markes 3 Napisano Jul 30, 2012 Svrati ponekad, 178 postova Lokacija: Beograd Prijavi odgovor kao problematičan Drugari, trazim da kupim svecice, ali nigde nema tacno one koja je za moj motor (CPR8EA-9). Ima samo ova druga. Razlika je samo u Terminal type-u. Moja je stud, a ova druga je solid. Sta je to u stvari i da li odgovara? Specifikacije CPR8EA-9 Traditional Spark Plug, 10mm Thread Size, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Projected Tip, Stud Terminal Threads, Projected Center Electrode, .035" (0.9mm) Gap, Heat Range 8. NOTE: Does not Include Terminal Nut, if necessary, order part #067606-0051 Thread Size: 10mm Seat: Gasket Reach: 19mm (3/4") Hex: 5/8" (16mm) Terminal Type: Stud Resistor: yes Gap: .035" (0.9mm) Heat Range: 8 CPR8EB-9 Traditional Spark Plug, 10mm Thread Size, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Projected Tip, Solid Terminal Nut, Projected Center Electrode, .035" (0.9mm) Gap, Heat Range 8 Thread Size: 10mm Seat: Gasket Reach: 19mm (3/4") Hex: 5/8" (16mm) Terminal Type: Solid Resistor: yes Gap: .035" (0.9mm) Heat Range: 8 Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ribolovac 493 Napisano Jul 30, 2012 Zainteresovan, 863 postova Lokacija: Negotin Motocikl: @ UBER ALLES Prijavi odgovor kao problematičan Probaj da nadjes odgovarajucu Denso spram tvoje CPR8EA-9 ... DENSO U24EPR9 http://www.sparkplugcrossreference.co.uk/1180-denso/1319-ngk/cpr8ea-9-cpr8ea-9-cpr8ea-9.html Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
