Pojacalo , Lab.Gruppen FP 10000 Q
  • Ne silazi, 2629 postova
  • Motocikl: Kawasaki GTR 1400
Znalci znaju koliko ovo kosta :)
Vrhunsko pojacalo. Kupio sam ga novog , i od prvog dana je u reku ( rek se dobija uz pojacalo , inace je oko 100ak evrica ovaj 2U rek ).
Koristili smo ga u bendu , i gurao je 4 FBT Hi maxx 60 kutije , tako da nikad nije bio ni na pola snage. Kao dokaz , skinuo sam prednje maske i slikao kondenzatore koji su i dalje kao novi i ni jedan nije naduven.
Pojacalo je jednom mesecno usisavano od prasine. Nikad nije radio pod satorom , na vasarima i sl , dakle samo restorani ( imate  stranicu Medino benda pa mozete baciti pogled )
Evo specifikacija sa neta :
 Četvorokanalno pojačalo visokog kvaliteta idalno za touring.4 x2500 po kanalu na 2 Ohm-a, 4 x 2100W po kanalu na 4 Ohm-a i 4 x 1300W po kanalu na 8 Ohm-a. Malih dimenzija i težine.
FP 10000Q
10,000 Watt 4-Channel Amplifier with NomadLink Network Monitoring and Dedicated Control for Touring Applications
Delivering Rock-Solid Reliability and Sonic Purity
The FP 10000Q is the flagship four-channel model in the FP+ Series. At the core of the FP 10000Q’s performance is the milestone that is LAB GRUPPEN’s patented Class TD® output stage, an amplifier topology that approaches the exceptional efficiency of Class D while retaining the sonic purity of proven Class B designs. Contributing to the remarkable efficiency of the FP 10000Q is a Regulated Switch Mode Power Supply (R. SMPS™ ). A highly refined and updated circuit layout optimizes the interaction of R. SMPS and Class TD to produce the extraordinary power density of the FP 10000Q.
Network Control
The FP 10000Q is shipped with a NomadLink® network interface as standard. In conjunction with DeviceControl PC software, NomadLink allows monitoring of all key amplifier parameters and remote control of power on/off, channel mutes, and channel solo functions. NB. operation of NomadLink requires the NLB 60E NomadLink Bridge &Network Controller which must be purchased separately.
Proven Ergonomics
View all key performance parameters at a glance – in real time – on the comprehensive front panel display. The FP+ provides the most complete and useful front panel indication on the market today. Bright, color-coded LEDs give clear status indication of all control activation, warnings and faults – without scrolling through menus. Conditions such as blown drivers, shorted lines, and over-temperature channels are easily recognizable. You won’t waste time trying to decipher a generic “ trouble light. ”
Under the Hood
To achieve the extreme power-to-size ratio in the FP+ Series, LAB GRUPPEN engineers refined and upgraded two proprietary technologies. Both are incorporated in all four FP+ Series amplifiers. This new generation of proprietary circuits produces more power from a smaller package while maintaining LAB GRUPPEN’s peerless reputation for sonic excellence. The ultra-efficient Intercooler® uses thousands of tiny copper cooling fins to increase exposure of the heat sink to the cooling air flow.
Twin variable-speed fans respond to temperature sensors, forcing air over the Intercooler fins in a front-to-rear flow. There are no “ end-of-tunnel” output transistors subject to greater warming and, consequently, possible premature failure.
Features
10,000 Watt, 4-channel amplifier with up to 2,500 Watts output per channel
Selectable gain plus scalable Voltage Peak Limiter (VPL) and bridge-mode operation
4 x 2,500 Watts into 2 Ohms, 4 x 2,100 Watts into 4 Ohms, 4 x 1,300 Watts into 8 Ohms, 4 x 660 Watts into 16 Ohms
Proven and reliable Class-TD output stage delivers Class A/B audio quality with Class D efficiency
Regulated Switch Mode Power Supply (R. SMPS) ensures constant power output
Intuitive DeviceControl software monitors and controls key functions
Comprehensive protection scheme including current, voltage, DC, temperature, short circuit and open load warnings
Efficient Intercooler copper cooling system dissipates more heat for extended peak output
4 x balanced analog audio inputs on Neutrik XLR* connectors
4 NL4 Neutrik speakON* output connectors
Removable dust filter grilles for increased air circulation
Rugged 2U rackmount chassis for durability in touring applications
10-Year Warranty Program*
Designed and engineered in Sweden
Specs:
General
Number of amplifier channels: 4
Peak total output all channels driven: 10000 W
Peak output voltage per channel: 150 V
Max output current per channel: 50 A peak
Max output power (all channels driven)
2 ohms: 2500 W
4 ohms: 2100 W
8 ohms: 1300 W
16 ohms: 660 W
Max output power bridged
2 ohms: Not recommended 1
4 ohms: 5000 W
8 ohms: 4200 W
16 ohms: 2600 W
1100e
Promenio član Darko Mihajlovic
