Fredi
Sve što je postavio član: Fredi
  1. Fredi
    Formula 1
  2. Fredi
    Formula 1
    Mohammed Ben Sulayem elected new FIA president WWW.MOTORSPORT.COM Mohammed Ben Sulayem has been elected the new president of the FIA, taking over from the outgoing Jean Todt after 12 years. Sve je otislo u Honduras....
  3. Fredi
    Formula 1
    100 kg goriva nose, odavno nema dolivanja.
  4. Fredi
    Formula 1
    Taktika na trci koja je 300 km ili sat i po treba da bude opleti po gasu pa ko brzi.
  5. Fredi
    Formula 1
    Jednostavniji motori od 2026. F1 agrees to ditch MGU-H as part of new engine rules WWW.MOTORSPORT.COM Formula 1 chiefs have confirmed that the MGU-H will be dropped from power units from 2026 as part of a new rules shake-up.
  6. Radi se na sistemu obavestenja o padu. MotoGP, Fall signals: Dorna working for motorcycle riders on the track WWW.GPONE.COM MotoGP: Dashboard messages and signal lights are being considered, but they have to figure out how to automate them through airbag sensors or on the bikes.
  7. Fredi
    Formula 1
    Kad bolje razmislim mozda i nisi, mozda je te 90 trebala da bude promena na levu stranu a Prost se izborio da ostane desno.
  8. Fredi
    Formula 1
    Nisam siguran da je tako. Osvajac pol pozicije od 87 kada je Suzuka uvrstena u kalendar pa do 90 i drugog incidenta Sena-Prost startovao je sa desne strane. Od 91 prebacena je na levu stranu.
  9. Fredi
    Formula 1
    Mislio sam da je Pike junior.
  10. Fredi
    Formula 1
    Znao sam da imas argumente.
  11. Fredi
    Formula 1
    Umesto sto vrtite tu mantru, navedi u cemu je poseban tretman Mercedesa, i koja su pravila krojena za njih.
  12. Fredi
    Formula 1
    stiks, hoces biti jos tuzniji ako procitas pravilnik. Article 48.12 deals with the situation of having backmarkers unlap themselves. Initially, Masi had been within his rights to state that 'Lapped Cars will not be allowed to overtake' - which meant Verstappen would be trapped behind five backmarkers before he could get a run on Hamilton. However, on the penultimate lap, on the run down to Turn 9, Masi sent a message saying that five cars – Lando Norris, Fernando Alonso, Esteban Ocon, Charles Leclerc and Sebastian Vettel could unlap themselves. The decision to only allow some lapped cars to unlap themselves is unusual as Article 48.12 suggests that the message 'LAPPED CARS MAY NOW OVERTAKE' should be sent to all competitors. The regulation is then explicit about when the race can be restarted. It states: "Unless the clerk of the course considers the presence of the safety car is still necessary, once the last lapped car has passed the leader the safety car will return to the pits at the end of the following lap. "If the clerk of the course considers track conditions are unsuitable for overtaking the message "OVERTAKING WILL NOT BE PERMITTED" will be sent to all Competitors via the official messaging system " This clause suggests that with the lapped car message having come out on lap 57, then the restart could only come at the end of the 'following lap'- so lap 58, which was the end of the race. Article 48.8 relates to there being no overtaking behind the safety car. During the restart phase, as Hamilton and Verstappen prepared to begin racing again, it appeared from the onboard that the Red Bull had briefly nudged ahead of the Mercedes. The rule states that "no driver may overtake another car on the track, including the safety car, until he passes the Line (see Article 5.3 – which is the safety car line) for the first time after the safety car has returned to the pits."
  13. Fredi
    Formula 1
    Plus sto je situacija oko sefti kara potpuno ne legalna, ili automobili koji zaostaju ceo krug ostaju ili obilaze sc ali onada on ostaje jos jedan krug. Masi je skonio ove izmedju Verstapena i Hamiltona ostale ne i odamah sklonio SC. Nece da moze, plus je ovaj u jenom trenutku bio ispred Hamiltona za vreme SC ni to ne moze. Kradja ne vidjena.
