ajde.....HELP
  • U prolazu, 57 postova
  • Lokacija: Pancevo
Moj drug uskoro kupuje 125 icu,
i zanima ga yamaha tdr 125.
pa me zamolio da li mogu vas,tako pametne i sveznajuce, da pitam za motor! 8)
dakle, tehnicke karakteristike? :?:
Brzina? :?: SWE? :?: ko zna, nek se javi sto pre!
  • Drug član, 1777 postova
  • Lokacija: Sibir
A da otkucas tdr125 review u Googlu ili necem slicno...
Model: Yamaha TDR 125
Year: 2002
Category: Allround
Rating: 78.9 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 125.00 ccm (7.63 cubic inches)
Engine type: Single cylinder
Stroke: 2
Power: 15.00 HP (10.9 kW)) @ 7000 RPM
Torque: 14.70 Nm (1.5 kgf-m or 10.8 ft.lbs) @ 7000 RPM
Compression: 6.6:1
Bore x stroke: 56.0 x 50.7 mm (2.2 x 2.0 inches)
Cooling system: Liquid
More details Consult a Yamaha repair manual.
Physical measures
Dry weight: 128.0 kg (282.2 pounds)
Seat height: 850 mm (33.5 inches) If adjustable, lowest setting.
Overall height: 1,295 mm (51.0 inches)
Overall length: 2,120 mm (83.5 inches)
Overall width: 840 mm (33.1 inches)
Ground clearance: 270 mm (10.6 inches)
Wheelbase: 1,405 mm (55.3 inches)
Chassis and dimensions
Front suspension travel: 180 mm (7.1 inches)
Rear suspension travel: 180 mm (7.1 inches)
Front tyre dimensions: 100/90-18 56P
Rear tyre dimensions: 130/80-17 65P
Front brakes: Single disc
Front brakes diameter: 282 mm (11.1 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Power/weight ratio: 0.1172 HP/kg
