spdzlla 0 Napisano Maj 17, 2010 Drug član, 3618 postova Lokacija: Kovin Prijavi odgovor kao problematičan Evo prvih slika, podataka i videa za potpuno novog Sprinta ST koji je planiran za sledecu godinu ali ce se na trzistu ipak naci krajem ove godine. 2011 Triumph Sprint ST specs: Engine Liquid-cooled, 12 valve, DOHC, in-line 3-cylinder Capacity 1050cc Bore/Stroke 79 x 71.4mm Compression Ratio 12.0:1 Fuel System Multipoint sequential electronic fuel injection with SAI Transmission Final Drive X ring chain Clutch Wet, multi-plate Gearbox 6-speed Cycle Parts Frame Aluminium beam perimeter Swingarm Single-sided, aluminium alloy with eccentric chain adjuster Front Wheel Cast aluminium alloy 5-spoke 17 x 3.5in Rear Wheel Cast aluminium alloy 5-spoke 17 x 5.5in Front Tyre 120/70 ZR 17 Rear Tyre 180/55 ZR 17 Front SuspensionShowa 43mm cartridge forks with dual rate springs and adjustable preload, 127mm travel Rear Suspension Showa monoshock with adjustable preload and rebound damping, 152mm rear wheel travel Front Brakes Twin 320mm floating discs, Nissin 4-piston calipers, ABS Rear Brakes Single 255mm disc, Nissin 2-piston sliding caliper, ABS Dimensions Length 2260mm Width (Handlebars) 760mm Height 1210mm Seat Height 815mm Wheelbase 1537mm Rake/Trail 23.5°/84mm Wet Weight (homologated) 268kg Fuel Tank Capacity 20 litres Performance (measured at crankshaft to 95/1/EC) Maximum Power EC 130PS Maximum Torque EC 108Nm Colours Pacific Blue, Aluminium Silver Price £9,499 OTR Izvor informacija Visordown. Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
wulfy 217 Napisano Jul 7, 2010 Drug član, 1592 postova Lokacija: Budva - MNE Motocikl: Aprilia Pegaso 650 Strada Prijavi odgovor kao problematičan Poslije lansiranja modela Sprint GT http://www.nolimitbikers.com/forum/viewtopic.php?f=18&t=2340 došlo je vrijeme da s i redizajnira i bazni Sprint ST http://www.nolimitbikers.com/forum/viewtopic.php?f=18&t=1890 . Redizajn podrazumjeva bord kompijuter sa više podataka, prednja viljuška sa manjim uglom čime je i smanjeno međuosovinko rastojanje. Zbog nešto više opreme težina je povećana za 27 kg. Nova je i mapa paljenja tako da ST za 2011 razvija drugačije snagu nego ST iz 2005 godine i ima nešto drugačije vrijednosti maksimalne snage i obrtnog momenta. Osim ovih detalja izmjenjeni su i neki detalji na oplatama što se vidi iz priloženih slika. Iz slika se vide razlike u dizajnu na osnovu predhodnog modela http://www.nolimitbikers.com/forum/viewtopic.php?f=18&t=1890 a za poređenje tehničkih podataka evo i tabele sa tehnikalijama. Tehnički podaci za Triumph Sprint ST 1050: Motor: R3 Zapremina: 1.050 ccm Snaga: 128 KS pri 9.200 o/min. Obrtni moment: 108 Nm pri 6.300 o/min. Mjenjač: 6 brzina Težina spremnog za vožnju: 268 kg Ukupno dozvoljena težina: - kg Nosivost: - kg Rezervoar: 21 l Visina sjedišta: - cm Ubrzanje do 100 km/h: - s Max. brzina: - km/h Citat Podeli ovaj odgovor sa prijateljima Link to post Share on other sites More sharing options...
