Evo uputstva iz owner manual-a na engleskom:
To check the engine oil level
1. Place the motorcycle on a level
surface and hold it in an upright
position.
NOTE:
Make sure that the motorcycle is
positioned straight up when checking
the oil level. A slight tilt to the side
can result in a false reading.
2. Remove the oil filler cap cover by
removing the screw.
3. Start the engine, warm it up for
at least 10 seconds, and then
turn it off.
4. Wait a few minutes until the oil
settles, remove the oil filler cap,
wipe the dipstick clean, insert it
back into the oil filler hole (without
screwing it in), and then
remove it again to check the oil
level.
NOTE:
The engine oil should be between the
minimum and maximum level marks.
Do not operate the motorcycle
until you know that the engine oil
level is sufficient.
CAUTION:
WARNING:
Never remove the engine oil tank
cap after high-speed operation,
otherwise hot engine oil could
spout out and cause damage or
injury. Always let the engine oil
cool down sufficiently before
removing the oil tank cap.
5. If the engine oil is below the minimum
level mark, add sufficient
oil of the recommended type to
raise it to the correct level.
6. Install the oil filler cap and the oil
filler cap cover.
