Motorcyclist
Sve što je postavio član: Motorcyclist
  1. Verovatno mu fali taj drugi disk da bude kako treba.
  2. Motorcyclist
    Lidl kaciga
    Ima i u Backoj Palanci jos.
  3. Najbolje da ne prelaze mnogo sa 750ccm i 58ks :). Sto kaze Jasminko i ja sam se iznenadio kada ga je kupio, ja sam ocekivao nesto minimum 1000ccm.
  4. Don't do it.
  5. Ja bio ubedjen da si uzeo CBF1000, kakva je ono bila mosha slika sa tim motorom? Cestitke na kupovini.
  6. Due to defects in the injection casting process or mechanical damage to the sheath of your BMW R1300GS, humidity may enter the starter relay. This can lead to the corrosion of components/contacts inside the starter relay, causing functional failures. This corrosion can also cause electrical leaks making components overheat, creating a risk of fire. The screw connection between the valve housing and the damper at the front and rear of the spring legs of your BMW K 1600 B, K 1600 GT, K 1600 GTL or R 1250 RT may become detached. If the front spring leg is affected, driving stability may be impaired. This can cause the driver to lose control of the motorcycle, increasing the risk of accident and injuries. Check our website for the production dates. FEMA, Europe's leading motorcyclists' organisation, shows you all recalls: www.femamotorcycling.eu/recalls
  7. http://www.polovniautomobili.com/motori/23729549/suzuki-sv650-s Vratio se.
  8. Sa WEMOTO cekas porudzbinu mozda oko 10 dana. Takodje mozes uzeti i na motorcycleparts.eu.
  9. Skini senzor, rastavi, ocisti klinerom pa vidi. Ja sam tako resio problem kada ga nije gasio na spustenu copavu. Ako ne, porudzina senzora.
  10. Oke, zaboravio sam te manje modele.
  11. Valjda za troduplo manje novca?
  12. Prodajem maslinasto zelene pantalone domace izrade za svakodnevne aktivnosti napolju. Kvalitetan materijal. Za nekoga izmedju 175-180cm i do 70kg. Dimenzije: ukupna duzina - 102cm, unutrasnje nogavice - 77cm, precnik struka 38,5cm, sirina nogavica na butini 24cm. Cena 3000din.
  13. Motorcyclist
    Regler
    Na WEMOTO ili Motorcycleparts eu.
  14. Izgleda da covek sto je stariji postaje vece zanovetalo... A povukli sad i ove mladje.
  15. Koliko citam sad vec ljudima i smeta sto im vetar udara u kacigu...ej zamisli. A ovamo vetar u kosi ovo ono Sednes u auto pa ne udara vetar.
  16. Ko je sve serviser... Samo veza i nebo ti je granica u Srbiji.
  17. Pa da jeste to bi prvo bilo na naslovnoj strani sajta itd...
  18. Kakvo sranje da odvrne jedan sraf ili filter ulja rukom?
  19. Mozda im je u servisu neravan pod Stavi ga na centralni, ako nema sedi na njega i ispravi a neko neka ocita.
  20. Nije agregat od Stroma.
  21. Ode. Ko stavi realnu cenu taj i proda.
  22. Nece on vise osvojiti nista u GP.
