Ernesto 10 Napisano Jun 14, 2006 Zainteresovan, 981 postova Lokacija: Bgd Prijavi odgovor kao problematičan Drgar Mali iz Arhangela je konacno docekao svoj novi motor! Stigao je u NS danas i sklopljen je ali nije mogao da ga preuzm jer je prvi koji je uzeo ZX-14 pa mora na Masinski fakultet u Bg. Zurka povodom toga je cim se vratimo sa Trebinja tako da ocekujte i slike tada! A drugar Mali ce do tada morati da se zlopati na 4 godine staroj ZX-12-ici! Model: Kawasaki ZZR 1400 Year: 2006 Category: Sport Rating: 72.6 out of 100. Show full rating and compare with other bikes Engine and transmission Displacement: 1352.00 ccm (82.50 cubic inches) Engine type: In-line four Stroke: 4 Power: 187.00 HP (136.5 kW)) Compression: 12.7:1 Bore x stroke: 84.0 x 61.0 mm (3.3 x 2.4 inches) Fuel system: Injection. DFI with Mikuni 44mm Throttle Bodies (4) Valves per cylinder: 4 Fuel control: DOHC Ignition: TCBI with Digital Advance Starter: Electric Cooling system: Liquid Gearbox: 6-speed Transmission type final drive: Chain More details Consult a Kawasaki repair manual. Physical measures Chassis and dimensions Front suspension: 43mm Inverted Cartridge Fork with Adjustable Rear suspension: Uni-Trak with Adjustable Preload, Stepless Front tyre dimensions: 120/70-VR18 Rear tyre dimensions: 150/80-VR16 Front brakes: Double disc Rear brakes: Single disc Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Evil_Zo 9 Napisano Jun 14, 2006 U potrzi za performansama..., 3388 postova Lokacija: Chemnitz / Beograd / Herceg Novi Motocikl: KTM 690 SUPERMOTO ORANGE Prijavi odgovor kao problematičan ...Stigao je u NS danas i sklopljen je ali nije mogao da ga preuzm jer je prvi koji je uzeo ZX-14 pa mora na Masinski fakultet u Bg.... Molim te javi mi kada ce biti na masincu da skoknem do laboratorije da ga pogledam :moli: Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
drag 6 Napisano Jun 15, 2006 Svrati ponekad, 446 postova Lokacija: ADA Prijavi odgovor kao problematičan Front tyre dimensions: 120/70-VR18 Rear tyre dimensions: 150/80-VR16 Ovo meni nije jasno :roll: Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
AreOut 8 Napisano Jun 15, 2006 Zainteresovan, 978 postova Prijavi odgovor kao problematičan Front tyre dimensions: 120/70-VR18 Rear tyre dimensions: 150/80-VR16 Ovo meni nije jasno :roll: Heheh i meni je zapalo za oko. front 120/70ZR17M/C rear 190/50ZR17M/C Ovo su naravno prave dimenzije Btw sta reci za motor koji bije 280 cetvrtom, samo da nije te blokade na 300 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
AreOut 8 Napisano Jun 15, 2006 Zainteresovan, 978 postova Prijavi odgovor kao problematičan A evo stavio sam i jedan snimak za drugovi forumasi (1.2 MB) http://rapidshare.de/files/23100972/Kawasaki_ZZR_1400_su_ovale.wmv.html Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Kengur 0 Napisano Jun 15, 2006 Svrati ponekad, 117 postova Lokacija: beograd/SRBIJA Prijavi odgovor kao problematičan Btw sta reci za motor koji bije 280 cetvrtom Pa i 12ca je bluzu......Znam sigurno da ide drugom 180kmh...... Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Guest diRRty Napisano Jun 15, 2006 Prijavi odgovor kao problematičan Mali , napokon nasao veliki motor.Aj nek mu je srecno Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Cale 9 Napisano Jun 15, 2006 In memoriam, 783 postova Lokacija: Ottawa, Canada Prijavi odgovor kao problematičan Btw sta reci za motor koji bije 280 cetvrtom Pa i 12ca je bluzu......Znam sigurno da ide drugom 180kmh...... ZX10R ide 175 prvom :twisted: Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
