Yamaha xt660r
  • Starfleet officer, 249 postova
  • Lokacija: Canada
  • Motocikl: n/a
Ja imam isti agregat, ali ti ipak savetujem da download-ujes user manual za XT jer tamo sve pise.
Meni pise da je najbolje odmah posle krace voznje na otvorenom, ne srafi se cep kada se meri, samo se spusti i izvadi.
  • Svrati ponekad, 276 postova
  • Motocikl: XT660R
Upalis motor, provozas se ili ga u mestu zagrejes, ugasis ga, sacekas minut-dva, odvrnes merac, obrises i vratis ga bez zavrtanja, proveris. Motor treba da stoji uspravno kada vracas merac da proveris.
  • Svrati Svaki Dan, 884 postova
  • Motocikl: brm brm brm
CHECKING THE ENGINE OIL LEVEL
1. Stand the motorcycle on a level surface.
NOTE:
_
Place the motorcycle on a suitable stand.Make sure the motorcycle is upright.
  1. Start the engine, warm it up for 10 ~ 15 min-utes, and then turn it off.
  2. Check:
engine oil level
The engine oil level should be between theminimum level mark a and maximum levelmark b.
Below the minimum level mark Add therecommended engine oil to the proper level.
NOTE:
_
  • Before checking the engine oil level, wait afew minutes until the oil has settled.
  • Do not screw the dipstick in when check-ing the oil level.
Imate ovde manuala nekoliko, parts cataloge i sl., sve lepo zapakovano, ne mora da se trazi po internetu :)
Bice aktuelan link par dana : Tekst koji želiš
