420 -
Sve što je postavio član: ekozelj
Ovo su šifre koje ja imam: Sprej Silkolene Pro Chain Art. ID: 255507 Silkolene Comp 4 15W-50 XP Art. ID: 255292 Silkolene PRO 4 15W-50 XP Art. ID: 255295 Silkolene Comp 4 10w-40 XP Art. ID: 255291 Silkolene Pro 4 10w-40 XP Art. ID. 255294
Imaš i foru da glatke kineske nosače blago obrusiš šmirglom u delu gde se ostvaruje kontakt, da postanu hrapavi i onda uglavnom prestanu da klizaju.
Upravo tako. Jeste da košta ali i radi za šta je namenjeno. Ostalo je bukvalno bacanje para.
Evo pa propusti kroz translate. U principu da se spreči klizanje između magnetnog nosača i nekog od drugih nosača, ako klizi, iako je šraf maksimalno strgnut: The Anti Slip Pad (Ring Sticker) is supposed to be used when the Quick Release Adapter Mount is moving no matter how hard you have screwed the thumbscrew in on the extra accessory (for example bike mount, handlebar mount). Due to the speed and bumps and wind the action camera can wiggle/slip to the front or back even if you screwed the thumbscrew hard into the accessory. The rings can then be used to prevent it from moving and make it more secure so that it stays in place even during a very rough ride. The placement of the ring is best seated on the inside between quick release and accessory (one is mostly adequate and is best placed on the Quick Release Mount hole). But most original accessories should have an adequate strong hold without the need for anti-slip rings/pads (but in some extreme sports/rides it can move due to bumpiness or vibration). If you go for an after-market/third-party accessory the fit between that and the original quick-release plate may not be the best and can move around (since the spacing might not be the best fit and a bit too lose no matter how hard you screw the thumbscrew in).
Trebalo bi da je ovako: Silkolene Comp 4 10w-40 XP Art. ID: 255291
I meni danas Temu za tačno 7 dana ali je zanimljivo da je porudžbina, pošto se sastoji od više stvari i veće je vrednosti, podeljena u dve pošiljke od koje je prva ova o kojoj govorim a druga je tek juče sletala u BG tako da u suštini nema pravila. I dalje je usko grlo carina i to se sigurno neće promeniti.
Od kvaliteta izrade do nekoliko kafa koje sam do sada skuvao za probu ja sam prezadovoljan. Evo linka: https://www.aliexpress.com/item/1005007317504326.html?spm=a2g0o.order_list.order_list_main.5.5be61802wuGENz E sad ima fora. Ako naručiš da ti stigne kod nas cena vidiš koja je. Ako imaš nekog drugara u Rumuniji i naručiš tamo, kao što sam ja uradio, onda vidi cenu. Plus stigne za deset dana:
Znači biće tema i na nekom traktorističkom forumu? Registrujem se i pratim razvoj situacije.
Temu pratim a tvoj post naravno da nisam pročitao jer je NEPISMEN (ili si nepismen) pa samim tim i nečitljiv. Možeš i pet "romana" da napišeš ali ako učestvuješ u radu jednog foruma očekuje se da ti "romani" budu napisani u skladu sa elementarnim pravopisom. Pozdrav i ovo shvati kao dobronamernu, konstuktivnu kritiku.
Ništa tačka, ništa zarez. Genijalno...
Naručio sebi danas tri litra 15w50-XP Pro. Cena identična kao pre godinu dana 1303 din. Evo slike sa monitora u Delmax-u dok su mi radili porudžbinu. Što se ulja tiče dve godine sam koristio Comp iste gradacije i pokazalo se odlično a prošle godine probao Pro i ulje nije odlično nego je FENOMENALNO.
Realno nije ni prevara. Da imaju napismeno ugovor o pozajmici ili da je makar bilo u prisustvu svedoka moglo bi da se priča o prevari. Ovako je reč protiv reči i svodi se na to da je dobio malu novčanu sumu na poklon. Na stranu da ostavimo to da može da kaže da je hteo da se javi da vrati pozajmicu ali eto slučajno je obrisao broj a ima fobiju od javljanja na nepoznate brojeve. Nešto u fazonu "pas mu je pojeo domaći".
Nije to fora pošto realno ovaj dobri gospodin ništa nije ukrao.
