Razrada novog motora
  • U prolazu, 64 postova
  • Lokacija: BEOGRAD 011
Danas je stigla tablica i saobracajna za Duke-a i ovih dana planiram da ga preuzemem, samo jos par stvari da se ugradi...
Pricajuci sa iskusnijim motociklistima u vezi razrade dosao sam do totalno razlicitih misljenja...
Stav br 1:
-Izaci na autout ubaciti u sestu i voziti tako...
Stav br 2:
-Voziti po gradu i sto cesce menjati brzine da se lepo menjac razradi...
Stav br 3:
-Ibarska magistrala i lagana voznja...
Jedino su bili svi jedinstveni da ne treba prelaziti 6000 rpm u razradi...
I sta sad da radim...
  • Drug član, 1359 postova
neznam ko ti reko da razradjujes menjac i sto  kod mene ide ko u sir  . razradjuje se koliko ja znam putanja klipa u  stublini i lezaj na radilici kao i ventili i jos ponesto u motoru . za to ti treba laganija voznja bez velike brzine ono sto ti rekose da netreba prelaziti 6000rpm ali netreba ni do njih dolaziti brzo . treba da izbegavas auto put jer razrada trazi da se nevozi konstantnom brzinom dugo vec da menja brzina rada motora , ali opet bez nekih naglih cimanja motora .
  • Svrati ponekad, 418 postova
  • Motocikl: Ducati
Evo šta piše u upustvu za moju Apriliu
RUNNING-IN
The running-in of the engine is essential to
ensure its life and correct operation.
If possible, ride on hilly roads and/or roads
with many bends, so that the engine, the
suspensions and the brakes undergo a
more effective running-in.
During running-in, change speed.
In this way the components are first
“loaded” and then “relieved” and the
engine parts can thus cool down.
Even if it is important to stress the engine
components during running-in, take care
not to exceed.
NOTE Only after the first 2000 km (1250
mi) of running-in you can expect the best
performance levels from the vehicle.
u Do not open the throttle completely if the
speed is low, both during and after
running-in.
u During the first 500 km (312 mi) put on
the brakes with caution, avoiding sharp
and prolonged braking. This ensures a
correct bedding-in of the pads on the
brake disc.
u During the first 500 km (312 mi) never
exceed 4000 rpm.
u When the total number of km covered by
the vehicle is included between 500 km
(312 mi) and 1000 km (625 mi), never
exceed 5000 rpm.
WARNING
After the first 1000 km (625 mi), have an
aprilia Authorised Dealer carry out the
checks indicated in the column “After
running-in” of the regular service
intervals chart, see page 58 (REGULAR
SERVICE INTERVALS CHART), in order
to avoid hurting yourself or other
people and/or damaging the vehicle.
u Between the first 1000 (625 mi) and
2000 km (1250 mi) ride more briskly,
change speed and use the maximum
acceleration only for a few seconds, in
order to ensure better coupling of the
components); never exceed 5500 rpm
(see table).
u After the first 2000 km (1250 mi) you can
gradually expect better performance
from the engine.
Engine maximum rpm recommended
Mileage km (mi) rpm
0 – 500 (0 – 312) 4000
500 – 1000 (312 – 625) 5000
1000 – 2000 (625 – 1250) 5500
  • Drug član, 2753 postova
  • Lokacija: MNE-SRB-BIH-CRO (trenutno Herceg Novi))
  • Motocikl: GPZ 500 Street Twin
Kako je meni objasnjeno, razrada je ustvari ispiranje motora od naslaga ulja koje je u masini od momenta napustanja fabrike do preuzimanja od strane kupca, a ponekad taj period zna da traje i 6 mjeseci. Zato ima prva razrada od 300-500km (zavisi od modela), kada se skine veci dio naslaga i tada treba bas polako voziti, cesto mjenjati brzinu da bi se svi lezajevi razradili, poslje ide druga razrada 1000-1500km kada vec imate novo ulje u masini al i dalje su ostale naslage u tragovima, mozete voziti malo slobodnije, al ipak oprezno. Poslje ovoga perioda smatra se da je motor isprao naslage staroga ulja i moze se voziti normalno. U uputstvu za koriscenje pise tacno za svaki model koliko traje razrada i koju brzinu nebi trebalo prelaziti
  • Svrati ponekad, 423 postova
  • Lokacija: Cuprija
Radi kako pise u manualu i nista se ne brini.Predji lagano predvidjenu kilometrazu za razradu i posle uzivaj.......Taman se upoznaje sa motorom tako da nije problem
  • Enduraš, 6690 postova
  • Lokacija: Paracin
  • Motocikl: 450MT
Lose su ti objasnili, razrada nema nikakve veze sa "naslagama ulja". Kakve naslage ulja, pa ulje je tecno, ne moze da pravi nikakve naslage. Radi se o tome da tokom razrade razni sklopovi u masini "lezu" kako to majstori kazu, tj. sitne neravnine i nastale u obradi materijala (recimo izmedju karika i cilindra, lezajeva, zupcanika u menjacu) se ravnjaju i dovode u stanje kakvo treba da bude, tokom razrade. Pri tom se stvaraju opiljci i zato se menja ulje posle 1000km.
U abarh-ovom postu je lepo objasnjen nacin razrade.
Nisam mehanicar pa ne znam, pricao sam o tome sa likom koji ih prodaje i servisira, kako mi je objasnio to je da se isperu necistoce, staro ulje koje je malo gusce jer se konzervira motor prije nego sto ode na brod. U ove necistoce sigurno spadaju i ti opiljci, pogotovu kod masina jeftinije izrade, zato su kineski i slicni motori osetljiviji na losu razradu. Ostali proizvodjaci su mnogo pazljiviji kod ovakvih detalja, pogotovo kod motora visokih performansi, primjer BMW M3 koji sa trake ide na pistu da bi se ispitale vozne karakteristike...
