Powertuning box
  • Svrati ponekad, 232 postova
  • Lokacija: Pecinci
Evo uputstva...
1.Locate IAT (Intake Air Temperature sensor).It is usually  on AIR BOX CLEANER ,throttle body,or somewhere near throttle body(see picture) ,under the fuel tank.It is two peen connector.
If you are not sure that you locate right,you can tested (see picture)
2.INSTALL CHIP
when you locate IAT,disconnect battery,ignition turn off
Then unplug two wire connector and plug chip in instead of IAT sensor
Once installed tie back or fasten the wires in a safe place (tape, silicone)
Reconnect the battery.
  Start the motor and hold at 2700 rpm's for 1 (one) minute. This will allow
the computer to re-program your ECU.
  After holding at 2700 rpm's, let the  bike idle for at least 15-20 minutes;
then turn bike off and restart before driving.
3. ENJOY THE RIDE
CHEERS
powertuning.2009
