Aprilia RS4 50 - Tehnička specifikacija
Engine type Single-cylinder, two stroke, carburettor, liquid cooled.
Bore and stroke 39.86 x 40 mm
Engine capacity 49.9cc
Compression ratio 11.5 :1
Ignition Electronic with CDI capacity discharge
Start up Electric
Lubrication Automatic mixer
Gearbox 6 Ratios, 1st 11/34, 2nd 15/30, 3rd 18/27, 4th 20/24, 5th 22/23, 6th 23/22
Primary drive Gears, 21/78
Final drive Chain, 11/53
Clutch Multiplate wet clutch
Frame Twin spar aluminium frame
Front suspension 41 mm upside down fork, wheel travel 110 mm
Rear suspension Asymmetric swingarm with monoshock, wheel travel 130 mm
Brakes Front: 300 mm stainless steel disc with radial 4 piston calliper
Rear: 218 mm stainless steel disc and calliper with single 30 mm piston
Wheel rims In light alloy with 6 split spokes, with sealing profile for tubeless tyres; front: 2.75 x 17″; rear: 3.50 x 17″
Tyres Front: 100/80 - 17″, rear: 130/70 - 17″
Dimensions Max. Length 1953 mm
Max width 740 mm
Max height at top fairing 1,138 mm
Saddle height 820 mm
Wheelbase 1,350 mm
Fuel tank capacity 14.5 litres (including 3.5 litre reserve)
Emissions compliance Euro 2