Razlika nije samo kozmetička počev od veće zapremine rezervoara preko drugačijih i boljih retrovizora, položaja suvozačkih fuzastera... da ne pričamo o farovima koji za razliku od prve generacije rade svoj posao. Učini sebi uslugu i skupi još malo para pa čekaj da se pojavi neki dobar primerak 2002-03.
Na ovoj poslednjoj slici koju si postavio veliki štaf bi trebalo da je za podešavanje ler gasa a ovaj koji sam zaokružio za podešavanje smeše. E sad zašto je kod tebe u ovakvom stanju kao da mu je odlomljena glava to ne znam. Uglavnom ono "izgrebano" sa prve slike ja ne bih dirao.
I meni se na osnovu slike čini da je ovo neki umetak - poklopac kirnovan na dva mesta da bi tu stajao. De slikaj ti taj karburator sa svih strana.
Ne postoji jer praćenje sa tim brojevima ide samo do Mađarske. Od Mađarske do Srbije ide bez praćenja. Znaju to i fucking Kinezi i prave se ludi da ne bi vraćali pare. Ne bacajte drvlje i kamenje na poštu tek tako.
I ovaj mamlaz je ovo ladno stavio na net da svi gledaju njegovu bahatost i bruku zarad jebenih klikova. Impresivno...
Iz nekog razloga mi ne dozvoljava da postavim Louisov link. Za pranje odeće. O pranju odeće sa GoreTex membranama pričamo, ne o pranju motora. S100 Fabric & Leather Wash SHOP.DR-WACK.COM Dr. Wack - S100 Fabric & Leather Wash 300 ml I liquid detergent for motorcycle clothing of all kinds I high-quality motorcycle care - Made in Germany Idi na Louis sajt i kucaj "s100 technical wash".
PERFORMANCE WASH DC 1L WWW.IGLUSPORT.RS Sredstvo za čišćenje svih vrsta sportske, nepromočive i prozračne odeće, uključujući Gore-Tex® materijal. Čisti, optimizuje disanje i ne uklanja vodoodbojnu impregnaciju... SREDSTVO HOLMENKOL ZA PRANJE TEKSTILA NATURAL CAPSULES 20ml PLANETBIKE.RS A čini mi se da sam i u Beosportu višao deterdžente za odeću sa GoreTex membranom Ja koristim S100 TECHNICAL WASH iz Louisa i što se mene tiče radi odličan posao.
Jel misliš da je normalno da za svako svoje pitanje otvoriš novu temu?
Meni se Aspidex iz Compp Co proletos odlično pokazalo. Vozio sam 340 km po potpu od kiše i stigao kući potpuno suv.
Mani se Delte jer i da imaju odrali bi te za besmisleni konektor. https://www.aliexpress.com/item/32823498497.html?spm=a2g0o.productlist.main.19.21de20dduv8EH7&algo_pvid=6d9530ab-28eb-44c9-bf3f-8e6db72e283a&algo_exp_id=6d9530ab-28eb-44c9-bf3f-8e6db72e283a-9&pdp_npi=4%40dis!EUR!0.60!0.57!!!0.65!0.62!%40210133e017253968740013729eaa23!64894514056!sea!SRB!185176652!X&curPageLogUid=FyA0heHH6Tfc&utparam-url=scene%3Asearch|query_from%3A https://www.aliexpress.com/item/32873390417.html?spm=a2g0o.productlist.main.1.21de20dduv8EH7&algo_pvid=6d9530ab-28eb-44c9-bf3f-8e6db72e283a&algo_exp_id=6d9530ab-28eb-44c9-bf3f-8e6db72e283a-0&pdp_npi=4%40dis!EUR!1.33!0.79!!!1.44!0.86!%40210133e017253968740013729eaa23!65540005589!sea!SRB!185176652!X&curPageLogUid=f6auDZYrXeka&utparam-url=scene%3Asearch|query_from%3A itd. Ima ih raznih. A možeš da potražiš i u: M&G Electronic WWW.MGELECTRONIC.RS Elektronske komponente na veliko i malo :: MikroPrinc WWW.MIKROPRINC.COM Merna i test oprema, lemna oprema i pribor, elektronske i elektromehaničke komponente, poluprovodnici, napajanje, programatori, računarska i telekomunikaciona opreama...
Ja imam sivu-srebrnu.
