U ovu kavu sto sto si ti okacio je ulozeno jako mnogo truda doj je poskidao sve sto se skinuti moze,truda je jakoooo mnogo ulozio dok je ofarbao motor,a novca jos vise,jako je skupo litar crne farbe,i ovaj far od fergusona napred hahahaah
Znaci ja sam sad budala a ti si pametan. Dobro.
Ocu samo da kazem da ponekad i nije potrebno bogatstvo da bi se dobilo nesto lepo. Mada daleko od toga da je samo secena i skinute plastike.
Works on the Kawa ZX6R:
Fabricated / modified / relocated:
• Aluminum headlight brackets made from aluminum stock and factory clip-ons
• Ignition lock cylinder mount removed, upper triple shaved smooth
• Guage bracket
• Unused mount points on lower triple removed
• Forks lowered internally 1.5", externally 1"
• Extra mount lugs removed from fork tubes
• Aluminum bracket to relocate ignition lock cylinder
• Aluminum brackets for coolant reservior
• Coolant reservior made out of a camping stove fuel bottle - cap modified for overflow, inlet mounted in bottom
• Seat pan shaved and seat shaped from combining factory front and rear seat foam, then shaved to shape. Latching pin mounted in seat pan
• Custom leather seat cover
• Subframe cut, lowered, welded, crossbar for seat latch added
• Battery box custom made
• Rear brake reservior mount
• Front brake reservior mount
• Lower radiator mount bar
• Under-seat storage compartment
• Seat latch / lock cylinder
• Battery / relays / fusebox / CDI / fuel pump / fuel filter relocated
• Wiring harness - shortened, all connectors relocated
• Frame / subframe / swingarm - ram air tubes gound flat, mount lug for factory headlight removed, misc brackets & mount lugs removed on swingarm, holes drilled for mounting new brackets / clips / equipment - scratches, scrapes and dings filled
• Side stand shortened
• Clamps / guides for clutch cable
• Mount brackets for tail
• Fiberglass tail (not yet finished)
• Fuel lines re routed
• Radiator fins straightened
• Factory muffler mount flange removed from exhaust
Bolt-ons:
• Vortex race clip-ons
• Ducati Monster headlight
• Pazzo short/long race levers
• Handlegrips
• Braided steel brake lines
• Supertrapp exhaust
• Heaader wrap
• License plate mount
• LED license plate lights
• Oberon foot pegs
• Bar end mirrors
• Solid state flasher relay
• Rear lowering links
• Radiantz stop / turn / tail LED strip (not yet finished)
• Supertrapp muffler welded onto end of pipe
• Header wrap (the end isn't finished yet - ran out of wrap 6" short, clamp in the rear is temporary)
Parts replaced / new
• Rearset bolts
• Rear axle nut
• Several other rounded-off bolts around the bike
• All various factory bolts replaced with new allen bolts / cap screws, nuts replaced with nylocks the rest are media blasted & polished to be silver
• Upper steering head seal
• Fork seals
• Stator cover gasket
• Chain
• Lower radiator hose
• PCV hose
• Fuel lines
• Coolant expansion tank hose
• Throttle cables
• Brake reservior hoses
• Radiator bushings
• Tank bushings
• Clutch cable
• All zerk grease fittings
• Tires
• Chrome valves stems
• CDI
• Fuse / relay box
Painted / refinished
• Powder coated: Frame, swingarm, subframe.
• Black w/clear: Tank, wheels, fork tubes, brake rotors, headlight bucket, upper & lower triples, rearsets, heel guards, engine covers, misc brackets, lower radiator mount, coolant expansion tank.
• Wheels pinstriped
• Flat black: Engine, radiator, rear sprocket, storage tray, seat pan, timing cover, headlight ring, side stand, rear brake reservoir
Every single other part and sub-assembly on this bike, not listed here, down to individual screws, springs and clips, was disassembled, cleaned, repaired and/or rebuilt then polished or painted.