vladica 35 Napisano Jun 15, 2006 Svrati ponekad, 276 postova Lokacija: Niš, SRBIJA Motocikl: DR 650 Prijavi odgovor kao problematičan Btw sta reci za motor koji bije 280 cetvrtom Pa i 12ca je bluzu......Znam sigurno da ide drugom 180kmh...... ZX10R ide 175 prvom :twisted: :shock: :shock: u jebote koja je to sila od motora Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Cale 9 Napisano Jun 15, 2006 In memoriam, 783 postova Lokacija: Ottawa, Canada Prijavi odgovor kao problematičan Vecina R motora i u kalsi 600 ide glatko prvom 120-130, a drugom 170-180. Medjutim poenta nije u tome. ZX10R ima dugacku prvu da bi kako tako prednji tocak bio na zemlji. 14-ka ima ogroman obrtni momenat cak i pri nizim obrtajima, tako da su dugacki prenosi moranje. Na uporednim testovima kriva snage i momenta kod 12-ke i 14-ke imaju isti oblik samo sto su 14-kine vrednosti vece, uz jednu rupu u snazi na nekih 2000 obrtaja, koje nema kod 12-ke. Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Snake 06 7 Napisano Jun 22, 2006 Svrati ponekad, 296 postova Lokacija: Velika Krsna Prijavi odgovor kao problematičan Vecina R motora i u kalsi 600 ide glatko prvom 120-130' date=' a drugom 170-180. Medjutim poenta nije u tome. ZX10R ima dugacku prvu da bi kako tako prednji tocak bio na zemlji. 14-ka ima ogroman obrtni momenat cak i pri nizim obrtajima, tako da su dugacki prenosi moranje. Na uporednim testovima kriva snage i momenta kod 12-ke i 14-ke imaju isti oblik samo sto su 14-kine vrednosti vece, uz jednu rupu u snazi na nekih 2000 obrtaja, koje nema kod 12-ke.[/quote'] :shock: Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Brka 2 Napisano Jun 22, 2006 Zainteresovan, 837 postova Lokacija: Mladenovac Prijavi odgovor kao problematičan Ja sam bas sinoc doterao Kawasaki ZX12R iz Backe Topole sa popravke i cini mi se da nema velike razlike u odnosu na moju ZX9R. Mnogo lakse ide na zadnjem i lako se dize i razlika je jos u tome sto ZX12R brze puni od 250-260 do 300km/h. Inace ovo ostalo je za ulicnu voznju veoma mala razlika. A ZX14... :shock: :shock: :shock: Bas me zanima sta to radi... Neka ti je sa srecom i sve najbolje. :pivo: Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Snake 06 7 Napisano Jun 23, 2006 Svrati ponekad, 296 postova Lokacija: Velika Krsna Prijavi odgovor kao problematičan Ja sam bas sinoc doterao Kawasaki ZX12R iz Backe Topole sa popravke Je l' to Obradowicewa Kawa? Koliko je puko za 'oprawku? Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Brka 2 Napisano Jun 23, 2006 Zainteresovan, 837 postova Lokacija: Mladenovac Prijavi odgovor kao problematičan Da, to je Kawa koju je on unistio ali njegov cale je ostavio kod mene dok se ne sredi kompletno i dok se ne proda posto na foru on ne moze da vozi a ja mogu mada ja imam svoj motor tako da ZX12R necu da vozim. Mozda ga isteram jednom na pumpu preko gazele. P.S. Sorry za off. Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Maki 289 Napisano Jun 23, 2006 Drug član, 2110 postova Lokacija: Zrenjanin Motocikl: Suzuki GSX-R 1000 L1 SBK; MV Agusta F4 1000 S; Ducati 996 S; Aprilia RSV4 RF; Suzuki GSX-S 1000 M0; Suzuki GSF 1200 N Prijavi odgovor kao problematičan Mnogo lakse ide na zadnjem i lako se dize i razlika je jos u tome sto ZX12R brze puni od 250-260 do 300km/h. Ma sta kazes! Ajde doteraj ga do ZR da vidimo kako to cudo ide! Sto se 14-ke tice, komentar vozaca MOTO PULS-a je da je 6. brzina nepotrebna posto u 5. dostize blokadu (bod blokadom mislim na onu na 299km/h) :twisted: Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ernesto 10 Napisano Jun 23, 2006 Zainteresovan, 981 