Ivan x 70 Napisano Maj 8, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Honda XR400r, 1999 godiste. Renthal volan,Mikuni karburator,uhd tubes,mx51,acerbis stitnici. Montirane nove lamele kvacila i zadnje kocione plocice(OEM Honda). Registrovan do 07.08.2014. 1850 eur 066/299-300 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Maj 18, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Make Model Honda XR 400R Year 1999 Engine Air cooled, four-stroke, single cylinder SOHC, 4 valve, Capacity 397 Bore x Stroke 85 x 70 mm Compression Ratio 9.3:1 Induction 36mm piston-valve Ignition / Starting Solid state CDI with electronic advance / kick Max Power 34 hp 24.8 kW @ 6500 rpm Transmission / Drive 5 Speed / chain Front Suspension 43mm leading-axle Showa cartridge fork with 18-position compression and 12-position rebound damping adjustability, 300mm wheel travel Rear Suspension Pro-Link Showa single shock with spring preload, 16-position compression and 16-position rebound damping adjustability, 300mm wheel travel Front Brakes Single 256mm disc 2 piston caliper Rear Brakes Single 220mm disc 1 piston caliper Front Tyre 80/100-21 Rear Tyre 110/100-18 Seat Height 930 mm Dry-Weight 121 kg Fuel Capacity 9.5 Litres Standing ¼ Mile 14.8 sec / 132 km/h Top Speed 137 km/h Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Maj 18, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Make Model Honda XR 400R Year 1999 Engine Air cooled, four-stroke, single cylinder SOHC, 4 valve, Capacity 397 Bore x Stroke 85 x 70 mm Compression Ratio 9.3:1 Induction 36mm piston-valve Ignition / Starting Solid state CDI with electronic advance / kick Max Power 34 hp 24.8 kW @ 6500 rpm Transmission / Drive 5 Speed / chain Front Suspension 43mm leading-axle Showa cartridge fork with 18-position compression and 12-position rebound damping adjustability, 300mm wheel travel Rear Suspension Pro-Link Showa single shock with spring preload, 16-position compression and 16-position rebound damping adjustability, 300mm wheel travel Front Brakes Single 256mm disc 2 piston caliper Rear Brakes Single 220mm disc 1 piston caliper Front Tyre 80/100-21 Rear Tyre 110/100-18 Seat Height 930 mm Dry-Weight 121 kg Fuel Capacity 9.5 Litres Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Maj 27, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Montiran nov lanac i lancanici. DID VX2 JT 14/48 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Maj 27, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 1900 € Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jun 5, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Montiran nov lanac i lancanici. DID VX2 JT 14/48 Zamenjeno ulje i semering prednje viljuske. Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jun 5, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 1900 € Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jun 16, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Montiran nov lanac i lancanici. DID VX2 JT 14/48 Zamenjeno ulje i semering prednje viljuske. Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 3, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 1800 eur Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 3, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan http://www.honda.com/newsandviews/article.aspx?id=200706191732 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 6, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 1750 eur Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 9, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan http://www.honda.com/newsandviews/article.aspx?id=200706191732 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 9, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 1700 eur Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 10, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 061/161-05-41 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 10, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Zvati na telefon iz predhodnog posta. Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 10, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 1700 eur Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 11, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 1800 eur 061/161-05-41 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 27, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Nov lanac(DID VX2) i lancanici(JT). Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Jul 27, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 1650 eur Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Avgust 6, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Nov lanac(DID VX2) i lancanici(JT). Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Avgust 6, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan http://www.motorcyclespecs.co.za/model/Honda/honda_xr400r%2098.htm Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Avgust 6, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 061/161-05-41 Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Avgust 16, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan 1650 eur Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Avgust 21, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Nov lanac(DID VX2) i lancanici(JT). Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
Ivan x 70 Napisano Avgust 21, 2014 Zainteresovan, 560 postova Prijavi odgovor kao problematičan Telefon iz prvog posta vise nije aktivan. Novi telefon je, 066/299-301. 1600 eur Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
