KARAKTERISTIKE
  • Drug član, 1116 postova
  • Lokacija: Tvrdos
  • Motocikl: ZUNDAPP KS 750
moze li mi neko napisati tehnicke karakteristike YAMAHE XT660R mislim na snagu kw tezinu max speed i ostalo i da li je u ovoga motora ful injection ,ima li pumpu za gorivo ili karburatori. unaprijed hvala :)
  • Zainteresovan, 981 postova
  • Lokacija: Bgd
Model: Yamaha XT 660 R
Year: 2007
Category: Enduro / offroad
Engine and transmission
Displacement: 660.00 ccm (40.27 cubic inches)
Engine type: Single cylinder
Stroke: 4
Power: 47.33 HP (34.5 kW))
Torque: 60.00 Nm (6.1 kgf-m or 44.3 ft.lbs) @ 6100 RPM
Bore x stroke: 100.0 x 84.0 mm (3.9 x 3.3 inches)
Fuel system: Injection
Fuel control: SOHC
Starter: Electric
Lubrication system: Wet sump
Cooling system: Liquid
Gearbox: 5-speed
Transmission type
final drive: Chain
Clutch: Wet, multiple-disc coil spring
More details Consult a Yamaha repair manual.
Physical measures
Dry weight: 172.0 kg (379.2 pounds)
Seat height: 865 mm (34.1 inches) If adjustable, lowest setting.
Overall height: 1,230 mm (48.4 inches)
Overall length: 2,240 mm (88.2 inches)
Overall width: 845 mm (33.3 inches)
Ground clearance: 210 mm (8.3 inches)
Wheelbase: 1,505 mm (59.3 inches)
Chassis and dimensions
Frame type: Steel tube, diamond shaped
Front suspension: Telescopic forks
Front suspension travel: 225 mm (8.9 inches)
Rear suspension: Swingarm (monocross)
Rear suspension travel: 200 mm (7.9 inches)
Front tyre dimensions: 90/90-M21
Rear tyre dimensions: 130/80-M17
Front brakes: Single disc
Front brakes diameter: 298 mm (11.7 inches)
Rear brakes: Single disc
Rear brakes diameter: 245 mm (9.6 inches)
Speed and acceleration
Power/weight ratio: 0.2752 HP/kg
Other specifications
Fuel capacity: 15.00 litres (3.96 gallons)
  • Lokacija: Bgd
Evo i osvraja na X model za tebe:
Yamaha's profilation of this bike
The XT660X injects fun wherever, whenever. It mixes a gutsy 660 cc, liquid-cooled fuel-injected engine with Supermotard-styling and suspension to deliver an awesome package. But this is no highly-strung track bike. It wants to slice through the urban sprawl or carve through the countryside every day. Are you ready¿
General information
Model: Yamaha XT 660 X
Year: 2007
Category: Super motard
Stroke: 4
Compression: 10.0:1
Fuel control: SOHC
Ignition: TCI
Starter: Electric
Gearbox: 5-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 177.0 kg (390.2 pounds)
Seat height: 875 mm (34.4 inches) If adjustable, lowest setting.
Overall height: 1,170 mm (46.1 inches)
Overall length: 2,175 mm (85.6 inches)
Overall width: 860 mm (33.9 inches)
Ground clearance: 205 mm (8.1 inches)
Wheelbase: 1,490 mm (58.7 inches)
Front suspension travel: 200 mm (7.9 inches)
Front tyre dimensions: 120/70-R17
Rear tyre dimensions: 160/60-R17
Front brakes diameter: 320 mm (12.6 inches)
Power/weight ratio: 0.2674 HP/kg
  • Lokacija: Bgd
ernesto kad si tako bio dobar ajde mi sad napisi karakteristike za suzuki freewind XF650 pa da nesto uporedim.
A sto nebi moglo Stevo!
Model 2003-a
General information
Model: Suzuki XF 650 Freewind
Year: 2003
Rating: 72.3 out of 100.
Displacement: 644.00 ccm (39.30 cubic inches)
Stroke: 4
Power: 47.00 HP (34.3 kW)) @ 7000 RPM
Torque: 51.60 Nm (5.3 kgf-m or 38.1 ft.lbs) @ 5500 RPM
Max RPM: 8000
Compression: 9.0:1
Bore x stroke: 100.0 x 82.0 mm (3.9 x 3.2 inches)
Fuel system: Carburettor. 2 x Mikuni 32
Valves per cylinder: 4
Ignition: Electric CDI
Starter: Electric
Cooling system: Oil & air
Transmission type
final drive: Chain
Clutch: Wet plate
More details Consult a Suzuki repair manual.
Physical measures
Dry weight: 168.0 kg (370.4 pounds)
Seat height: 800 mm (31.5 inches) If adjustable' date=' lowest setting.
Alternate seat height: 830 mm (32.7 inches) If adjustable, highest setting.
Overall height: 1,240 mm (48.8 inches)
Overall length: 2,205 mm (86.8 inches)
Overall width: 865 mm (34.1 inches)
Ground clearance: 200 mm (7.9 inches)
Frame type: CrMo steel
Front tyre dimensions: PIRELLI-MT 80
Rear tyre dimensions: PIRELLI-MT 80 RS
Front brakes: Single disc. Piston
Front brakes diameter: 300 mm (11.8 inches)
Rear brakes: Single disc. Piston
Rear brakes diameter: 240 mm (9.4 inches)
Top speed: 160.0 km/h (99.4 mph)
0-100 km/h (0-62 mph): 8.000 seconds
Power/weight ratio: 0.2798 HP/kg
Fuel capacity: 18.00 litres (4.76 gallons)
Reserve fuel capacity: 4.00 litres (1.06 gallons)
Fuel consumption pr. 10 km (6.2 miles): 3.40 litres (0.90 gallons)
Color options: BLUE, BLACK,SILVER
  • Lokacija: Bgd
Model 2003-a
General information
Year: 2003
Stroke: 4
Max RPM: 8000
Compression: 9.0:1
Starter: Electric
Transmission type
final drive: Chain
Clutch: Wet plate
Physical measures
Zeje, cestitke i pozdravi u nastavku...
  • Lokacija: Bgd
ERNESTO hvala ti :!: kod mene je 97godina xf650 pa sam ga poredio sa xt660r i zadovoljan sam. :D
Nema na cemu... Seti me se kada dodjem u junu tu do vas dole na skup!
Kao sto znas PRIMAM MITO - 1 ladno
