Erbauer akumulatorski set alata
  • Zainteresovan, 212 postova
  • Lokacija: Becej
Erbauer set akumulatorski se sastoji od busilice sa cekicem i posebno udarnim zavrtacem. Set je kupljen u UK potpuno nov sa dve li jon baterije od 2.0 ah i brzim punjacem. Veoma kvalitetan alat, robustan i jak Nemackog proizvodjaca. Garancija 2 godine ali  preko mene i ne danas za sutra jer covek dolazi jednom mesecno iz UK. Alat je u klasi Bosch, Makite ali ne i Dewalta, ostale Vilagere, Womaxe, Bomaxe i Einhele ne vredi ni spominjati, pogodan za gipsare, tesare ... U produzetku su slike alata kao i specifikacije, snimak rada istog mozete naci na youtubu naravno, kao i link gde mozete procitati ocene zadovoljnih kupaca.
 Cena 180e
0638524305 Bojan
SPECIFICATION
Battery Chemistry Li-Ion
Battery Power 2.0 Ah
Brand Erbauer
Brushless Brushed
Carry Case/Bag Included Yes
Charge Time 60 min
Corded or Cordless Cordless
Manufacturer Guarantee 2 Year Manufacturer's Guarantee (T&Cs Apply)
Model No ERI742KIT
No. of Batteries Per Pack 2
Pack Size 1
Pieces in Pack/Case 2
Power Voltage Supply 18 V
Product Type Combi Drill & Impact Driver Twin Pack
Tool 1 Max. Torque 40 Nm
Tool 1 Model No ERI744COM
Tool 1 Product Type Combi Drill
Tool 1 Specification Max. drilling capacity in masonry 13mm, wood 35mm, steel 10mm. Max. torque 40Nm. No-load speed 0-400 / 0-1500rpm. Impact rate 0-6400 / 0-24,000bpm. Overall length 215mm. Weight 1.2kg.
Tool 2 Max. Torque 120 Nm
Tool 2 Model No ERI604IPD
Tool 2 Product Type Impact Driver
Tool 2 Specification Bolt capacity M12. Max. torque 120Nm. No load speed 0-2600rpm. Impact rate 0-3000bpm. Overall length 157mm. Weight 1.1kg.
PRODUCT CONTENTS
ERI744COM combi drill, ERI604IPD impact driver, charger, 2 x 2Ah Li-ion batteries and carry case.
https://www.screwfix.com/p/erbauer-eri742kit-18v-2-0ah-li-ion-cordless-combi-drill-impact-driver-twin-pack/9478t#product_additional_details_container
  • Zainteresovan, 459 postova
  • Motocikl: Kawasaki Z1000 Mk2 (1979) Piaggio Beverly 250 (2005) Honda ADV 350 (2025)
Dobar komplet! To je ovo...
Pošto sam pre izvesnog vremena kupio Li-Ion bušilicu iz serije plavog Bosch-a a trebao bi mi udarni odvijač, mogao bih da ti ponudim zamenu uz moju doplatu. Bušilica je jako malo radila, u odličnom je stanju, kao i prateća oprema.
Moj Bosch je model GSR 14,4-2-Li. Nisam kod kuće, prilično sam siguran da je taj model ali ako sam slučajno omašio ispraviću u toku dana. U svakom slučaju, ide u paketu sa kartonskom Bosch kutijom, dve Li-jonske baterije od 14,4V 2Ah i brzim punjačem AL1820CV. Naravno, baterije su kod Boscha komplementarne pa korisnik po želji može da stavi i druge jače.
Evo kako izgleda:
Bosch GSR 14,4 - 2 - Li
Ako si zainteresovan, iskontaktiraćemo za detalje.
  • Lokacija: Becej
Bilo bi mi drago da ti izadjem u susret ali mi je slabo i iskreno najvise menjam jer mi je cekic na busilici slab ( imao Dewalt pre ovog), udarna je jakoooo dobra kao sto vidis iz opisa m12 srafove zavrce bez problema. Probaj tvoju da oglasis u produzetku pa mozda neko kupi a ti uz doplatu dodjes do sjajnog seta.
Ok drugar, javiću se kad prodam moj alat ako tvoj do tada ostane u prodaji.
  • Lokacija: Becej
Ako i ne bude ovaj bice neki drugi ili cemo naruciti set, mogu sve sa sajta da nabavim po lepim cenama tj. jeftinije 30 % nego kod nas. Kisaca se secas?  ;)
Sjajno, bićemo u kontaktu. Kisač se ne da zaboraviti, za njega me vežu posebne emocije! :takoje:
