Charge current range : 0.1~5.0A Discharge current range : 0.1~1.0A Current drain for balancing Li-Po : 300mAh/cell NiCd / NiMH battery cell count : 1~15 cell Li-Ion / Polymer cell count : 1~6 series Pb battery voltage : 2V~20V Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
