GS-911 - BMW dijagnostika
  • Drug član, 1154 postova
  • Motocikl: BMW R1200GS 2009 K25
Prodajem kinesku GS-911 dijagnostiku za BMW.
U pitanju je kopija originalne “HexCode.co.za" i radi veoma dobro, verzija software-a je 1006.3 i ne moze se updateovati.
Podrzava sledece modele (uglavnom do 2008-e):
R, F, K, G, C, S.
Ne moze se koristiti za dijagnostiku novih motocikala.
Ja sam sebi nabavio novu sa full supportom, pa ova ide na oglas.
Cena, onoliko koliko sam ja platio sa dostavom:
43€
0656929955
Miki
Promenio član m.milivojevic
Spisak svih modela sa godistima...
Ja hoću npr da uradim sinhronizaciju ESA-e i ova dijagnostika je ne vidi, zato sam se ogradio sa verzijom SW-a i podrškom za novije motocikle.
Pre par dana sam sa istom, kolegi @VR46 resetovao servis i to radi.
GS-911 version 1006.3 (PC version):
Revision History:
WWW.HEXCODE.CO.ZA
New:
    Added support for some new models:
    K1300R
    K1300S
    K1300GT
    Added Engine Syncro Lock for R-Series (K2x) - locking Idle actuators for Engine Syncronization
    Added Idle Actuator Calibration function for F- and K-Series models
    Added Reset to default for "Distance to next valve-clearance check" for F (K7x) and K-series (K4x)
    Added Service functionality for all BMS-C (F650 1 spark and C1 models) - see detailed BMS-C functionality
    Added Service functionality for all BMS-C2 (G650 and F650 2 spark models) - see detailed BMS-C2 functionality
2009-04-05
GS-911 version 904.1 (PC version):
Bugfixes:
    ABS auto identify (ABS2/iABS)
    ZFE Clear DTC issue (on ZFE High)
    MA2.4 real-time scaling
Fixes:
    incorrect flagging our software by AntiVir
New:
    F800R
    G650GS
    G450X
    Service reminders (on all models that support Service reminders)
    Idle Actuator Calibration function for all CAN-bus R-Series motorcycles
    Support reading of "Distance to next valve-clearance check" for F and K-series
    brake pad reset on K1200GT
    Switching off of lights on CAN-bus motorcycles (during diagnosis)
    Imperial and Metric units
    Automatic USB driver installation
    64bit support for XP/Vista
    Added full functionality for ABSN (including real-time values and Bleed tests)
    Enhanced BMSC real-time values (C-Series and F650 (single cylinder, single spark))
    Enhanced BMSC2 real-time values (All G650 models and F650 (2 spark, single cylinders)
    Enhanced BMSK real-time values (added values (fuel pressure, etc.), including digital outputs - all CAN-bus motorcycles)
    Plotting of Lambda sensor voltage
    New GUI (Graphic User Interface)
    Support for checking Main stand and seat-belt switch operation on C1 and C1-200
    Basic support for Tyre Pressure (RDC), Anti-theft Alarm (DWA) and Radio (RBT) control modules
    Introducing Enthusiast (max of 10 motorcycles for Service functionality) and Professional version
    Online upgrades from Enthusiast to Professional version
    Updated fault codes (current up to 2009)
2008-04-24
GS-911 version 804.1:
    R1200CL
    R1200C
    R850C (with 10pin connector)
    R850R (with 10pin connector)
    R850RT (with 10pin connector)
    F800S (Engine (BMSK) & Vehicle Electronics (ZFE) only)
    F800ST (Engine (BMSK) & Vehicle Electronics (ZFE) only)
    G650Xchallenge (Engine only)
    G650Xmoto (Engine only)
    G560Xcountry (Engine only)
    Added realtime display of Digital Input values for BMSK (some culprits that could prevent starting):
    ClutchSwitch,
    KillSwitch,
    SideStandSwitches 1&2,
    OilPressureSwitch
    Tools -> Check for Updates (if you have internet access you can check whether your version is current)
    Help -> About : lists your specific Reseller's support contact details
    Some layout changes in the way models are selected
2007-05-24
GS-911 version 705.6:
    Bug fix on F650 twin-spark ECU (BMS C-II) that had no text descriptions for fault codes.
    Made the [Cancel] button the default on the fault code erase confirmation.
    Swapped the button positions of [Erase fault Codes] & [Copy to Clipboard] buttons
    Log file is now default on
2007-05-21
GS-911 version 705.4:
    Minor cosmetic changes from Beta 704.3
    Added support for the twin-spark F650CS
    Changed versioning, the versioning now represents the year and month in which it was released.
    New Firmware update build of v0.8 for the interface
    Added a couple of models (even non-CAN K-Series)
    Added Integral ABS (I-ABS) of 1150 models
    Added Integral ABS2-CAN (I-ABS2CAN) for 2007+ (late 2006) models
    Renamed ABS3-CAN to I-ABS-CAN for clarity
    Added ABS to several K- and R-Series models
    Added R1100S
    Several miscellaneous User Interface enhancements
    Added K1200, and more R1200 and R1150 Series models
    Parsing for New ABS controller update of 1200 series
2007-01-19
GS-911 version 1.14:
    Fixed a bug that showed up as "Login failed"...
    Fixed support for 1150 and 1200 ranges showing whether a Fault code is currently present or not
    Small usability issue around the "Activation information" in the Setup window.
2007-01-17
GS-911 version 1.13:
    Minor bugfix on usability issue.
    New Firmware for your interface (v0.6)
2007-01-16
GS-911 version 1.12:
    ABSN "Failed to get Detailed information" bug fixed
    BMSC & BMSC2 Status bug fixed
    More user-friendly grouping of controllers under the Advanced Window
    Defaulting to USB under Status Window
    Added support for C-Series
    Added support for F650CS
    Removed Bluetooth option from PC app - Bluetooth is for GS-911Mobile ;-)
    Various small usability issues revised
  • Svrati ponekad, 298 postova
  • Motocikl: BMW R1200GS "13 LC
Ево и ја да се захвалим Микију,каква је то људина од човека,нисмо три поруке разменили понудио се без поговора да ми ресетује сервис на мотору :sampion:
  • Sviđa mi se 2
  • Drug član, 1477 postova
  • Lokacija: Mladenovac
  • Motocikl: k25
sto ne vozite japance kao sav normalan svet a ne ove komplikacije, pre svake voznje online seminar :D
  • Sviđa mi se 2
  • Haha 2
  • Ponosni BJB Redar, 1217 postova
  • Motocikl: Vespa ET4 150 (16. dvotočkaš)
Zainteresovan sam ako je aktuelno.
Da li može da se koristi za 2006 1200 GS ADV i kako se isčitavaju podaci?
Pazi ovako, nisam je prodao, i ne znam da li radi...
ja na 2009 nisam uspeo da procitam sta mi je potrebno, jer je za modele do 2008.
mozes da svratis, da je pokupis, da vidis da li ti sljaka, ako sljaka, to je to...
ako ne, imam ja drugu koju sam kupio za sebe, pa mozemo procitati to sto ti je potrebno...
jer ta druga radi 100%. kupio sam licencu, adapter... tj sve sto je potrebno
Ma ja se nisam kačio na forum jako dugo.
Sad sam van zemlje, vraćam se oko 15.11 pa se javljam. U BG si?
poslao sam ti poruku
Nisam ništa dobio.
Šalji na 0606627999, iMessage ili Viber. Hvala