postova Lokacija: Bgd Prijavi odgovor kao problematičan Mnogo lakse ide na zadnjem i lako se dize i razlika je jos u tome sto ZX12R brze puni od 250-260 do 300km/h. Ma sta kazes! Ajde doteraj ga do ZR da vidimo kako to cudo ide! Sto se 14-ke tice' date=' komentar vozaca MOTO PULS-a je da je 6. brzina nepotrebna posto u 5. dostize blokadu (bod blokadom mislim na onu na 299km/h) :twisted:[/quote'] A brzina postizanja te blokade??? :twisted: :twisted: Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Snake 06 7 Napisano Jun 24, 2006 Svrati ponekad, 296 postova Lokacija: Velika Krsna Prijavi odgovor kao problematičan Da' date=' to je Kawa koju je on unistio ostavio[/quote'] Pa koliko je dao za poprawku,koliko znam obradowic ga je bash "mushki" nasharao....? Koliko sad trazi za njega? Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
AreOut 8 Napisano Jul 3, 2006 Zainteresovan, 978 postova Prijavi odgovor kao problematičan Vidjen uzivo ispred "Limun"-a, auf :twisted: Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Tibor_ns 17 Napisano Jul 12, 2006 U prolazu, 63 postova Lokacija: Novi Sad Motocikl: Suzuki GSXR 750 2003 , Yamaha Virago 535 Prijavi odgovor kao problematičan Drgar Mali iz Arhangela je konacno docekao svoj novi motor! Stigao je u NS danas i sklopljen je ali nije mogao da ga preuzm jer je prvi koji je uzeo ZX-14 pa mora na Masinski fakultet u Bg. A jel tvoj drugar iz Novog Sada ili iz BG ? Posto si napisao da je stigao u NS ... jel to neka firma u NS uvozi Kawe ? Cestitam za novi motor i puno sretnih kilometara zelim ! :wink: Ja sam isto citao u motopulsu da je strahovito ubrzanje ... i pomalo zastrasujuce kojom brzinom cajger putuje do 280 km/h a tu malo sporije ide do 299 . :!: Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ernesto 10 Napisano Jul 12, 2006 Zainteresovan, 981 postova Lokacija: Bgd Prijavi odgovor kao problematičan Iz bg-a je ali je uvezao motor preko firme iz Ns-a Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
IVAN R1 2 Napisano Octobar 23, 2007 U prolazu, 74 postova Lokacija: Kovin Prijavi odgovor kao problematičan MA LJUDI TAJ ZX14 JE SRANJE,JA SAM GA NA POTEZANJU ODRAO SA XX HONDOM 97 GODISTE,MA PRAVO RAZOCARANJE. JAK MOTOR NEMA STA,ALI NE I BRZ... Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
quasaar 1030 Napisano Octobar 23, 2007 Călător motocicleta, 2361 postova Lokacija: Novi Sad / Mlecni Put Motocikl: Bez... jednog dana ponovo :) Prijavi odgovor kao problematičan Ako ti tako kazes... MA LJUDI TAJ ZX14 JE SRANJE,JA SAM GA NA POTEZANJU ODRAO SA XX HONDOM 97 GODISTE,MA PRAVO RAZOCARANJE. JAK MOTOR NEMA STA,ALI NE I BRZ... I ponovo te upozoravamo da ne koristis Caps Lock (velika slova) posto je to isto kao da se deres na sve nas! Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
vlaxxdee 7 Napisano Octobar 23, 2007 Svrati ponekad, 369 postova Lokacija: Cacak Prijavi odgovor kao problematičan U standardnoj izvedbi je to nekih 200ks,ne znam zasto toliko slabo poteze :-\ Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Guest diRRty Napisano Octobar 23, 2007 Prijavi odgovor kao problematičan Verovatno nije bio u pravim rukama, XX ide i to dobro, ali kao ZX 14 tesko, cak ne ide ni od 12-tice bolje Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
vlaxxdee 7 Napisano Octobar 23, 2007 Svrati ponekad, 369 postova Lokacija: Cacak Prijavi odgovor kao problematičan Pa naravno da i izmedju 12-tice i XX-a nema mnogo razgovora...a vozac je,moguce,u slucaju 14-tice napravio neku gresku. Evo mozda bi ova bila dobra za potezanje Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
