Patriota
Sve što je postavio član: Patriota
  1. I dzabe ces ici,sve cekaju da se bave takvim stvarima.Mozes da dobijes samo pitanje sto ga nisi odjavio kako zakon nalaze
  2. AGV i Scorpion ne pasu istoj glavi (probao)
  3. Put je stvarno dobar,siroke i dosta pregledne krivine,ali...i vozaci putnickih auta preticu gde stignu,pa bas i nije za jurcanje.
  4. Patriota
    Formula 1
    100 godina nisam gledao F1 i pratio sam po malo neke trke u poslednje vreme, mogu samo da kazem da je Dorna (MotoGP) gospodska institucija za ove,samo sam potvrdio da mi je razlog sto ih ne gledam opravdan
  5. Citao sam par foruma u vezi sa tim testiranjima,masa ljudi se slaze da je to samo smernica, i dosta je diskusija bilo o validnosti njihovog nacina testiranja
  6. Sa njihovog sajta Each model of motorcycle helmet undergoes 30 linear and 2 oblique impact tests in order to achieve a SHARP rating. To complete these 32 tests, a minimum of 7 individual helmet samples, in a range of sizes, are subjected impacts at three speeds (6, 7.5 and 8.5 metres per second) as follows: Helmet Velocity Impact type and location on helmet Impact surface 1 6.0 m/s Linear impacts to Front, Left, Right, Crown and Rear Flat anvil 2 6.0 m/s Linear impacts to Front, Left, Right, Crown and Rear Kerb anvil 3 7.5 m/s Linear impacts to Front, Left, Right, Crown and Rear Flat anvil 4 7.5 m/s Linear impacts to Front, Left, Right, Crown and Rear Kerb anvil 5 8.5 m/s Linear impacts to Front, Left, Right, Crown and Rear Flat anvil 6 8.5 m/s Linear impacts to Front, Left, Right, Crown and Rear Kerb anvil 7 8.5 m/s Oblique impacts to the Left and Right sides Abrasive anvil For the linear impact tests, helmets are impacted against both flat and kerb shaped surfaces which represent the surfaces likely to be impacted in real world road accidents. The impact anvils are as specified in UN ECE Regulation 22.05. The oblique impact test is carried out to assess the surface frictional properties of the helmet that can lead to rotational acceleration injuries. For this test SHARP follows the requirements of Regulation 22.05 completely. Given the COST 327 recommendations concerning the benefits of improved energy absorption, SHARP tests at a higher impact velocity than required by regulation (8.5m/s). This represents approximately 30% more energy input than required by UN ECE Regulation 22.05.
  7. Ako ne gresim trenutno je veci problem cena tehnickog i osiguranja nego takse drzave i porez,po nekoj gruboj kalkulaciji ove dve stavke izadju 2/3 cene registracije.Ali taj lobi se ne dira,po meni je ovo samo mazanje ociju
  8. To moras da naglasis, inace ode tema ...
  9. Zato sto skoro svi privatno voze,pa znaju i razumeju
  10. Isti su, zimi su u kolima, leti na motoru
  11. Nije palanka al sam je vozio po Rumuniji, touring force, toplo i suvo,odusevila me kako drzi, ali imam utisak da cim je malo hladniji put trazi dosta vremena da se ugreje, sad kad je prelazni period poprilicno zna zadnja da kliza
  12. Online prodavnica Svega za automobile i ostala vozila - GRT Group GRTGROUP.NET Specijalizovana radnja i online prodaja svega za automobile i ostala vozila i to su zvucne izolacije, auto muzika, auto žabice, kopče,patenti Probaj ovde,svasta imaju
  13. A Miseluk ocisen i nalickan za gospodu iz vlasti, taman je mogao tamo skup da bude
  14. Naleteh danas na ovo
  15. PCR test ALI 24 sata, ako se ide avionom vazi 72 sata.To je informacija sa granice, dok na zvanicnom sajtu nigde ne pominju tih 24h
  16. Verovao ili ne, nema tu puno padova, prosao sam nesto slicno i iz iskustva ti govorim, radi se na malim brzinama skoro pa bez obaranja dok se ne uvezba, vremenom ide brze, nize itd. Za stunt ne znam, nisam probao, ali verujem da padaju
  17. U sustini svako ko je prosao neku obuku moze da ti pokaze osnove, pogled i tehniku na tako malom prostoru. Prednost instruktora je iskusno oko i finese
  18. Tako sto iz dana u dan, po ceo dan vrte dok ne nauce. Bilo bi zaniljivo videti snimak sa pocetka obuke, koliko tih cunjeva ostane na mestu. Samo krvavi trening
  19. Patriota
    Bell kacige
    Probaj sa LS2 pioneer,iznenadjujuce dobra kaciga za malo para.Konkretno Bell ne znam da iko ima kod nas sem pomenuti Xmoto
  20. Na sta tacno mislis? Zaboravio sam da napisem da ukoliko imate PCR test boravak je maksimalno 48h,ono sto pise na sajtu da je dozvoljeno 72 h je u koliko se ide avionom
  21. Ja sam naleteo na dva komada,hrane iz iz automobila pa jos strucnjaci stanu u sred krivine da ih slikaju
  22. Upravo se vratio iz Rumunije, traze PCR test(skuplji) ili vakcinaciju
  23. Ja planiram tamo 26 tog, ajd javi kuda si isao i kakav je put da znam na sta da se pripemim,isto autom idem
