Arakis
Administratori
  1. Važni podaci o našim Transalpovima Service manual: http://www.filestube...Manual-ENG.html http://www.filestube...+service+manual http://www.manualede...Microfiche.html http://www.manualede...-1987-2002.html Uputstvo za razne prepravke https://docs.google....Vpld1V3VjA/edit Dimenzije ležajeva u točkovima: prednji su 6202, zadnji su 6203 i ležaj zupčanika je 6204. Dimenzije ležajeva upravljača: 26x47x15 mm, oba (prema www.wemoto.com) Svećice: NGK DPR8EA-9 Delovi za TA: http://www.hamart.at...Hand-Parts.html Termoprekidač ventilatora: odgovara od automobila Suzuki Maruti, cena oko 900 din Year of manufacture/VIN Year of manufacture: 1987-1993 VIN: PD06-3000002 to PD06-5200008 Capacities Fork oil per rod: 550 ML SAE 7,5W Engine oil w/o filter: 2,2 L SAE 10W-40 Engine oil incl. filter: 2,4 L API SE-SF Final drive lubricant: Brake fluid: DOT 4 Coolant: 2,0 LITER Fuel: 18,0 LITER Technical data Engine size: 583 ccm Cylinders: 2 hp/kW: 50/37 - 34/25 Valve clearance (intake): KALT 0,15 MM Valve clearance (exhaust): KALT 0,20 MM Engine idle speed: 1300 ± 100 U/MIN Carburettor air screw: 2,25 AUSDREHUNGEN Tyre pressure (front): 2,0 BAR Tyre pressure (rear): 2,0 BAR Spark plug 1: NGK DPR8EA-9 Spark plug 2: NGK DPR8EIX-9 Electrode gap: 0,9 MM Fork tube Ø: 41 MM TELEGABEL Front and rear sprockets: 15/47 ZÄHNE Chain/final drive: 118 GLIEDER Year of manufacture/VIN Year of manufacture: 1994-1996 VIN: Capacities Fork oil per rod: 550 ML SAE 7,5W Engine oil w/o filter: 2,2 L SAE 10W-40 Engine oil incl. filter: 2,4 L API SE-SG Final drive lubricant: Brake fluid: DOT 4 Coolant: 2,0 LITER Fuel: 18,0 LITER Technical data Engine size: 583 ccm Cylinders: 2 hp/kW: 50/37 - 34/25 Valve clearance (intake): KALT 0,13-0,17 MM Valve clearance (exhaust): KALT 0,18-0,22 MM Engine idle speed: 1300 ± 100 U/MIN Carburettor air screw: 1,75 AUSDREHUNGEN Tyre pressure (front): 2,0 BAR Tyre pressure (rear): 2,0 (2,3) BAR Spark plug 1: NGK DPR8EA-9 Spark plug 2: NGK DPR8EIX-9 Electrode gap: 0,9 MM Fork tube Ø: 41 MM TELEGABEL Front and rear sprockets: 15/47 ZÄHNE Chain/final drive: 118 GLIEDER Year of manufacture/VIN Year of manufacture: 1997-2000 VIN: ZDCPD10A*VF000001-G to ZDCPD10B*VF000001-2G Capacities Fork oil per rod: 550 ML SAE 10W Engine oil w/o filter: 2,2 L SAE 10W-40 Engine oil incl. filter: 2,4 L API SE-SG Final drive lubricant: Brake fluid: DOT 4 Coolant: 2,0 LITER Fuel: 18,0 LITER Technical data Engine size: 583 ccm Cylinders: 2 hp/kW: 50/37 - 34/25 Valve clearance (intake): KALT 0,13-0,17 MM Valve clearance (exhaust): KALT 0,18-0,22 MM Engine idle speed: 1300 ± 100 U/MIN Carburettor air screw: 2,25 AUSDREHUNGEN Tyre pressure (front): 2,0 BAR Tyre pressure (rear): 2,0 (2,25) BAR Spark plug 1: NGK DPR8EA-9 Spark plug 2: NGK DPR8EIX-9 Electrode gap: 0,9 MM Fork tube Ø: 41 MM TELEGABEL Front and rear sprockets: 15/47 ZÄHNE Chain/final drive: 118 GLIEDER
  2. Minus 9 je bilo uveče kad sam odvezao Kopriana kući na Medak...tako da su me posle jedva odlepili sa sedišta
  3. Što? Kad je gladan hoće i saputnika da pojede?? ;D
  4. Laku noć i lepo pawaj
  5. Baš jedan fini i dostojanstven mladić ;D
  6. Ma za Transalpa...nije hitno, dok se vreme prolepša, javiću se ja obavezno.
  7. Ja već kupio gume, ali upek'o minus... ;D Čim se razlepša, eto mene. Imaš li možda umutrašnje gume?
  8. Ma sredićeš to, nije problem. A od Jasminka? Video sam oglas i sliku, ok je. R.I.P. ima isti takav, pa ti može više pomoći, a ti samo na proleće promeni ulje i vozikaj se.
  9. Idi u profil i isključi bilo kakva obaveštenja na mail...zatrpaće te bez veze
  10. Smederevo ti je najbolje odredište, momci rade kvalitetno i upola jeftinije nego u Bgd, bar sam tako čuo.
  11. Pametno bogami Kad otopli, možemo da vitlamo po blokovima ;D A šta hoćeš da uradiš u servisu?
  12. Ubačeni kineski element u japanske redove ;D
  13. Pa gde si komšija
  14. Svi smo mi po malo kinezi... ;D...sekta je to
  15. Ugaćama ;D
  16. ...i još vozio Kopriana kući na Medak, pa posle samog sebe kući u Blokove.... Ne dam se ja ;D
  17. Kad meni nije ništa, vama omladincima nema da fali ič ;D
  18. Pozdrav!
  19. Ne nije taj, drap boje, samo vozač.
  20. Ma hteli smo nas nekoliko, ali na šta bi to ličilo...sva sreća, niko nije pao, ali je bilo za nekih 10-tak cm, ja sam bio iza na nekih 10 metara i sledio se....
  21. Kreten nas je posle nadvožnjaka pre Ade obilazio sa desne strane i na silu ušao među nas da bi obišao naše snimatelje u žutoj traci. Pri tom je za malo oborio jednog od nas i pobegao džukački desno na B. Brdo.
  22. Ja sam zapisao broj i proslediću R.I.P.-u, žao mi je samo što nisam mogao da slikam, kao dokaz.
  23. Odličan posao Bobo, veseli akcijaši, prelepe seka - mrazice, dečica, paketići...odlično!
  24. Ma stolica nije prišvršćena, a lik je na štenderu... ;D
  25. Sa skuterčetom oko 4 500, sa TA oko 300 ;D