  14. Fredi
    Formula 1
    Ajde nabroj koje su to igrarije i koje odluke su isle na Hamiltonovu stranu. Pre bih rekao da je kontra, pocevsi od Silverstona,Azerbedzana, Monce, Belgije, Brazila, Katara pa do ove bruke danas, da nije uspe uz trostruku pomoc mislim da bi Hamiltonu pucali u gume.
  15. Fredi
    Formula 1
    Nije iskljuceno da je sampionat dogovoren. Prosle godine Toto Wolf je izjavio da ekipe moraju voditi racuna o tome da je gubitak F1 bio ogroman. E sad dal su ga zavrnuli sta su dogovorili....
  16. Fredi
    Formula 1
    S obzirom da su mu oteli trecu titulu u karijeri poneo se kako dolikuje vitezu. Dva puta sefti kar da ga ovaj stigne, plus voznja Pereza u cik cak gde je izgubio 7 sek. da je bila trka bez ovih svinjarija odrao bi ga za 30 sekundi.
  17. Fredi
    Formula 1
    Monca 1985, startuje ih 26, klasicno nozno kvacilo, rucni mrnjac, minimum ili 0 elektronike. Od ovih danjasnjih 5 ne bi proslo trecu krivinu.
  18. Fredi
    DAKAR, 2022
    Godine lete, bio sam ubedjen da je mladja a ustvari ima 36 godina i deset ucesca na Dakar reliju.
  19. Fredi
    DAKAR, 2022
    Nadao sam se da ce uskoro na postolje. Sada se nadam de ce krenuti stopama Jute Klajsmit ili Misel Muton.
  20. Fredi
    DAKAR, 2022
    Laia Sanz presla na 4 tocka.
  21. Fredi
    Formula 1
    Trka u nedelju ce mu biti 350. po redu. A imao je pauzu od 2 godine.
  22. Fredi
    Formula 1
    Berni o najboljem vozacu F1. Eklston je istakao da to neće promeniti Hamiltonovo mesto u najboljih pet vozača, prema njegovom mišljenju, kao i da će najbolji ostati francuski vozač Alan Prost (šampion – 1985, 1986, 1989. i 1993. godine). „On je bolidom upravljao sam bez ikakve pomoći, za razliku od sadašnjih vozača, koji dobijaju uputstva preko radija. Takodje on je uvek imao veoma jake protivnike“, rekao je Eklston
  23. Fredi
    Formula 1
    Slazem se za razlicite poglede, i ne bih vise ali moram zbog trke u Azerbedzanu. Kada je Verstapenu pukla guma RedBul je trazio prekid trke radi zamene guma iz bezbednosnih razloga, tako da ne stoji da Hamilton profitirao, pre bi se moglo reci da je ostecen jer je i Perez morao na zamenu da nije bilo crvene zastave.
  24. Fredi
    Formula 1
    Za 40 godina koliko pratim Formulu 1 propustio sam max 20 trka. Nagledao se svega. O svakoj sezoni ili spornoj situaciji mogu nasiroko. Na primer o sezoni kada si ti rodjen, zaasto je doslo do naglog pada Meklarena posle cetiri uvodne pobede. Ali to je bilo davno i nikog ne interesuje. Uzmimo zadnje dve trke. U Kataru jedan beli bolid stoji pokraj staze 2 kruga, Verstapen postavlja najbezi krug i tek onda se uvodi virtuelni SC do kraja trke. U Arabiji uvodi se SC Verstapen pravi gresku i ne promeni gume kao ostali, verovatno bi bio 3 ili 4 zbog te greske, istice se crvena zastava da isti sa prvog mesta dobije bespatnu zamenu guma. Kako ti vidis ove dve situacije?
  25. Fredi
    Formula 1
    DAS je bio legalan, i FRIC i ono inovativno vesanje ali je zabranjeno jer bi Mercedes bio jos dominantniji. To sa SC ne stoji, deset puta je bilo protiv Hamiltona, jednom je mozda profitirao. Suvise verujes sumnjivim portalima i ozlojedjenim navijacima Ferarija, Alonsa, Raikonena.... Mercedes se dominantan zbog para i tehnicog potecijala kiji je u odnosu na druge ekipe skoro ne iscrpan.
