CONTOURHD
  • Zainteresovan, 987 postova
  • Lokacija: Düsseldorf / Germany
  • Motocikl: R 1250 GS Adventure
Konacno je stigla nova vodootporna kamera ( 116 grama ) u HD formatu za nas bajkere na trziste !
Key Features
Amazing Video Clarity
2 Video Settings
High Definition: Fill your screen with vivid, widescreen (16;9) action video. With a full 1280x720 (pixels) window and 30 frames per second, your videos will be just how you remember them, big and awesome!
High Action: Ideal for making the fastest adventure sports appear as smooth as butter. Recording standard definition video at 60 frames per second (twice as many frames as TV quality video) you won’t miss any of the action.
Beautiful Outdoor Colors
The image sensor and video processor in this tiny camera were fine-tuned for the changing colors and lighting conditions you’ll experience when recording outdoors. The snow will have definition, the lighting will transition when you go through the trees, and the color clarity has been adjusted so that colors will appear as rich as you remember them.
Capture the Whole Scene
The wider the angle of your lens the more of the scene you capture. At 135 degrees, the new ContourHD lens strikes the perfect balance in capturing the entire scene without over-distorting the video.
Record over 8 Hours of Action Video
As an all-in-one wearable camcorder, ContourHD records to an internal MicroSD memory card to capture up to 8 hours of HD quality video (compatible up to a 16GB Memory Card). Powered by a removable, rechargeable lithium-ion battery, this robust camera recharges through a USB cable connected directly to your computer. Now you can throw away your camcorder tapes, wires, and AA batteries.
With Full Audio
Capturing the sounds you hear (other than the wind) is a difficult proposition, which is why we upgraded the microphone from the previous VholdR model. We’ve done our best to help you cut out the wind noise and record the sounds of the action.
Easy to Use
One Button Record
ContourHD’s operation couldn’t be simpler, as it features a single oversized record switch that you can use even when you’re wearing a pair of gloves. Slide the switch forward to record and slide it back to stop—congratulations, you just made a video! Now you can capture the best scenes right before they happen.
Easy to Align
Have you ever seen a camera with lasers? ContourHD uses two of them and a 192o rotating lens to ensure you line up the shot every time. Turn on the lasers and rotate the front lens until the two laser points are horizontally aligned. Congratulations, you just lined up your video.
Wearable Anywhere
As the most versatile wearable camcorder we take “wearable” seriously. ContourHD uses our patent-pending TRailTM Mounts to “slide and lock” onto a series of different mounts for your goggles, helmet, handlebars, vehicle, or anywhere else you want to mount it. Wear HD video on more than just your head.
Armored Body
A water-resistant camera for all seasons, its light (4 ounces/116 grams) anodized aluminum body withstands dust, dirt, mud, and snow—elements that destroy most electronic gear. It’s also shock, vibration and impact resistant.
Specs:
Video
• Resolution Settings
HD (1280x720) 30 fps
SD (848x480) 60 fps (not finalized)
• 5 Mega-pixel CMOS Image Sensor
• Codec: H.264
• File Type: .mov
Audio
• Internal Microphone
• AAC Audio Compression
Lens
• 135o (HD)
• 90o (SD)
• Fixed Focus
• Zoom: None
Memory
• Type: Removable MicroSD (SDHC compatible)
• Capacity: 16GB (2GB included)
• Average Record Time
HD: 30min / GB
SD: 60min / GB
Battery & Power
• Removable Lithium-ion Battery
• Record Time: Up to 2 hours (SD setting)
• Charging via USB to Computer or Wall Charger (sold separately)
• Charge Time: 3 hours (average)
Easy Edit™ Software
• Compatible Operating Systems: Mac (10.4 & 10.5) ; PC (XP & Vista)
• Videos Download via USB 2.0
Size and Weight
• Height: 95mm
• Length: 53mm
• Width: 34mm
• Weight: 4.2 ounces (116 grams)
Body
• Water Resistant
• Aluminum and Fiberglass Body
• Compatible with VholdR TRail™ Mount System
What’s in the Box
• ContourHD Camera
• MicroSD Card (2GB)
• Goggle Mount
• Flat Surface Mount
• Rechargeable Battery (average 2 hours)
• USB Cable
Manufacturer 20Twenty
Image Display No
HD Yes
Resolution (pixel) 1280x720
Max. storage capacity 16 GB
Framerate 30
Changeable lense No
Field of View 110°
Interfaces MicroSD Cards, USB
Video Formats MPEG4 H.264
Weight 116g
http://www.youtube.com/results?search_query=contourhd&search_type=&aq=f
Cena je 299,00 € i moze da se kupi ovde:
http://www.blickvang.com/helmkamera-systeme/contourhd/contourhd-hd-helmkamera-helmet-camera.html?gclid=CLSO-KnajZ0CFZaGzAodfhl95g
Izasla je nova verzija: ContourHD1080p
Specifikacija novog modela i poredjenje sa konkurencijom: http://vholdr.com/contourhd/techspecs
Menjao sam uz doplatu ContourHD za ContourHD 1080p, evo i snimka:
http://www.youtube.com/watch?v=CxR3_FvN4is
  • Zainteresovan, 904 postova
  • Lokacija: Šumadija-Pašaluk
  • Motocikl: SUZUKI V- STROM
kamera mi je stigla...Niko da odgovori na moje pitanje pa ću odgovoriti ja i dati jednu korisnu informaciju
Kada sam video bateriju, učinila mi se jako poznata..Proverim specifikaciju i raspored pinova i skapiram da je ima svuda za NOkia telefonima..to je..BL-5C BATERIJA...
http://nds1.nokia.com/batteryreplacement/images/bl5c1_large.jpg
A pasuje na najjeftinije i stare NOkia telefone...Ja sam dobio na poklon jednu.... Te telefone tipa Nokia 2610 daju na poklon u ser4visima, kada totalno crknu..Tako da nema potrebe da neko puca 30 eu za dodatnu bateriju.... Inače contour se ne može puniti u toku vožnje i snimanja...A pasuje skoro svaki 12 voltni punjač baterija mobilnih telefona....
Inače kamera otkida ako snima...Aluminijumska je..Lagana dosta.... Reaguje dobro na promene svetlosti... Držač je dobar..Za sada nemam zamerki...
  • Zainteresovan, 635 postova
  • Lokacija: Beograd / Smederevo
  • Motocikl: Suzuki DL650
cek da iskoristim temu dok je jos sveza.
planirah da kupim neku kamericu da se malo castim za slavu
Sveta Petka me spasila kad sam imao ceoni sudar sa busom i sad se castim svaki put kad je slava
nego, samo jedan problem imam, cini mi se po youtube snimcima da je slika mnogo tamnija u odnosu na recimo gopro
(gopro mi nije opcija zbog dimenzija)
a takodje, kao da i dosta sporije reaguje na promenu osvetljenja
evo pogledajte
http://www.pinkbike.com/video/151302/
da li neko od vlasnika moze da potvrdi da li je sliku moguce podesiti da bude kao kod gopro kamera (tj. da bude svetla onako)?
i da li imate problem prilikom voznje na prelazu iz recimo sume na otvoreno?
hvala
